  3. Home Assistant
  4. Raspberry Pi gateway + hass.io + MQTT + MySensors
38 Posts 4 Posters 4.5k Views 5 Watching
  • SebexS Sebex
    @monte ok it seems to work. Temp/humidity sensor is recognised by HA and data is getting through so looks good! Only connection isnt stable which is most likely due to that I still need to get capacitors for the NRF24L01+ on both ends, and need to solder the cables to the sensor. So still some tweaks to do but happy that it works, thanks for the support @monte :grinning:
    Two general questions, any advice for which capacitor to select? Apart from 4.7 or 47uF, there's different types. Tanto, elco, bipolaire etc.
    Furthermore I wondered why the 64bit hassio software didn't work on my Arduino, while it is a 64bit RPi 3+. Does Raspbian (or dockers?) as default run in 32?
    monteM
    monteM
    monte
    wrote on last edited by monte
    #21
    @sebex 4.7uF should be enough, I've never seen any problem with this value on my nodes. As for the type of the capacitor you probably will want to use ceramic or electrolytic (polarized) capacitor, but it doesn't do much difference for this application, if any. Those are just the most common types. Ceramic SMD capacitor of a size 0805 is the best choice IMO because it could be soldered directly to the VCC and GND pins on top of NRF24 module.
    You can google about why raspbian is running like RPi is 32 bits, but as I understood it's better for downward compatibility and the fact that RPi3 won't get much boost (if any) from switching to 64 bit architecture.
    SebexS 1 Reply Last reply
    • monteM monte
      SebexS
      SebexS
      Sebex
      @monte ah smart makes sense and probably looks most neat as well. Thanks!
      • SebexS
        SebexS
        Sebex
        Ok so I am experiencing node loss. After a while my sensor node is not recognized anymore by the gateway/mothernode. It seems to be related to the persistence file that is not accessible although the user account should have the correct rights, not sure how to verify. See HA dev logs below.
        Developer Tools
        Permission denied when writing to /config/home/pi/.homeassistant/mysensors.json
        10:13 PM /usr/local/lib/python3.7/site-packages/mysensors/persistence.py (ERROR) - message first occurred at 10:06 PM and shows up 42 times
        Node 1 is unknown
        10:11 PM __main__.py (WARNING) - message first occurred at 10:06 PM and shows up 116 times
        Failed to load sensors from file: home/pi/.homeassistant/mysensors.json
        10:06 PM /usr/local/lib/python3.7/site-packages/mysensors/persistence.py (WARNING)
        File does not exist or is not readable: home/pi/.homeassistant/mysensors.json.bak
        Trying backup file: home/pi/.homeassistant/mysensors.json.bak
        10:06 PM /usr/local/lib/python3.7/site-packages/mysensors/persistence.py (WARNING)```
        # MySensors gateway
        mysensors:
         gateways:
          - device: '192.168.178.27'
            persistence_file: 'home/pi/.homeassistant/mysensors.json'
            tcp_port: 5003
         persistence: true
        logger:
          default: info
          logs:
            homeassistant.components.mysensors: debug
            mysensors: debug
        @drock1985 saw your post in another thread related to this, do you have a suggestion?
        monteM 1 Reply Last reply
        • SebexS Sebex
          Developer Tools
          Node 1 is unknown
          # MySensors gateway
          mysensors:
           gateways:
              tcp_port: 5003
           persistence: true
          logger:
            default: info
            logs:
              mysensors: debug
          monteM
          monteM
          monte
          #24
          @Sebex you are using Hassio, so there is no /home/pi folder. Try persistence_file: 'mysensors.json'
          • monteM monte
            SebexS
            SebexS
            Sebex
            @monte seems to do the trick :grin: thanks again!!
            • SebexS
              SebexS
              Sebex
              @monte, I'm seeing that a HA update is available. Since I'm using HA via docker the following applies to update.
              $ sudo docker pull homeassistant/home-assistant:latest
              To be on the safe side I'd like to backup my HA and/or RPi first to prevent me from losing all my settings. In your experience what's the most convenient for doing this. I did make a clone from the sd card a few weeks ago but it's not the most labour efficient method, do you make regular backups?
              • SebexS Sebex
                monteM
                monteM
                monte
                @Sebex if you installed Hassio with provided script then you can find your Home Assistant config folder in /usr/share/hassio. You can also change this path to your liking in /etc/hassio.json config file.
                To backup all of your HA settings and setups you need to just copy this folder. That's why I like idea of using Docker. You can lose all your RPi setup, but if you fave backed up your config folder it only matter of half an hour to recover everything from scratch.
                • monteM monte
                  SebexS
                  SebexS
                  Sebex
                  @monte can you copy this over ssh? tried using scp -r, which seemed to work but can't find the downloaded files somehow.
                  And in regard of updating HA(within UI I see that and update is available). I can just stop the container and run a new updated version right, without it affecting config files?
                  Furthermore I wondered about HA speed, if I want to look at the history of a sensors it takes quite a while to poll the data and create a graph. Is this subsequent to HA/rpi or can the performance be improved somehow?
                  • SebexS Sebex
                    monteM
                    monteM
                    monte
                    @Sebex yes, you can copy config over ssh, like every other directory you have access to. It should be located from where you were running scp command. Do you use linux on your desktop/laptop?
                    You can also create samba share on your raspberry with location of your config folder, and then access it from any pc on the network, it makes easy to config your HA.
                    Yes you can pull newer version of a container and all your config files should be in place.
                    Can't help you with UI speed, sorry. You can try to find anything on HA forum, maybe there is someone who made some performance tests.
                    • monteM monte
                      SebexS
                      SebexS
                      Sebex
                      wrote on last edited by Sebex
                      #30
                      @monte thanks it worked using Samba. I use ssh from my mac. I also found the copied folder that I tried to copy with scp :laughing:
                      I tried pulling a new version but that didn't seem to work so easily. It seems to get stuck on initialising after which it shuts down and tries again. The logs show the error below, it's missing a file/directory. Not sure how to solve this.
                      2020/01/23 17:13:08 [error] 7#7: *1 open() "/usr/share/www/api/websocket" failed (2: No such file or directory), client: ::ffff:192.168.178.16, server: , request: "GET /api/websocket HTTP/1.1", host: "192.168.178.27:8123"
                      2020/01/23 17:13:15 [error] 7#7: *3 open() "/usr/share/www/api/websocket" failed (2: No such file or directory), client: ::ffff:192.168.178.16, server: , request: "GET /api/websocket HTTP/1.1", host: "192.168.178.27:8123"
                      2020/01/23 17:13:21 [error] 7#7: *4 open() "/usr/share/www/api/websocket" failed (2: No such file or directory), client: ::ffff:192.168.178.16, server: , request: "GET /api/websocket HTTP/1.1", host: "192.168.178.27:8123"
                      What I did to update the container is stop all running containers, and remove images, and re-execute the cmd for homeassistant again. Was this the way to go?
                      Also is there a way to copy the RPi settings? I quite often get a broken pipe and not sure what's causing it. I am thinking about reflashing the SD and reinstating the settings.
                      • SebexS Sebex
                        monteM
                        monteM
                        monte
                        @Sebex the best way to backup your Raspbian setup is to copy whole SD card to image file, apparently you can use mac's Disk Utility to do this.
                        I'm not sure how home assistant supervisor pulls and runs docker container, but it seems that it have some trouble. You can run setup script once again, maybe it will help.
                        For future, you should update via web ui. I've read that hassio images are updated later than standalone home assistant once. So you won't get update right away, when new version of HA is released. But when new version of hassio is released it will suggest you to update in Hass.io dashboard.
                        • SebexS
                          SebexS
                          Sebex
                          @monte I had tried that one before, but know that it's useful to restore the file doesn't seem to work and I get an error. Perhaps bad luck, will have to try again.
                          In the meantime while reinstating HA I'm facing quite some difficulties in getting HA to install within docker via link. I'm facing a broken pipe quite often and have no idea how to fix this, tried different ssh settings but when installing HA it seems to get stuck at
                          pi@raspberrypi:~ $ sudo su
                          root@raspberrypi:/home/pi# curl -sL https://raw.githubusercontent.com/home-assistant/hassio-installer/master/hassio_install.sh | bash -s -- -m raspberrypi3
                          [Warning] No NetworkManager support on host.
                          [Info] Install supervisor Docker container
                          packet_write_wait: Connection to fe80::233b:33dc:8d3e:eb75%en0 port 22: Broken pipe
                          Yesterday it did pass but then hassio had troubles successfully launching. It got the below error in the logs, not sure what caused it.
                          error /usr/share/www/manifest.json
                          Now trying to install hassio again, any suggestions are welcome. I'm going to try a different SD card and wifi connection instead of ethernet.
                          • SebexS Sebex
                            monteM
                            monteM
                            monte
                            #33
                            @Sebex you could try connecting a monitor and keyboard directly to RPi and running install script. Broken pipe means something is braking connection to ssh host. I can't really say what it is for sure, maybe just excessive CPU usage, or running out of ram? But that would be strange.
                            If you have backed up you HA setup, why not just flash clean Raspbian image and run install script on it. If it worked before, I don't see why it wouldn't work again.
                            And that piece of output you wrote, suggests you are using IPv6 for ssh connection. Is there any reason for this?
                            • SebexS
                              SebexS
                              Sebex
                              @monte good idea I'll try that.
                              Regarding IPv6, there's no particular reason and I haven't noticed actually. I have been using ssh pi@raspberrypi.local to login, I can also connect directly to the IPv4 address. You think that can resolve it?
                              • SebexS Sebex
                                monteM
                                monteM
                                monte
                                #35
                                @Sebex okay, I've googled for you, there are plenty reportings of similar issues. It may be caused by insufficient power supply. On intense CPU usage it may lack current. Try getting better power supply rated at 2.5A, 5V.
                                • monteM monte
                                  SebexS
                                  SebexS
                                  Sebex
                                  @monte man you're 100% right. Now that I have connected external screen/keyboard, it actually reports the low voltage quite regularly in cmd line... I've ordered one and should solve the issue :grin:
                                  • SebexS
                                    SebexS
                                    Sebex
                                    This post is deleted!
                                    • SebexS
                                      SebexS
                                      Sebex
                                      Here I am again, I had a second node running and tried to make it battery powered but it doesn't seem to work on battery only. Anyway along the process of finding out what the problem is I encountered two other problems:
                                      • I'm getting a ERROR accept: Bad file descriptor in mysgw, only 1 instance seems to be running though:
                                      Any suggestions on this?
                                        PID TTY      STAT   TIME COMMAND
                                          1 ?        Ss     0:05 /sbin/init
                                          2 ?        S      0:00 [kthreadd]
                                          3 ?        I<     0:00 [rcu_gp]
                                          4 ?        I<     0:00 [rcu_par_gp]
                                          8 ?        I<     0:00 [mm_percpu_wq]
                                          9 ?        S      0:00 [ksoftirqd/0]
                                         10 ?        I      0:05 [rcu_sched]
                                         11 ?        I      0:00 [rcu_bh]
                                         12 ?        S      0:00 [migration/0]
                                         13 ?        S      0:00 [cpuhp/0]
                                         14 ?        S      0:00 [cpuhp/1]
                                         15 ?        S      0:00 [migration/1]
                                         16 ?        S      0:00 [ksoftirqd/1]
                                         17 ?        I      0:00 [kworker/1:0-mm_percpu_wq]
                                         19 ?        S      0:00 [cpuhp/2]
                                         20 ?        S      0:00 [migration/2]
                                         21 ?        S      0:00 [ksoftirqd/2]
                                         23 ?        I<     0:00 [kworker/2:0H-kblockd]
                                         24 ?        S      0:00 [cpuhp/3]
                                         25 ?        S      0:00 [migration/3]
                                         26 ?        S      0:00 [ksoftirqd/3]
                                         29 ?        S      0:00 [kdevtmpfs]
                                         30 ?        I<     0:00 [netns]
                                         33 ?        I      0:00 [kworker/2:1-mm_percpu_wq]
                                         34 ?        S      0:00 [khungtaskd]
                                         35 ?        S      0:00 [oom_reaper]
                                         36 ?        I<     0:00 [writeback]
                                         37 ?        S      0:00 [kcompactd0]
                                         38 ?        I<     0:00 [crypto]
                                         39 ?        I<     0:00 [kblockd]
                                         40 ?        S      0:00 [watchdogd]
                                         42 ?        I<     0:00 [rpciod]
                                         43 ?        I<     0:00 [kworker/u9:0-hci0]
                                         44 ?        I<     0:00 [xprtiod]
                                         47 ?        S      0:00 [kswapd0]
                                         48 ?        I<     0:00 [nfsiod]
                                         59 ?        I<     0:00 [kthrotld]
                                         60 ?        I<     0:00 [iscsi_eh]
                                         61 ?        I<     0:00 [dwc_otg]
                                         62 ?        I<     0:00 [DWC Notificatio]
                                         63 ?        S<     0:04 [vchiq-slot/0]
                                         64 ?        S<     0:01 [vchiq-recy/0]
                                         65 ?        S<     0:00 [vchiq-sync/0]
                                         66 ?        S      0:00 [vchiq-keep/0]
                                         67 ?        S<     0:00 [SMIO]
                                         69 ?        S      0:00 [irq/86-mmc1]
                                         71 ?        I<     0:00 [mmc_complete]
                                         74 ?        I<     0:01 [kworker/0:1H-mmc_complete]
                                         75 ?        I<     0:00 [kworker/1:1H-kblockd]
                                         76 ?        S      0:00 [jbd2/mmcblk0p2-]
                                         77 ?        I<     0:00 [ext4-rsv-conver]
                                         79 ?        I<     0:00 [ipv6_addrconf]
                                         96 ?        I<     0:00 [kworker/3:2H-kblockd]
                                        101 ?        S      0:00 [irq/166-usb-001]
                                        114 ?        Ss     0:01 /lib/systemd/systemd-journald
                                        144 ?        Ss     0:01 /lib/systemd/systemd-udevd
                                        159 ?        S<     0:00 [SMIO]
                                        181 ?        I<     0:00 [mmal-vchiq]
                                        183 ?        I<     0:00 [mmal-vchiq]
                                        185 ?        I<     0:00 [mmal-vchiq]
                                        198 ?        I<     0:00 [cfg80211]
                                        202 ?        I<     0:00 [brcmf_wq/mmc1:0]
                                        203 ?        S      0:00 [brcmf_wdog/mmc1]
                                        247 ?        Ssl    0:00 /lib/systemd/systemd-timesyncd
                                        290 ?        Ss     0:55 /usr/local/bin/mysgw -q
                                        295 ?        Ss     0:00 /usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --socket /run/thd.socket --user nobody --deviceglob /dev/input/ev
                                        297 ?        Ss     0:00 /usr/sbin/cron -f
                                        298 ?        Ss     0:01 avahi-daemon: running [raspberrypi.local]
                                        299 ?        Ss     0:01 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
                                        303 ?        Ssl    0:00 /usr/sbin/rsyslogd -n -iNONE
                                        311 ?        Ss     0:00 /lib/systemd/systemd-logind
                                        315 ?        SNs    0:00 /usr/sbin/alsactl -E HOME=/run/alsa -s -n 19 -c rdaemon
                                        319 ?        Ss     0:00 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
                                        344 ?        SLsl   0:00 /usr/sbin/rngd -r /dev/hwrng
                                        356 ?        S      0:00 avahi-daemon: chroot helper
                                        395 ?        I      0:00 [kworker/2:3-mm_percpu_wq]
                                        456 ?        Ss     0:00 /sbin/dhcpcd -q -w
                                        461 ?        Ss     0:01 /usr/sbin/nmbd --foreground --no-process-group
                                        463 ?        Ssl    0:00 /usr/bin/python3 /usr/share/unattended-upgrades/unattended-upgrade-shutdown --wait-for-signal
                                        466 ?        Ssl    0:02 /usr/bin/containerd
                                        467 ?        Ssl    0:11 /usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock
                                        468 tty1     Ss+    0:00 /sbin/agetty -o -p -- \u --noclear tty1 linux
                                        469 ?        Ss     0:00 /usr/sbin/sshd -D
                                        479 ?        S      0:00 /usr/bin/hciattach /dev/serial1 bcm43xx 3000000 flow - b8:27:eb:d7:7e:1b
                                        481 ?        I<     0:00 [kworker/u9:2-hci0]
                                        483 ?        Ss     0:00 /usr/lib/bluetooth/bluetoothd
                                        489 ?        Ss     0:00 sshd: pi [priv]
                                        511 ?        Ss     0:01 /lib/systemd/systemd --user
                                        514 ?        S      0:00 (sd-pam)
                                        525 ?        Ss     0:00 /usr/sbin/smbd --foreground --no-process-group
                                        536 ?        R      0:03 sshd: pi@pts/0
                                        539 pts/0    Ss     0:01 -bash
                                        542 ?        S      0:00 /usr/sbin/smbd --foreground --no-process-group
                                        543 ?        S      0:00 /usr/sbin/smbd --foreground --no-process-group
                                        552 ?        S      0:00 /usr/sbin/smbd --foreground --no-process-group
                                        794 ?        Ss     0:00 /bin/sh /usr/sbin/hassio-supervisor
                                        821 ?        Sl     0:01 docker start --attach hassio_supervisor
                                        873 ?        Sl     0:00 containerd-shim -namespace moby -workdir /var/lib/containerd/io.containerd.runtime.v1.linux/moby/af8bfda572398f9806ba54d
                                        890 ?        Ss     0:00 s6-svscan -t0 /var/run/s6/services
                                       1045 ?        S      0:00 s6-supervise s6-fdholderd
                                       1192 ?        Ss     0:00 udevd --daemon
                                       1267 ?        S      0:00 s6-supervise supervisor
                                       1271 ?        Ssl    0:17 python3 -m supervisor
                                       1354 ?        S      0:00 socat UDP-RECVFROM:53,fork UDP-SENDTO:172.30.32.3:53
                                       1398 ?        Sl     0:00 containerd-shim -namespace moby -workdir /var/lib/containerd/io.containerd.runtime.v1.linux/moby/21403e3385d0ce05418df7e
                                       1409 ?        Sl     0:00 containerd-shim -namespace moby -workdir /var/lib/containerd/io.containerd.runtime.v1.linux/moby/2b6193b6744b35b8d848671
                                       1433 ?        Ssl    0:01 coredns -conf /config/corefile
                                       1437 ?        Ss     0:00 s6-svscan -t0 /var/run/s6/services
                                       1625 ?        S      0:00 s6-supervise s6-fdholderd
                                       1919 ?        Ss     0:00 udevd --daemon
                                       1951 ?        S      0:00 s6-supervise bridge
                                       1952 ?        S      0:00 s6-supervise pulseaudio
                                       1955 ?        Ss     0:00 socat UNIX-LISTEN:/data/external/pulse.sock,fork,unlink-early,mode=777 UNIX-CONNECT:/data/internal/pulse.sock
                                       1956 ?        S<sl   0:05 pulseaudio --system -vvv
                                       2004 ?        Sl     0:00 containerd-shim -namespace moby -workdir /var/lib/containerd/io.containerd.runtime.v1.linux/moby/00ef0f54f7a780be3af62a1
                                       2019 ?        Ssl    2:07 /usr/local/bin/python3 -m homeassistant --config /config
                                       2036 ?        Ss     0:01 udevd --daemon
                                       2353 ?        Sl     0:00 containerd-shim -namespace moby -workdir /var/lib/containerd/io.containerd.runtime.v1.linux/moby/9ca754987ee52a3a48c5290
                                       2369 ?        Ss     0:00 /sbin/docker-init -- /init /run.sh
                                       2462 ?        S      0:00 s6-svscan -t0 /var/run/s6/services
                                       2487 ?        S      0:00 foreground  if   /etc/s6/init/init-stage2-redirfd   foreground    if     if      s6-echo      -n      --      [s6-init]
                                       2488 ?        S      0:00 s6-supervise s6-fdholderd
                                       2499 ?        S      0:00 foreground  s6-setsid  -gq  --  with-contenv  backtick  -D  0  -n  S6_LOGGING   printcontenv   S6_LOGGING    importas  S
                                       2632 ?        S      0:02 /usr/local/bin/python /usr/local/bin/hass-configurator /etc/configurator.conf
                                       2677 ?        S      0:02 /usr/sbin/smbd --foreground --no-process-group
                                       2837 ?        I<     0:00 [kworker/1:2H]
                                       2854 pts/0    T      0:00 sudo nano mysensors.conf
                                       2859 pts/0    T      0:00 nano mysensors.conf
                                       2903 ?        I      0:00 [kworker/u8:2-events_unbound]
                                       2937 ?        I<     0:00 [kworker/3:0H]
                                       2939 ?        I      0:00 [kworker/3:2-mm_percpu_wq]
                                       2968 ?        I      0:00 [kworker/1:2-events]
                                       3008 ?        I      0:00 [kworker/u8:0-events_unbound]
                                       3021 ?        I<     0:00 [kworker/0:2H]
                                       3022 ?        I      0:00 [kworker/0:0-events]
                                       3036 ?        I      0:00 [kworker/3:0-events]
                                       3037 ?        I<     0:00 [kworker/2:2H]
                                       3043 ?        I      0:00 [kworker/0:1-events_power_efficient]
                                       3068 ?        I      0:00 [kworker/u8:1-events_unbound]
                                       3070 ?        I      0:00 [kworker/2:0-mm_percpu_wq]
                                       3071 ?        I<     0:00 [kworker/3:1H-kblockd]
                                       3074 ?        I<     0:00 [kworker/0:0H]
                                       3075 ?        I      0:00 [kworker/3:1-events]
                                       3076 pts/0    R+     0:00 ps -ax
