  3. The rules made in the controller saved on the gateway?
3 Posts 3 Posters 462 Views 3 Watching
  • T
    tjog
    I just trying to understand how everything works. So i set rules to my esp8266wifi gateway through the web interface controller of my choice.
    But after that, if i loose power to the computer with the controller running, what happens to all the rules, are they stored on the gateway?
    What i try to understand if i can set up the nodes+gateway and then remove the computer from the equation?
    mfalkviddM F 2 Replies Last reply
    • T tjog
      @tjog the gateway does not remember anything, regardless if you have a controller or not.
      Nodes can be programmed to remember their state. The example with rotary encoder at https://www.mysensors.org/build/dimmer does that if you want something to base your sketch on. Note that the first example on that page does not store state; it relies on a controller instead.
      Not sure what you mean by rules, but if you enter rules in your controller they will most likely depend on the controller being available.
      • T tjog
        F
        F
        Fleurros
        Banned
        This post is deleted!
