  3. Modifying IKEA Tradfri Sensor (E1525) timeout help wanted
29 Posts 3 Posters 3.6k Views 3 Watching
  • electrikE Offline
    electrikE Offline
    electrik
    wrote on last edited by electrik
    #21
    It's confusing me.
    The potmeter has three legs. One is positive supply (VDD probably), one is ground and the other one should change voltage of you move the dial. You should measure between ground and the point you want to measure.
    Edit
    Now you should find out where this third leg is going to
    • B Offline
      B Offline
      bob21
      Yeah sorry about that. My inexperience is probably exacerbating things :grimacing: thank you for putting up with me ;)
      I am looking at the potmeter, and I think I can fairly say the legs are like this: https://imgur.com/a/1bTBnUo
      So with one probe on the variable leg, where to I test with the other probe?
      It looks like the variable leg first goes to TP5_1, then to TP5_2, then to the MCU, but it is not clear which pin: https://imgur.com/a/hbgOOBU
      • electrikE Offline
        electrikE Offline
        electrik
        @bob21 said in Modifying IKEA Tradfri Sensor (E1525) timeout help wanted:
        Always to ground
        With the continuity function of your multimeter (when it beeps if you short the probes) you can trace where it goes to.
        • B Offline
          B Offline
          bob21
          My meter doesn't beep, but I get a reading of 0.1 between TP5_2 and the second pin from the right, this seems to be the lowest reading by far: https://imgur.com/a/RLFyOBP is this a sign that it is connected here?
          But, when I set the potmeter to minimum the Voltage = 2.95, and this doesn't change... the potmeter set to max is still 2.95V... :disappointed:
          • electrikE Offline
            electrikE Offline
            electrik
            #25
            So, do you measure a voltage change on any of the pins of the potmeter when you change it?
            And what is the type of the MCU?
            • B Offline
              B Offline
              bob21
              wrote on last edited by bob21
              #26
              According to the pics I found, the MCU is a Silicon Labs Mighty Gecko EFR32MG1P132GI.
              With 1 probe to ground I tested:
              Pos leg with dial at 1 minute (min): 2.97V
              Pos leg with dial at 15 mins (max): 2.97V
              Neg leg with dial at 1 minute (min): 2.96V
              Neg leg with dial at 15 mins (max): 2.95V
              Variable leg with dial at 1 minute (min): 2.96V
              Variable leg with dial at 15 mins (max): 2.97V
              Seems like a very small change.. is this enough of a change to be useful?
              • electrikE Offline
                electrikE Offline
                electrik
                I'm out of ideas, I'm giving up.
                You could try to tie the variable pin to ground but it could damage your sensor
                • B Offline
                  B Offline
                  bob21
                  Ok, no worries. I'd like to thank you for spending your time on this :)
                  • P Offline
                    P Offline
                    peter_s
                    Hello everyone!
                    Based on the quite useful reverse engineered schematic at https://hackaday.io/project/174308-tradfri-pir-motion-sensor-hacking the measurements were somewhat sabotaged by the 2N7002 (see Connors comment "enables voltage dividers only when triggered").
                    the transistor is controlled by the Elmos E931.96 PIR motion controller IC.
                    The latter is programmable by the IKEA TRÅDFRI ICC-1 module's EFR32MG1P132F256GM32 MCU.
                    E.g.
                    2. Blind Time
                    Ignores motion after the interrupt output is switched back to 0
                    Range: 0.5s... 8s.
                    The blind time is [Register Value] *0.5s
                    3. Programmable pulse counter
                    1... 4 pulses with sign change in between
                    Amount of pulses = [Register Value] + 1
                    4. Window time
                    For noisy environments
                    2s... 8s window
                    Window time = [Register Value] * 2s + 2s
                    https://github.com/basilfx/TRADFRI-Hacking gives a good overview on that.
                    What is the issue with tose 60s?
