  3. Home Assistant
  4. Send a text to node
Send a text to node
12 Posts 4 Posters 1.4k Views 4 Watching
  • P
    P
    Poupoune1974
    I have about 20 mysensors’s node, who send their values to HA, through a USB gateway.
    This way is OK.
    But now, I need to send infos from HA to my nodes (for LCD displaying, etc.)
    I tried with notify.mysensors, but I cannot get it to work : there is no sevice called like that.
    And it seems to be abandonned :
    https://www.home-assistant.io/integrations/notify.mysensors/
    https://forum.mysensors.org/topic/10488/homeassistant-mysensors-notify-does-nothing-alternatives/7
    Does someone have a workaround or knows how to integrate the that service in HA ?
    skywatchS 1 Reply Last reply
    • electrikE
      electrikE
      electrik
      I'm using node red for this purpose. This makes it easy to send data to nodes, without even following the integration guidelines for HA.
      Does your sketch fulfill the requirements from this page? https://www.home-assistant.io/integrations/notify.mysensors/
      P 1 Reply Last reply
      • P Poupoune1974
        This way is OK.
        skywatchS
        skywatchS
        skywatch
        @Poupoune1974 I don't know about HA, but in MyController it is easy to forward a payload received from one node to another for display. I use it with a weather forecasting node that sends to the controller and then the value is sent to a node in the bedroom to display on oled screen.
        • electrikE electrik
          P
          P
          Poupoune1974
          @electrik said in Send a text to node:
          The problem is that I have no notify.mysensors service in HA :
          I tried to use the sketch from your page, but could not receive any V_TEXT message.
          @skywatch HA might not be the ideal controller to work with mysensors. I ordered an ethernet gateway. Once delivered (6 weeks) I'll hope it will better communicate with mysensors.
          electrikE 1 Reply Last reply
          • P Poupoune1974
            electrikE
            electrikE
            electrik
            @Poupoune1974
            I also don't have this service but expected it to show up with this sketch. So that didn't show up, after the sketch presented itself to the gateway?
            I don't think another gateway will make a difference.
              @Poupoune1974
              P
              P
              Poupoune1974
              @electrik When I replace in the sketch :
              request(CHILD_ID, V_TEXT);
              With
              request(CHILD_ID, V_TEMP);
              I could receive a message from HA. Very strange.
              With another gateway, an ethernet one, I'd like to do use MQTT communication both ways.
              • electrikE
                electrikE
                electrik
                What do the logs say?
                • P
                  P
                  Poupoune1974
                  Serial monitor :
                  30439 TSF:MSG:SEND,66-66-0-0,s=1,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
                  Sending initial value
                  32448 TSF:MSG:SEND,66-66-0-0,s=1,c=1,t=47,pt=0,l=1,sg=0,ft=0,st=OK:-
                  Requesting initial value from controller
                  32456 TSF:MSG:SEND,66-66-0-0,s=1,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
                  34464 TSF:MSG:SEND,66-66-0-0,s=1,c=1,t=47,pt=0,l=1,sg=0,ft=0,st=OK:-
                  34473 TSF:MSG:SEND,66-66-0-0,s=1,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
                  36483 TSF:MSG:SEND,66-66-0-0,s=1,c=1,t=47,pt=0,l=1,sg=0,ft=0,st=OK:-
                  36493 TSF:MSG:SEND,66-66-0-0,s=1,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
                  And in HA
                  2020-04-17 08:42:48 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:137717498 TSF:MSG:READ,66-66-0,s=1,c=1,t=47,pt=0,l=1,sg=0:-
                  2020-04-17 08:42:48 WARNING (MainThread) [mysensors] Not a valid message: Not valid message sub-type: 47 for dictionary value @ data['sub_type']
                  2020-04-17 08:42:48 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:137717507 TSF:MSG:READ,66-66-0,s=1,c=2,t=47,pt=0,l=0,sg=0:
                  2020-04-17 08:42:50 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:137719517 TSF:MSG:READ,66-66-0,s=1,c=1,t=47,pt=0,l=1,sg=0:-
                  2020-04-17 08:42:50 WARNING (MainThread) [mysensors] Not a valid message: Not valid message sub-type: 47 for dictionary value @ data['sub_type']
                  2020-04-17 08:42:50 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:137719526 TSF:MSG:READ,66-66-0,s=1,c=2,t=47,pt=0,l=0,sg=0:
                  • electrikE
                    electrikE
                    electrik
                    I guess you are right and this is not working on HA...
                    • BearWithBeardB
                      BearWithBeardB
                      BearWithBeard
                      I wonder - have you specified a protocol version for the MySensors integration in configuration.yaml? Because your HA log hints that you are using an older protocol which doesn't support V_TEXT. It is only available with 2.0 and higher and IIRC the notify service was also introduced with 2.0. The MySensors integration in HA defaults to 1.4 if no version is specified.
                      mysensors:
                        version: '2.3'
                      For the record - I just set this up myself and it worked fine. I'm using Home Assistant 0.107.7 (Docker) and MySensors 2.3.2
                      Relevant code in my sketch:
                      #define CHILD_ID_TXT 98
                      MyMessage msgTxt(CHILD_ID_TXT, V_TEXT);
                      	send(msgTxt.set("#"));
                      	wait(1000);
                      	request(CHILD_ID_TXT, V_TEXT);
                      	present(CHILD_ID_TXT, S_INFO);
                      void receive(const MyMessage &msg)
                      	Serial.print("Received a message: ");
                      	Serial.println(msg.getString());
                      This is the HA log after uploading the new sketch to the node:
                      DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 179;98;0;0;36;
                      DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 179 child 98
                      DEBUG (MainThread) [mysensors.gateway_mqtt] Subscribing to: mysensors-out/179/98/1/+/+, qos: 0
                      DEBUG (MainThread) [mysensors.gateway_mqtt] Subscribing to: mysensors-out/179/98/2/+/+, qos: 0
                      DEBUG (MainThread) [mysensors.gateway_mqtt] Subscribing to: mysensors-out/179/+/4/+/+, qos: 0
                      DEBUG (SyncWorker_5) [mysensors.persistence] Saving sensors to persistence file /config/mysensors.json
                      DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 179;98;1;0;47;#
                      INFO (MainThread) [homeassistant.components.notify] Setting up notify.mysensors
                      INFO (MainThread) [homeassistant.components.mysensors] Adding new devices: [<MySensorsNotificationDevice DevNode 179 98>]
                      INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.mysensors
                      INFO (MainThread) [homeassistant.components.mysensors] Adding new devices: [<Entity DevNode 179 98: None>]
                      DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: DevNode 179 98: value_type 47, value = #
                      DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 179;98;2;0;47;
                      DEBUG (MainThread) [mysensors.gateway_mqtt] Publishing 179;98;1;0;47;#
                      Serial output on the node:
                      8812 TSF:MSG:READ,0-0-179,s=98,c=1,t=47,pt=0,l=1,sg=0:#
                      Received a message: #
                      The notify.mysensors service appeared right after presenting the new V_TEXT/S_INFO child. Sending custom messages from there works aswell.
                      Serial output:
                      413829 TSF:MSG:READ,0-0-179,s=98,c=1,t=47,pt=0,l=11,sg=0:TestMessage
                      Received a message: TestMessage
                      • P
                        P
                        Poupoune1974
                        Oh yeeeess !
                          version: '2.3'
                        did the trick ! Incredible ! I still have no notify.mysensors in the services, but it doesn't matter, I can now send infos to my nodes :
                        2020-04-17 18:01:35 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Citerne 1: value_type 47, value = -
                        Thank you so much !
                        • P
                          P
                          Poupoune1974
                          And after a node reboot, the notify.mysensors service appears too :
                          TSF:MSG:SEND,232-232-0-0,s=1,c=1,t=47,pt=0,l=12,sg=0,ft=0,st=OK:It works !!!
