  3. ENC28J60 Ethernet gateway
14 Posts 5 Posters 2.2k Views 3 Watching
  • Sergio RiusS
    Sergio RiusS
    Sergio Rius
    wrote on last edited by Sergio Rius
    As I was having low reliability with my gateway, I'm trying to build an ethernet one. But I can't make it work. I have those components:
    arduino nano
    ENC28J60 nano ethernet shield (this one)
    An original nrf24, shielded pa+lna
    I'm burning this sketch, sligtly altered from examples:
    #define MY_RADIO_RF24
    //#define MY_RADIO_RFM95
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "mys-in"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mys-out"
    // Set MQTT client id
    #define MY_MQTT_CLIENT_ID "mys-langw-mqtt"
    #define MY_CONTROLLER_IP_ADDRESS 192,168,50,201
    #define MY_PORT 1883
    // Enable these if your MQTT broker requires username/password
    #define MY_SOFTSPI
    //#define MY_SOFT_SPI_SCK_PIN 14
    //#define MY_SOFT_SPI_MISO_PIN 16
    //#define MY_SOFT_SPI_MOSI_PIN 15
    // When ENC28J60 is connected we have to move CE/CSN pins for NRF radio
    #define MY_RF24_CE_PIN 5
    #define MY_RF24_CS_PIN 6
    #define MY_GATEWAY_ENC28J60
    #define MY_IP_ADDRESS 192,168,50,211
    #define MY_IP_GATEWAY_ADDRESS 192,168,50,1
    // #define MY_PORT 5003
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
    // Enable inclusion mode
    // Flash leds on rx/tx/err
    #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    #include <Arduino.h>
    #include <UIPEthernet.h>
    • I copied the UPIEthernet v1.0.4 from the example.
    But all I get in debug is:
    18:25:24.979 -> 0 MCO:BGN:INIT GW,CP=RNNGA---,REL=255,VER=2.3.1
    18:25:24.979 -> 4 TSM:INIT
    18:25:24.979 -> 5 TSF:WUR:MS=0
    18:25:24.979 -> 11 TSM:INIT:TSP OK
    18:25:24.979 -> 13 TSM:INIT:GW MODE
    18:25:24.979 -> 15 TSM:READY:ID=0,PAR=0,DIS=0
    18:25:24.979 -> 17 MCO:REG:NOT NEEDED
    I had to introduce the SoftSpi because I was getting radio init errors. But now, there's no traffic at all.
    I've done everything possible, checked the wiring many times... Independly feeding the components...
    Does anyone use that setup? Thanks
    EDIT: OK, so now I found that this module is not recommended.
    • K
      K
      kimot
      ENC28J60 for a stable gateway is not a good idea.
      Buy some Wiznet...
      C 1 Reply Last reply
      • Sergio RiusS
        Sergio RiusS
        Sergio Rius
        So after being unable to make the nrf24 to work with the ENC28J60, I'm trying now something different. I started by making an rfm69 serial gateway with success. :clap:
        Then I want to see if it could be possible to convert it to ethernet with the ENC28J60.
        I searched and found everything in the forum. I arrived to the conclussion (that is probably wrong) that I must wire both radio and eth module using the same spi pins, activating a new driver and nothing more. But this doesn't work on the proto-board.
        There's something else to be done? Thanks.
        • scalzS
          scalzS
          wrote on last edited by scalz
          @Sergio-Rius
          unfortunaly I can't help with your enc28j60 issue. and I'm not sure to have one for testing this.
          A while back, we checked w5100 module + arduino 328p. Eth module and radio were working on same hw spi bus but in docs it uses softspi, I don't remember why, perhaps for having a dedicated spibus for ethernet..
          I understand this is not very convenient to find the infos, when always more hw is supported.
          Just a note, as you are using a Nano for your tests, RFMs modules are not 5v tolerant in theory, even if they seem to handle it, datasheet says 3.9v for max. good to know. but maybe you're already using a level converter.
          Sergio RiusS 1 Reply Last reply
          • scalzS scalz
            @Sergio-Rius
            Sergio RiusS
            Sergio RiusS
            Sergio Rius
            @scalz Thanks for your help. Unfortunately I can't get a w5100 in my country and would order it outside. I had those rfms for years and I want to test range before buying a sensebender.
            And I'm convinced to stop using the wifi for a gw.
            I had hope that any used had the same hw already running.
            • K kimot
              Buy some Wiznet...
              C
              C
              cabat
              @kimot I am use one Ethernet gateway about 2 year - work good and stable.
              • C cabat
                Sergio RiusS
                Sergio RiusS
                Sergio Rius
                @cabat Could you please share you pinout for radio and module, and the sketch configuration?
                I can't make it work and I don't know if it's a matter of connections or something to activate, like softspi.
                • Sergio RiusS Sergio Rius
                  C
                  C
                  cabat
                  wrote on last edited by cabat
                  @sergio-rius Pinout as described here Building an Ethernet Gateway, i am use module like this:
                  and my sketch on 20-Feb-2019 is:
                  #define MY_BAUD_RATE 9600
                  //#define MY_RF24_PA_LEVEL RF24_PA_MIN
                  #undef MY_REGISTRATION_FEATURE
                  #undef MY_CORE_COMPATIBILITY_CHECK
                  // Gateway IP address
                  #define MY_IP_ADDRESS 192,168,1,235
                  //#define MY_LEDS_BLINKING_FEATURE
                  //#define MY_DEFAULT_LED_BLINK_PERIOD 300
                  //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
                  //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
                  //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
                  • nagelcN
                    nagelcN
                    nagelc
                    wrote on last edited by nagelc
                    @scalz said in ENC28J60 Ethernet gateway:
                    It may have been fixed by now, but originally the W5100 did not release the SPI bus properly. So, it needed a separate SPI bus from the radio.
                    I think this was fixed in the W5200 and W5500.
                    • scalzS
                      scalzS
                      @nagelc
                      exactly, you're right! Better memory than me :) I remember now, I had to hack w5100 lib for spi transactions to make it working on same bus. So I don't know if it has been fixed.. I hope so.
                      • nagelcN nagelc
                        Sergio RiusS
                        Sergio RiusS
                        Sergio Rius
                        @nagelc said in ENC28J60 Ethernet gateway:
                        Noooooo..... Just ordered a W5100 :sob:
                        @cabat It may not do for me. I'm trying to use rfm69 now. I could not leave my existing network down and brought the nrfs back to where they belonged.
                        Also the eth module I have here is the shield for nano one. As it stacks below the nano, it may be that is interfering more pins than I expected.
                        What I would want to know is that the rfm69 needs a different pinout with this shield or not. I can't find any reference that tells me this, so I can start debugging the problem.
                          C
                          C
                          cabat
                          @sergio-rius sorry, my mistake, missed of using RFM69 in your setup..
                          • C cabat
                            Sergio RiusS
                            Sergio RiusS
                            Sergio Rius
                            @cabat Oh, no! Thanks for your help. It has inspired me. Now I'm trying something more.
                            • Sergio RiusS
                              Sergio RiusS
                              Sergio Rius
                              I've been fiddling with the radio alone (serial gw), softspi and changing pins, and I think there's something else here.
                              Well those are my findings:
                              With this base definition and without the module wired:
                              #define MY_RADIO_RFM69
                              #define MY_RFM69_NEW_DRIVER
                              #define MY_IS_RFM69HW
                              It works as expected.
                              0 MCO:BGN:INIT GW,CP=RPNGA---,REL=255,VER=2.3.1
                              4 TSM:INIT
                              5 TSF:WUR:MS=0
                              6 RFM69:INIT
                              7 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                              11 RFM69:PTX:LEVEL=5 dBm
                              13 TSM:INIT:TSP OK
                              15 TSM:INIT:GW MODE
                              16 TSM:READY:ID=0,PAR=0,DIS=0
                              19 MCO:REG:NOT NEEDED
                              72 GWT:TIN:IP=192.168.50.211
                              1075 MCO:BGN:STP
                              1077 MCO:BGN:INIT OK,TSP=1
                              1081 TSM:READY:NWD REQ
                              1083 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
                              1088 RFM69:CSMA:RSSI=-98
                              1090 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                              If I try to change CS pin to any other with #define MY_RFM69_CS_PIN 4 for example, I always get:
                              4 TSM:INIT
                              5 TSF:WUR:MS=0
                              6 RFM69:INIT
                              7 RFM69:INIT:PIN,CS=4,IQP=2,IQN=0
                              13 TSM:INIT:TSP OK
                              14 TSM:INIT:GW MODE
                              So I revert the CS pin change and activate softspi and change irq #define MY_SOFTSPI and #define MY_RFM69_IRQ_PIN 3 And it works well:
                              4 TSM:INIT
                              5 TSF:WUR:MS=0
                              6 RFM69:INIT
                              7 RFM69:INIT:PIN,CS=10,IQP=3,IQN=1
                              13 TSM:INIT:TSP OK
                              15 TSM:INIT:GW MODE
                              1075 MCO:BGN:STP
                              1079 TSM:READY:NWD REQ
                              1081 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
                              1086 RFM69:CSMA:RSSI=-98
                              1091 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                              Then I add the eth module and I get:
                              4 TSM:INIT
                              5 TSF:WUR:MS=0
                              6 RFM69:INIT
                              13 TSM:INIT:TSP OK
                              15 TSM:INIT:GW MODE
                              And stays here forever.
                              Of course all those test are made using a double (5v+3v3) good power source, a level shifter... and changing the wires accordingly.
                              I have some questions:
                              • Its normal MY_RFM69_CS_PIN not having effect and breaking the radion connection?
                                Without being able to change this, I don't know if it's spi interference.
                              • In the last test, it seems to halt when initialising the network. Doesn't it?
                                Is there a way I can further know if the problem is with the eth module? I've tried it alone with the nano and it works.
                              I would thank guidance for debugging this.
