  3. Home Assistant
  4. MQTT & MySensors persistant file
3 Posts 2 Posters 539 Views 2 Watching
    martim
    I have an existing mysensors network with many nodes. I would like to work with hassio (beginner). I have added mysensors and with the mqtt gateway. However, I see that the nodes need un update because of a special way sending the S_TYPE and V_TYPE. This would require a lot of work.
    Is there not a different way? Can I not specify all the nodes into the persistent file? Does someone have an example of this file?
    I do get now an error for example that node 17 is not recognized.
    Thanks and keep safe for the Coronavirus :(
    • electrikE
      electrikE
      electrik
      Here you are. I stripped many devices, if you need more let me know
          "4": {
              "sensor_id": 4,
              "children": {
                  "4": {
                      "id": 4,
                      "type": 4,
                      "description": "",
                      "values": {
                          "3": "71",
                          "2": "0"
                  "5": {
                      "id": 5,
                      "type": 4,
                      "description": "",
                      "values": {
                          "3": "71",
                          "2": "1"
                  "6": {
                      "id": 6,
                      "type": 4,
                      "description": "",
                      "values": {
                          "48": "927"
                  "3": {
                      "id": 3,
                      "type": 4,
                      "description": "",
                      "values": {
                          "3": "71",
                          "2": "0"
                  "15": {
                      "id": 15,
                      "type": 3,
                      "description": "",
                      "values": {
                          "2": "1"
              "type": 18,
              "sketch_name": "Dimmer bank",
              "sketch_version": "3.0",
              "battery_level": 0,
              "protocol_version": "2.4.0-alpha",
              "heartbeat": 0
      M 1 Reply Last reply
      • electrikE electrik
            "4": {
                "sensor_id": 4,
                "children": {
                    "4": {
                        "id": 4,
                        "type": 4,
                        "description": "",
                        "values": {
                            "3": "71",
                            "2": "0"
                    "5": {
                        "id": 5,
                        "type": 4,
                        "description": "",
                        "values": {
                            "3": "71",
                            "2": "1"
                    "6": {
                        "id": 6,
                        "type": 4,
                        "description": "",
                        "values": {
                            "48": "927"
                    "3": {
                        "id": 3,
                        "type": 4,
                        "description": "",
                        "values": {
                            "3": "71",
                            "2": "0"
                    "15": {
                        "id": 15,
                        "type": 3,
                        "description": "",
                        "values": {
                            "2": "1"
                "type": 18,
                "battery_level": 0,
                "heartbeat": 0
        martim
        @electrik Thanks. That will do I think. Now hopefully this will work :)
