  3. Modifying IKEA Tradfri Sensor (E1525) timeout help wanted
29 Posts 3 Posters 3.9k Views 3 Watching
  • B
    B
    bob21
    Sure, just to confirm though (because I've not measured anything like this before), I put one probe on the MCU pin and the other to ground? Ie. Battery negative? Sorry if this seems like a really dumb question :D
    • electrikE
      electrikE
      electrik
      Yes like that. And make sure the meter is on voltage reading, and the plugs are also in the voltage measuring connections. So not in the current measuring ones
      • B
        B
        bob21
        wrote on last edited by bob21
        I think I may have screwed up one of the earlier measurements. I am using a better meter now, and I got this: https://imgur.com/a/AQk22sR
        The Blue pin, which I originally said was connected to the VDD pin appears to actually be connected to the ground shield over the chip - I got a reading of zero. The Red pin, I got a reading of 3V (there abouts) and this is the one connected to the VDD pin on the E93196. Turning the potentiometer did not change the voltage on this.
        I remeasured the resistance from the ground leg of the potmeter to top green dot is 77K, bottom green dot is zero when at 1 minute, both are at 77K when at 15 minutes
        • electrikE
          electrikE
          electrik
          So is the third leg of the potentiometer still connected to the MCU input on? And what do you measure there? The voltage should change of you change the position
          • B
            B
            bob21
            Voltages:
            All 3 potmeter legs to MCU (blue): 2.9V - Does not change when potmeter moved
            All 3 potmeter legs to MCU (red): ~0.2mV-0.3mV - Does not change when potmeter moved
            Resistance:
            Top green on potmeter to MCU (red): 67K (turning dial does not change)
            Bottom green dot on potmeter to MCU (red): 67K at max time, 110K at minimum time
            Unmarked leg to MCU (red): 110K and does not change when potmeter moved
            • electrikE
              electrikE
              electrik
              wrote on last edited by electrik
              #21
              It's confusing me.
              The potmeter has three legs. One is positive supply (VDD probably), one is ground and the other one should change voltage of you move the dial. You should measure between ground and the point you want to measure.
              Edit
              Now you should find out where this third leg is going to
              • B
                B
                bob21
                Yeah sorry about that. My inexperience is probably exacerbating things :grimacing: thank you for putting up with me ;)
                I am looking at the potmeter, and I think I can fairly say the legs are like this: https://imgur.com/a/1bTBnUo
                So with one probe on the variable leg, where to I test with the other probe?
                It looks like the variable leg first goes to TP5_1, then to TP5_2, then to the MCU, but it is not clear which pin: https://imgur.com/a/hbgOOBU
                • electrikE
                  electrikE
                  electrik
                  @bob21 said in Modifying IKEA Tradfri Sensor (E1525) timeout help wanted:
                  Always to ground
                  With the continuity function of your multimeter (when it beeps if you short the probes) you can trace where it goes to.
                  • B
                    B
                    bob21
                    My meter doesn't beep, but I get a reading of 0.1 between TP5_2 and the second pin from the right, this seems to be the lowest reading by far: https://imgur.com/a/RLFyOBP is this a sign that it is connected here?
                    But, when I set the potmeter to minimum the Voltage = 2.95, and this doesn't change... the potmeter set to max is still 2.95V... :disappointed:
                    • electrikE
                      electrikE
                      electrik
                      #25
                      So, do you measure a voltage change on any of the pins of the potmeter when you change it?
                      And what is the type of the MCU?
                      • B
                        B
                        bob21
                        #26
                        According to the pics I found, the MCU is a Silicon Labs Mighty Gecko EFR32MG1P132GI.
                        With 1 probe to ground I tested:
                        Pos leg with dial at 1 minute (min): 2.97V
                        Pos leg with dial at 15 mins (max): 2.97V
                        Neg leg with dial at 1 minute (min): 2.96V
                        Neg leg with dial at 15 mins (max): 2.95V
                        Variable leg with dial at 1 minute (min): 2.96V
                        Variable leg with dial at 15 mins (max): 2.97V
                        Seems like a very small change.. is this enough of a change to be useful?
                        • electrikE
                          electrikE
                          electrik
                          I'm out of ideas, I'm giving up.
                          You could try to tie the variable pin to ground but it could damage your sensor
                          • B
                            B
                            bob21
                            Ok, no worries. I'd like to thank you for spending your time on this :)
                            • P
                              P
                              peter_s
                              Hello everyone!
                              Based on the quite useful reverse engineered schematic at https://hackaday.io/project/174308-tradfri-pir-motion-sensor-hacking the measurements were somewhat sabotaged by the 2N7002 (see Connors comment "enables voltage dividers only when triggered").
                              the transistor is controlled by the Elmos E931.96 PIR motion controller IC.
                              The latter is programmable by the IKEA TRÅDFRI ICC-1 module's EFR32MG1P132F256GM32 MCU.
                              E.g.
                              2. Blind Time
                              Ignores motion after the interrupt output is switched back to 0
                              Range: 0.5s... 8s.
                              The blind time is [Register Value] *0.5s
                              3. Programmable pulse counter
                              1... 4 pulses with sign change in between
                              Amount of pulses = [Register Value] + 1
                              4. Window time
                              For noisy environments
                              2s... 8s window
                              Window time = [Register Value] * 2s + 2s
                              https://github.com/basilfx/TRADFRI-Hacking gives a good overview on that.
                              What is the issue with tose 60s?
                              12.5k
