  3. Radio compatibility question
5 Posts 3 Posters 562 Views 2 Watching
  • garfiusG
    garfiusG
    garfius
    First of all, thanks 4 the great work!
    Now, have got a few:
    sx1278(ai thinker RA-02)-433
    sx1276-868
    RFM95W <-- explicitly supported, yeah! like! :heart_eyes:
    RFM98W
    And i wonder wether this hardware is fully supported, and wether i can change the default frequencies (868 || 433) to other hardware supported frequencies (RA-02 suppports 410Mhz to 525Mhz). :ghost:
    Thanks 4 the answers in advance. :hand_with_index_and_middle_fingers_crossed:
    skywatchS 1 Reply Last reply
    • garfiusG garfius
      sx1276-868
      RFM98W
      skywatchS
      skywatchS
      skywatch
      @garfius According to this page.... https://www.mysensors.org/about/components#the-radio the only supported devices are listed as nrf24l01+, rfm69 and esp8266.
      I guess if you are talented in programming you could add your own support for the items you listed and maybe share your success so that other can benefit too....
      I can see no reason you cannot 'change the default frequencies' so long as the protocols stay intact and all nodes talking to the gw are on the same frequency.
      garfiusG 1 Reply Last reply
      • skywatchS skywatch
        garfiusG
        garfiusG
        garfius
        @skywatch Correct!
        But according to:
        https://lowpowerlab.com/forum/rf-range-antennas-rfm69-library/rfm69-hoperf-are-they-semtech-clones-or-not/
        And other sources, HopeRF RFM9X are chinese clones of the original semtech sx127X, and these things works using same LoRa.h library from sandeep. So, i guess are practically identical.
        Also, i checked MySensors.h compiler definitions, where can be seen 868 and 433 freq are allowed.
        So, these radios maybe works...¿!?¿! :face_with_rolling_eyes:
        • nagelcN
          nagelcN
          nagelc
          I use the RA-01 with MySensors RFM95 drivers. Works just fine.
          I have not tried to change the frequency though. I have only used 433Mhz.
          • nagelcN nagelc
            garfiusG
            garfiusG
            garfius
            @nagelc Thaaaanks!
            Your answer is valuable to anyone.
