  3. Works perfectly untill i introduce sleep
4 Posts 3 Posters 477 Views 3 Watching
  • markjgabbM
    markjgabbM
    markjgabb
    Hi all
    thanks for all previous help with this node, im only 1 step away now from getting it to work
    the sketch works perfectly untill i introduce the sleep till interupt.....
    as soon i uncomment the line for sleep the node starts up then goes to sleep and never wakes up again... and advice is appreciated
    LOG
     __  __       ____
            |___/                      2.3.1
    16 MCO:BGN:INIT NODE,CP=RNNNA---,REL=255,VER=2.3.1
    28 TSM:INIT
    28 TSF:WUR:MS=0
    34 TSM:INIT:TSP OK
    36 TSF:SID:OK,ID=4
    38 TSM:FPAR
    75 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    110 TSF:MSG:READ,1-1-4,s=255,c=3,t=8,pt=1,l=1,sg=0:1
    116 TSF:MSG:FPAR OK,ID=1,D=2
    2084 TSM:FPAR:OK
    2084 TSM:ID
    2086 TSM:ID:OK
    2088 TSM:UPL
    2093 TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2127 TSF:MSG:READ,0-1-4,s=255,c=3,t=25,pt=1,l=1,sg=0:2
    2134 TSF:MSG:PONG RECV,HP=2
    2138 TSM:UPL:OK
    2138 TSM:READY:ID=4,PAR=1,DIS=2
    2144 TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2170 TSF:MSG:READ,0-1-4,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2201 TSF:MSG:SEND,4-4-1-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.1
    2226 TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:1
    2260 TSF:MSG:READ,0-1-4,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    2299 TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=OK:Lounge Multi
    2326 TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:3.0
    2435 TSF:MSG:SEND,4-4-1-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    2443 MCO:REG:REQ
    2449 TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    2478 TSF:MSG:READ,0-1-4,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    2484 MCO:PIM:NODE REG=1
    2486 MCO:BGN:STP
    2488 MCO:BGN:INIT OK,TSP=1
    2496 TSF:MSG:SEND,4-4-1-0,s=1,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
    2504 MCO:SLP:MS=0,SMS=0,I1=3,M1=1,I2=255,M2=255
    2508 TSF:TDI:TSL
    Code:
    #define MY_RADIO_RF24
    #include <Bounce2.h>
    #define CHILD_ID 1
    #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    Bounce debouncer = Bounce();
    int oldValue=-1;
    MyMessage msg(CHILD_ID,V_LIGHT);
    // BATTERY VOLTAGE DIVIDER SETUP
    #define VBAT_PER_BITS 0.003363075
    #define VMIN 1.9                                  //  Vmin (radio Min Volt)=1.9V (564v)
    #define VMAX 3.0                                  //  Vmax = (2xAA bat)=3.0V (892v)
    int batteryPcnt = 0;                              // Calc value for battery %
    int batLoop = 0;                                  // Loop to help calc average
    int batArray[3];                                  // Array to store value for average calc.
    int BATTERY_SENSE_PIN = A0;                       // select the input pin for the battery sense point
      // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
    void presentation() {
      sendSketchInfo("Lounge Multi", "3.0");
      wait(100);
      present(CHILD_ID, S_LIGHT);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         send(msg.set(value==HIGH ? 1 : 0));
         oldValue = value;
    //  batM();
    sleep(BUTTON_PIN, CHANGE, 0);
     void batM() //The battery calculations
       delay(500);
       // Battery monitoring reading
       delay(500);
       // Calculate the battery in %
       float Vbat  = sensorValue * VBAT_PER_BITS;
       int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
       Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
       // Add it to array so we get an average of 3 (3x20min)
       batArray[batLoop] = batteryPcnt;
       if (batLoop > 2) {
         batteryPcnt = (batArray[0] + batArray[1] + batArray[2] + batArray[3]);
         batteryPcnt = batteryPcnt / 3;
       if (batteryPcnt > 100) {
         batteryPcnt=100;
         Serial.print("Battery Average (Send): "); Serial.print(batteryPcnt); Serial.println(" %");
           batLoop = 0;
         else
         batLoop++;
    • markjgabbM
      markjgabbM
      markjgabb
      wrote on last edited by markjgabb
      additional note my button is connected between GND and D3 with 470k resistor in the middle
      skywatchS 1 Reply Last reply
      • BearWithBeardB
        BearWithBeardB
        BearWithBeard
        Hi markjgabb,
        Assuming you use an Arduino, you can use two external interrupts (INT0 and INT1) on pins D2 and D3. But the sleep function requires the external interrupt vector, not the Arduino pin number. When you give it BUTTON_PIN (3), nothing will happen, since only INT0 (0) and INT1 (1) are valid external interrupts on ATmega328P-based Arduinos.
        Instead, you could write sleep(1, CHANGE, 0), or preferably sleep(digitalPinToInterrupt(BUTTON_PIN), CHANGE, 0), which maps the pin number to the interrupt vector (or NOT_AN_INTERRUPT (-1) if invalid), if you want to wake up from D3 (INT1). 0 would wake up from D2 (INT0).
        For more information, there's a good tutorial on interrupts by Nick Gammon. Also, chapters 12 "Interrupts" and 13 "External Interrupts" in the ATmega328 datasheet might be helpful.
        • markjgabbM markjgabb
          skywatchS
          skywatchS
          skywatch
          @markjgabb said in Works perfectly untill i introduce sleep:
          This will be an unstable way to detect a change as the input pin is 'floating' unless the button is connected when it then gets grounded via the resistor.
          What would be better is connect the resistor between the positive power of the arduino and the input pin (this is known as a pull-up resistor) and then add the switch from the input pin to ground.
          In this configuration the input pin is at all times in a known state, either it is 'high' when the button is not pressed or 'low' when the button is pressed. This will give a clear signal to the arduino.
