  3. Battery: pro mini @ 1mhz vs booster
30 Posts 7 Posters 4.3k Views 7 Watching
  • NeverDieN NeverDie
    A pair of lithium AA primaries is hard to beat because:
    1. Unlike alkaline's, they don't leak.
    2. Have a look at the discharge curve: https://data.energizer.com/pdfs/l91.pdf By the time they drop to 2.4v, if not before, you'll want to replace them.
    3. Obviously much longer life, both shelf life (20 years!) and energy capacity.
    I think running 8Mhz from the internal RC is a no-brainer: wake up time is less than 4us. So, if your node wakes up often, you'll save a ton of energy over time.
    The best time to take your battery measurement is immediately after a Tx. That will give you the most conservative reading. Save that measurement in a variable and then send it in your next transmission. Switch on your ADC just before Tx and take your first ADC measurement during Tx, because you have to throw out the first measurement anyway. That way you can take a fresh (and valid) ADC measurement just after Tx before the voltage rebounds.
    Hope that helps!
    K
    K
    kiesel
    @NeverDie
    Thanks for letting me know about voltage rebound. I'll reprogram my nodes to take a measurement after tx as you said!
    NeverDieN 1 Reply Last reply
    • sundberg84S sundberg84
      Interesting all this - noticed you mentioned EasyPCB and something written in there, let me know if this can be clearer! Also worth mentioning here is that the booster will affect the radio with noice - my choise would be easy today, run it without booster if I can unless you can prove its way more efficient (longer life) with the booster. Downside with this is that you have to learn how to reprogram fuses and bootloader - but its worth the hassle.
      I just recieved a new batch of boosters and its 50/50 if they are good enough to not interfere with the radio. (Yes, its the cheap chinese mini boosters).
      K
      K
      kiesel
      wrote on last edited by kiesel
      #22
      @sundberg84
      In the "battery without a booster "-section, what do you mean by risky? I took it to mean that the arduino potentially could reboot or fail. Apologies if that's now what you meant.
      I think I need to stick with a booster anyway, I am using a light sensor in most of my nodes and it needs 3v.
      But I'll reprogram the bootloader of one of my arduino. Just out of curiosity :)
      Do you disable just the bod or do you also switch the frequency to 8mhz?
      zboblamontZ sundberg84S 2 Replies Last reply
      • K kiesel
        @NeverDie
        NeverDieN
        NeverDieN
        @kiesel Yes, voltage drops steadily during transmission. I used to do continuous ADC measurements throughout the transmission and then take the lowest one. The lowest one was always the last one, so I think taking one measurement (the second one) immediately afterward should be good enough.
        • K kiesel
          @sundberg84
          zboblamontZ
          zboblamontZ
          zboblamont
          @kiesel "I think I need to stick with a booster anyway, I am using a light sensor in most of my nodes and it needs 3v." - Don't make the mistake restricting the solution for different voltage requirements to boosting only, they do create noise which can cause problems.
          eg - If you can switch the higher power only when needed (to reduce energy) and use a level converter to talk to the processor, you can use a separate battery source, or increase the principal supply to 3xAA tapping off 2AA for the processor, etc., if space permits...
          K 1 Reply Last reply
          • zboblamontZ zboblamont
            K
            K
            kiesel
            @zboblamont
            How do I know whether a booster introduces noise? I think so far I have been lucky with my three nodes because they work as expected. Or I don't know what to look for...
            zboblamontZ NeverDieN 2 Replies Last reply
            • K kiesel
              @sundberg84
              #26
              @kiesel i mean exactly what @NeverDie mentioned above (https://forum.mysensors.org/topic/10952/battery-pro-mini-1mhz-vs-booster/12?_=1582011000646). When voltage drops below 2.4v the 8mhz processor is "out of specs". I cant promise it works as it should, but just as neverdie I also have alot of nodes out of specs so unless you do crasy stuff and pulling much current it should work.
              About the noice questions, its very hard to diagnose or find unless you have a oscilloscope. What you might experience is bad reception and alot of :NACK messages.
              In most cases i reprogram the bootloader and use 8mhz internal or 1mhz interlan.
              YveauxY 1 Reply Last reply
                YveauxY
                YveauxY
                @sundberg84 said in Battery: pro mini @ 1mhz vs booster:
                You, dear @sundberg84, can call me Yveaux :joy:
                • YveauxY Yveaux
                  @Yveaux - truly sorry my friend :) All credits go to you!
                  • K kiesel
                    @zboblamont
                    zboblamontZ
                    zboblamontZ
                    zboblamont
                    wrote on last edited by zboblamont
                    #29
                    @kiesel Bluntly, you won't until it does not behave as expected....
                    Example - At one stage I had a second promini on 5v from a booster working the ultrasonic, all ok and signals passed on I2C to the Node via a level converter. When I tried using the ultrasonic direct off the booster, periodic results or nada. I finally figured out the VR on the pro-mini was attenuating the noise, tried various filters but none worked. I ultimately solved the problem using a separate 4xAA stack and a VR, no noise but bulky. But the trick was switching it on only when required, 4 years plus life was eminently possible...
                    As @sundberg84 commented, without a scope you are on a hope and a prayer as far as noise is concerned, that is why I suggest a secondary cell may be your solution if it does ;)
                    • K kiesel
                      @zboblamont
                      NeverDieN
                      NeverDieN
                      #30
                      @kiesel said in Battery: pro mini @ 1mhz vs booster:
                      @zboblamont
                      If you wanted to play it safe (aka defensive programming), you could use your booster to charge a capacitor that's large enough to provide interim power, turn off the booster prior to doing your radio communications, and then turn the booster on again when you're done with tx/rx. That would effectively remove your booster from the equation as an interference source.
                      Also, some boosters have a pass-through, so you can use your regular battery voltage for as long as it's high enough, and then when it no longer is, enable your booster, if that's what you want to do. Here's an example of one:
                      https://www.openhardware.io/view/285/33v-Boost-Converter-with-Pass-Through
                      For instance, CR2032's can have quite a voltage dip after volunteering some current, so this would be one way to keep wringing a useful voltage out of such a battery after its voltage may have temporarily dropped too low.
                      Some of the ARM MCU chips include boost converters that can boost from as little as 0.5v....
