  3. MySensors external examples (Zip file contains No valid library)
3 Posts 3 Posters 577 Views 3 Watching
  • HJ_SKH
    HJ_SKH
    HJ_SK
    This example uses a modified version of the external DHT library, which is included in the MySensors external examples. Please install it and restart the Arduino IDE before trying to compile.
    I did the download from the github link. After add ZIP library I get the "Zip file contains No valid library" message. Has there been some changes?
    Thanks in advantage for your reply!
    • HJ_SKH HJ_SK
      @hj_sk according to https://github.com/mysensors/MySensorsArduinoExamples/tree/master/libraries/DHT there have been no changes the last 3 years. Could you describe what you did?
      • urbanusU
        urbanusU
        urbanus
        Hi, I have the same issue. Using 1.8.2. Downloaded the zip file. Tried to include it from the Arduino drop down but get the same message as above. If I manually open the xip file al the files seem to be there.
