  3. Modifying IKEA Tradfri Sensor (E1525) timeout help wanted
29 Posts 3 Posters 3.9k Views 3 Watching
  • electrikE
    electrikE
    electrik
    Yes like that. And make sure the meter is on voltage reading, and the plugs are also in the voltage measuring connections. So not in the current measuring ones
    • B
      B
      bob21
      wrote on last edited by bob21
      I think I may have screwed up one of the earlier measurements. I am using a better meter now, and I got this: https://imgur.com/a/AQk22sR
      The Blue pin, which I originally said was connected to the VDD pin appears to actually be connected to the ground shield over the chip - I got a reading of zero. The Red pin, I got a reading of 3V (there abouts) and this is the one connected to the VDD pin on the E93196. Turning the potentiometer did not change the voltage on this.
      I remeasured the resistance from the ground leg of the potmeter to top green dot is 77K, bottom green dot is zero when at 1 minute, both are at 77K when at 15 minutes
      • electrikE
        electrikE
        electrik
        So is the third leg of the potentiometer still connected to the MCU input on? And what do you measure there? The voltage should change of you change the position
        • B
          B
          bob21
          Voltages:
          All 3 potmeter legs to MCU (blue): 2.9V - Does not change when potmeter moved
          All 3 potmeter legs to MCU (red): ~0.2mV-0.3mV - Does not change when potmeter moved
          Resistance:
          Top green on potmeter to MCU (red): 67K (turning dial does not change)
          Bottom green dot on potmeter to MCU (red): 67K at max time, 110K at minimum time
          Unmarked leg to MCU (red): 110K and does not change when potmeter moved
          • electrikE
            electrikE
            electrik
            wrote on last edited by electrik
            #21
            It's confusing me.
            The potmeter has three legs. One is positive supply (VDD probably), one is ground and the other one should change voltage of you move the dial. You should measure between ground and the point you want to measure.
            Edit
            Now you should find out where this third leg is going to
            • B
              B
              bob21
              Yeah sorry about that. My inexperience is probably exacerbating things :grimacing: thank you for putting up with me ;)
              I am looking at the potmeter, and I think I can fairly say the legs are like this: https://imgur.com/a/1bTBnUo
              So with one probe on the variable leg, where to I test with the other probe?
              It looks like the variable leg first goes to TP5_1, then to TP5_2, then to the MCU, but it is not clear which pin: https://imgur.com/a/hbgOOBU
              • electrikE
                electrikE
                electrik
                @bob21 said in Modifying IKEA Tradfri Sensor (E1525) timeout help wanted:
                Always to ground
                With the continuity function of your multimeter (when it beeps if you short the probes) you can trace where it goes to.
                • B
                  B
                  bob21
                  My meter doesn't beep, but I get a reading of 0.1 between TP5_2 and the second pin from the right, this seems to be the lowest reading by far: https://imgur.com/a/RLFyOBP is this a sign that it is connected here?
                  But, when I set the potmeter to minimum the Voltage = 2.95, and this doesn't change... the potmeter set to max is still 2.95V... :disappointed:
                  • electrikE
                    electrikE
                    electrik
                    #25
                    So, do you measure a voltage change on any of the pins of the potmeter when you change it?
                    And what is the type of the MCU?
                    • B
                      B
                      bob21
                      #26
                      According to the pics I found, the MCU is a Silicon Labs Mighty Gecko EFR32MG1P132GI.
                      With 1 probe to ground I tested:
                      Pos leg with dial at 1 minute (min): 2.97V
                      Pos leg with dial at 15 mins (max): 2.97V
                      Neg leg with dial at 1 minute (min): 2.96V
                      Neg leg with dial at 15 mins (max): 2.95V
                      Variable leg with dial at 1 minute (min): 2.96V
                      Variable leg with dial at 15 mins (max): 2.97V
                      Seems like a very small change.. is this enough of a change to be useful?
                      • electrikE
                        electrikE
                        electrik
                        I'm out of ideas, I'm giving up.
                        You could try to tie the variable pin to ground but it could damage your sensor
                        • B
                          B
                          bob21
                          Ok, no worries. I'd like to thank you for spending your time on this :)
                          • P
                            P
                            peter_s
                            Hello everyone!
                            Based on the quite useful reverse engineered schematic at https://hackaday.io/project/174308-tradfri-pir-motion-sensor-hacking the measurements were somewhat sabotaged by the 2N7002 (see Connors comment "enables voltage dividers only when triggered").
                            the transistor is controlled by the Elmos E931.96 PIR motion controller IC.
                            The latter is programmable by the IKEA TRÅDFRI ICC-1 module's EFR32MG1P132F256GM32 MCU.
                            E.g.
                            2. Blind Time
                            Ignores motion after the interrupt output is switched back to 0
                            Range: 0.5s... 8s.
                            The blind time is [Register Value] *0.5s
                            3. Programmable pulse counter
                            1... 4 pulses with sign change in between
                            Amount of pulses = [Register Value] + 1
                            4. Window time
                            For noisy environments
                            2s... 8s window
                            Window time = [Register Value] * 2s + 2s
                            https://github.com/basilfx/TRADFRI-Hacking gives a good overview on that.
                            What is the issue with tose 60s?
                            12.5k
