  3. ENC28J60 Ethernet gateway
14 Posts 5 Posters 2.2k Views 3 Watching
  • scalzS scalz
    @Sergio-Rius
    unfortunaly I can't help with your enc28j60 issue. and I'm not sure to have one for testing this.
    A while back, we checked w5100 module + arduino 328p. Eth module and radio were working on same hw spi bus but in docs it uses softspi, I don't remember why, perhaps for having a dedicated spibus for ethernet..
    I understand this is not very convenient to find the infos, when always more hw is supported.
    Just a note, as you are using a Nano for your tests, RFMs modules are not 5v tolerant in theory, even if they seem to handle it, datasheet says 3.9v for max. good to know. but maybe you're already using a level converter.
    Sergio RiusS
    Sergio RiusS
    Sergio Rius
    @scalz Thanks for your help. Unfortunately I can't get a w5100 in my country and would order it outside. I had those rfms for years and I want to test range before buying a sensebender.
    And I'm convinced to stop using the wifi for a gw.
    I had hope that any used had the same hw already running.
    • K kimot
      ENC28J60 for a stable gateway is not a good idea.
      Buy some Wiznet...
      C
      C
      cabat
      @kimot I am use one Ethernet gateway about 2 year - work good and stable.
      • C cabat
        Sergio RiusS
        Sergio RiusS
        Sergio Rius
        @cabat Could you please share you pinout for radio and module, and the sketch configuration?
        I can't make it work and I don't know if it's a matter of connections or something to activate, like softspi.
        C 1 Reply Last reply
        • Sergio RiusS Sergio Rius
          C
          C
          cabat
          wrote on last edited by cabat
          @sergio-rius Pinout as described here Building an Ethernet Gateway, i am use module like this:
          and my sketch on 20-Feb-2019 is:
          #define MY_BAUD_RATE 9600
          //#define MY_RF24_PA_LEVEL RF24_PA_MIN
          #undef MY_REGISTRATION_FEATURE
          #undef MY_CORE_COMPATIBILITY_CHECK
          // When ENC28J60 is connected we have to move CE/CSN pins for NRF radio
          #define MY_RF24_CE_PIN 5
          #define MY_RF24_CS_PIN 6
          #define MY_GATEWAY_ENC28J60
          // Gateway IP address
          #define MY_IP_ADDRESS 192,168,1,235
          #define MY_PORT 5003
          // Flash leds on rx/tx/err
          //#define MY_LEDS_BLINKING_FEATURE
          // Set blinking period
          // Enable inclusion mode
          //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
          #include <UIPEthernet.h>
          • nagelcN
            nagelcN
            nagelc
            wrote on last edited by nagelc
            @scalz said in ENC28J60 Ethernet gateway:
            It may have been fixed by now, but originally the W5100 did not release the SPI bus properly. So, it needed a separate SPI bus from the radio.
            I think this was fixed in the W5200 and W5500.
              @nagelc
              exactly, you're right! Better memory than me :) I remember now, I had to hack w5100 lib for spi transactions to make it working on same bus. So I don't know if it has been fixed.. I hope so.
              • nagelcN nagelc
                Sergio RiusS
                Sergio RiusS
                Sergio Rius
                @nagelc said in ENC28J60 Ethernet gateway:
                Noooooo..... Just ordered a W5100 :sob:
                @cabat It may not do for me. I'm trying to use rfm69 now. I could not leave my existing network down and brought the nrfs back to where they belonged.
                Also the eth module I have here is the shield for nano one. As it stacks below the nano, it may be that is interfering more pins than I expected.
                What I would want to know is that the rfm69 needs a different pinout with this shield or not. I can't find any reference that tells me this, so I can start debugging the problem.
                  C
                  C
                  cabat
                  @sergio-rius sorry, my mistake, missed of using RFM69 in your setup..
                  • C cabat
                    Sergio RiusS
                    Sergio RiusS
                    Sergio Rius
                    @cabat Oh, no! Thanks for your help. It has inspired me. Now I'm trying something more.
                    • Sergio RiusS
                      Sergio RiusS
                      Sergio Rius
                      I've been fiddling with the radio alone (serial gw), softspi and changing pins, and I think there's something else here.
                      Well those are my findings:
                      With this base definition and without the module wired:
                      #define MY_RADIO_RFM69
                      #define MY_RFM69_NEW_DRIVER
                      #define MY_IS_RFM69HW
                      #define MY_DEBUG_VERBOSE_RFM69
                      It works as expected.
                      0 MCO:BGN:INIT GW,CP=RPNGA---,REL=255,VER=2.3.1
                      4 TSM:INIT
                      5 TSF:WUR:MS=0
                      6 RFM69:INIT
                      7 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                      11 RFM69:PTX:LEVEL=5 dBm
                      13 TSM:INIT:TSP OK
                      15 TSM:INIT:GW MODE
                      16 TSM:READY:ID=0,PAR=0,DIS=0
                      19 MCO:REG:NOT NEEDED
                      72 GWT:TIN:IP=192.168.50.211
                      1075 MCO:BGN:STP
                      1077 MCO:BGN:INIT OK,TSP=1
                      1081 TSM:READY:NWD REQ
                      1083 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
                      1088 RFM69:CSMA:RSSI=-98
                      1090 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                      If I try to change CS pin to any other with #define MY_RFM69_CS_PIN 4 for example, I always get:
                      4 TSM:INIT
                      5 TSF:WUR:MS=0
                      6 RFM69:INIT
                      7 RFM69:INIT:PIN,CS=4,IQP=2,IQN=0
                      13 TSM:INIT:TSP OK
                      14 TSM:INIT:GW MODE
                      So I revert the CS pin change and activate softspi and change irq #define MY_SOFTSPI and #define MY_RFM69_IRQ_PIN 3 And it works well:
                      4 TSM:INIT
                      5 TSF:WUR:MS=0
                      6 RFM69:INIT
                      7 RFM69:INIT:PIN,CS=10,IQP=3,IQN=1
                      13 TSM:INIT:TSP OK
                      15 TSM:INIT:GW MODE
                      1075 MCO:BGN:STP
                      1079 TSM:READY:NWD REQ
                      1081 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
                      1086 RFM69:CSMA:RSSI=-98
                      1091 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                      Then I add the eth module and I get:
                      4 TSM:INIT
                      5 TSF:WUR:MS=0
                      6 RFM69:INIT
                      13 TSM:INIT:TSP OK
                      15 TSM:INIT:GW MODE
                      And stays here forever.
                      Of course all those test are made using a double (5v+3v3) good power source, a level shifter... and changing the wires accordingly.
                      I have some questions:
                      • Its normal MY_RFM69_CS_PIN not having effect and breaking the radion connection?
                        Without being able to change this, I don't know if it's spi interference.
                      • In the last test, it seems to halt when initialising the network. Doesn't it?
                        Is there a way I can further know if the problem is with the eth module? I've tried it alone with the nano and it works.
                      I would thank guidance for debugging this.
