  3. Serial GW and motion sensor functionning, but no activity between them
28 Posts 5 Posters 2.2k Views 5 Watching
  • R Offline
    R Offline
    Rolland
    Hello everyone ! My first topic here, to search for a help. I'm new to MySensors and a little confused by its working process, but i don't understand why my really simple and standard setup isn't working. Here it is :
    A Serial Gateway on arduino nano clone, with NRF24L01+ attached.
    A SR501 motion sensor on arduino nano clone with same radio attached.
    I've only used the example sketches found here on mysensors, compiled on Arduino IDE 1.8.12.
    GW and sensor are (for now) powered via USB on a desktop computer.
    Here is the log of sensor :
    16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=16,REL=255,VER=2.3.2
    26 TSM:INIT
    28 TSF:WUR:MS=0
    As far as i understand, the sensor is initializing, but that's all, no communication with GW, no data gathering...
    And for the GW :
    0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGA---,FQ=16,REL=255,VER=2.3.2
    0;255;3;0;9;5 TSM:INIT
    0;255;3;0;9;7 TSF:WUR:MS=0
    0;255;3;0;9;15 TSM:INIT:TSP OK
    0;255;3;0;9;18 TSM:INIT:GW MODE
    0;255;3;0;9;21 TSM:READY:ID=0,PAR=0,DIS=0
    0;255;3;0;9;24 MCO:REG:NOT NEEDED
    0;255;0;0;18;2.3.2
    0;255;3;0;9;28 MCO:BGN:STP
    0;255;3;0;9;35 MCO:BGN:INIT OK,TSP=1
    0;255;3;0;9;38 TSM:READY:NWD REQ
    0;255;3;0;9;1850 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    That's it...
    I've tried with different sensors, with other pieces of radio, other nanos... nothing changes.
    Hope it's a ridicoulous newbie problem and i thank you for the help you can bring me.
    Thanks a lot !
    parachutesjP skywatchS 2 Replies Last reply
    • R Rolland
      26 TSM:INIT
      28 TSF:WUR:MS=0
      And for the GW :
      0;255;0;0;18;2.3.2
      That's it...
      Thanks a lot !
      parachutesjP Offline
      parachutesj
      @Rolland
      Did you give your node an ID?
      You could set via code or burn into ROM. This is needed. Can you post your node-code?
      R 1 Reply Last reply
      • R Rolland
        26 TSM:INIT
        28 TSF:WUR:MS=0
        And for the GW :
        0;255;0;0;18;2.3.2
        That's it...
        Thanks a lot !
        skywatchS Offline
        skywatchS Offline
        skywatch
        @Rolland Post your code for the gateway and the node.
        • skywatchS skywatch
          R Offline
          R Offline
          Rolland
          @skywatch
          @parachutesj , i've only used the basic example for the mysensors site, no modification at all. Here is the sensor sketch code :
           * Version 1.0 - Henrik Ekblad
           * Motion Sensor example using HC-SR501
           * http://www.mysensors.org/build/motion
          // Enable debug prints
          #define MY_RADIO_RF24
          //#define MY_RADIO_NRF5_ESB
          //#define MY_RADIO_RFM95
          uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
          // Initialize motion message
            sendSketchInfo("Motion Sensor", "1.0");
            present(CHILD_ID, S_MOTION);
            // Read digital motion value
            bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
            Serial.println(tripped);
            send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
            sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
          And here is the GW code :
          * The ArduinoGateway prints data received from sensors on the serial link.
          * The gateway accepts input on serial which will be sent out on radio network.
          * The GW code is designed for Arduino Nano 328p / 16MHz
          * Wire connections (OPTIONAL):
          * - Inclusion button should be connected between digital pin 3 and GND
          * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
          * LEDs (OPTIONAL):
          * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
          * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
          * - ERR (red) - fast blink on error during transmission error or receive crc error
          // Enable serial gateway
          #define MY_GATEWAY_SERIAL
          // Define a lower baud rate for Arduinos running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
          #if F_CPU == 8000000L
          #define MY_BAUD_RATE 38400
          // Enable inclusion mode
          // Set blinking period
          // Flash leds on rx/tx/err
          @parachutesj, I've read again the presentation of mysensors functionning principles, and indeed, i've missed the fact that i must define a child id for every sensor, but the sketch already made this. I've the same problem with a DHT-11 node, with child_id_hum set to 0 and child_id_temp set to 1. I've tried to change these ids to 1 and 2, but nothing changed...
          Is the code of the sensor and GW above get you any new ideas ?
          Thanks a lot.
          • electrikE Offline
            electrikE Offline
            electrik
            @Rolland said in Serial GW and motion sensor functionning, but no activity between them:
            26 TSM:INIT
            28 TSF:WUR:MS=0
            Are these three lines all output from the sensor? That should be more, eg that it is finding its parent etc.
            Did you double check the connections between the Arduino and the NRF24?
            • parachutesjP parachutesj
              @Rolland
              R Offline
              R Offline
              Rolland
              @parachutesj Reading the library's API, I've understood that the node ID is defined automatically. I don't know how to find the info on seeing this is manually, if this is needed in my case. Can you help?
              parachutesjP 1 Reply Last reply
              • electrikE electrik
                26 TSM:INIT
                28 TSF:WUR:MS=0
                R Offline
                R Offline
                Rolland
                @electrik Yes, that's all debug lines that i get, no matter how long I wait. I've just checked again the connection between Arduino nano and NRF24, for GW and sensor, and it's all good, according to the connect informations on this page. I didn't connect the IRQ pin as mentionned.
                • parachutesjP Offline
                  parachutesj
                  try and put this into your code of the node
                  #define MY_NODE_ID 2
                  replace the number (2) for each further node with numbers between 1 and 255
                  what happens then?
                  • R Rolland
                    parachutesj
                    @Rolland as far as I know, you need a controller which assigns the node ID's - this of course means that you need a fully functioning setup from the beginning e.g. your gateway connected to a controller.
                    As a workaround you could specify the node ID manually. see my other post.
                    • skywatchS Offline
                      skywatchS Offline
                      skywatch
                      @Rolland - The advice from @parachutesj is spot on! - You NEED a controller.
                      The gateway is only a conduit through which communications from nodes to the controller flow. With no controller there is no flow of data and so you will see little traffic. A raspberry pi is all you need, then choose from the available software downloads to act as controller. Simple!
                        parachutesj
                        @Rolland and you should put this into your code from both (if not there yet)
                        • R Offline
                          R Offline
                          Rolland
                          Ok guys, thanks a lot for all your advices. I understand better. @skywatch : my gateway is on USB port of a Raspberry Pi 3+ with Home Assitant. But on this side I don't understand fully how to configure the link between gateway and HA, or at least to see if everything is going normal. HA is powerful but there's so much to learn when you discover it.
                          I'm discovering a lot of things in a little time : Mysensors, Home assistant, arduino...
                          Thanks anyway for your help and kindness.
                          @parachutesj , I'll modify my sketch and see what happens.
                          skywatchS 1 Reply Last reply
                          • R Rolland
                            skywatchS Offline
                            skywatchS Offline
                            skywatch
                            @Rolland The best way to see what is happening is to connect the gateway to the usb of a computer and open the serial monitor in the arduino IDE. Then you can see the values being sent by the nodes to test if it is working.
                            @parachutesj suggestion to add my debug to the config is also needed for this, but then reflash the node without my debug before you plug it back into the pi as it can cause issues. I never used HA so can't help you with that side of things, sorry.
                              what happens then?
                              R Offline
                              R Offline
                              Rolland
                              @parachutesj said in Serial GW and motion sensor functionning, but no activity between them:
                              what happens then?
                              Hi. Nothing change. I still got the same 3 debug lines, no sign of communication between node and gw...
                              • R Offline
                                R Offline
                                Rolland
                                I've also tried to clear the eeprom memory of the node, and flash again sensor sketch, but still the same problem... i've also tried to see if the motion sensor was working correctly, and made up a simple sketch with just the sensor and the Arduino, it's working fine.
                                • R Rolland
                                  skywatchS Offline
                                  skywatchS Offline
                                  skywatch
                                  @Rolland Does the motion sensor go HIGH or LOW when activated?
                                  • mfalkviddM Offline
                                    as @electrik mentioned, the sensor node does not complete its initialization of the radio.
                                    Therefore, it does not (yet) matter if node ID is defined, or how the motion sensor works. The node never reaches any of that stuff.
                                    @Rolland if you can, replace the radio on the sensor node. If that doesn't help, try replacing the Arduino. Also try to disconnect everything but the power and the radio from the Arduino.
                                      parachutesj
                                      wrote on last edited by parachutesj
                                      @mfalkvidd true.
                                      this is the log if the radio works and it does not have an ID. just uploaded to a blank Nano
                                      3 TSM:INIT
                                      4 TSF:WUR:MS=0
                                      11 TSM:INIT:TSP OK
                                      13 TSM:FPAR
                                      15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      1024 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                      1029 TSF:MSG:FPAR OK,ID=0,D=1
                                      2022 TSM:FPAR:OK
                                      2023 TSM:ID
                                      2024 TSM:ID:REQ
                                      2027 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                                      4034 TSM:ID
                                      4035 TSM:ID:REQ
                                      4037 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                                      6045 TSM:ID
                                      6046 TSM:ID:REQ
                                      6048 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                                      and like this if the NODE_ID was set (here to 155)
                                      3 TSM:INIT
                                      4 TSF:WUR:MS=0
                                      11 TSM:INIT:TSP OK
                                      13 TSM:INIT:STATID=155
                                      15 TSF:SID:OK,ID=155
                                      16 TSM:FPAR
                                      53 TSF:MSG:SEND,155-155-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      146 TSF:MSG:READ,0-0-155,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                      151 TSF:MSG:FPAR OK,ID=0,D=1
                                      2060 TSM:FPAR:OK
                                      2061 TSM:ID
                                      2062 TSM:ID:OK
                                      2064 TSM:UPL
                                      2067 TSF:MSG:SEND,155-155-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                      2079 TSF:MSG:READ,0-0-155,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                      2084 TSF:MSG:PONG RECV,HP=1
                                      2086 TSM:UPL:OK
                                      2088 TSM:READY:ID=155,PAR=0,DIS=1
                                      2093 TSF:MSG:SEND,155-155-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                      2100 TSF:MSG:READ,0-0-155,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                      2108 TSF:MSG:SEND,155-155-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                                      2116 TSF:MSG:SEND,155-155-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                      4125 TSF:MSG:SEND,155-155-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Motion Sensor
                                      4134 TSF:MSG:SEND,155-155-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                                      4143 TSF:MSG:SEND,155-155-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                                      4149 MCO:REG:REQ
                                      4155 TSF:MSG:SEND,155-155-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                      4170 TSF:MSG:READ,0-0-155,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                      4175 MCO:PIM:NODE REG=1
                                      4177 MCO:BGN:STP
                                      4178 MCO:BGN:INIT OK,TSP=1
                                      4188 TSF:MSG:SEND,155-155-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
                                      4194 MCO:SLP:MS=120000,SMS=0,I1=1,M1=1,I2=255,M2=255
                                      4199 MCO:SLP:TPD
                                      if I "kill" the radio, it looks like this, which is still different than what @Rolland got. But would be worth a try to replace the radio.
                                      3 TSM:INIT
                                      4 TSF:WUR:MS=0
                                      11 !TSM:INIT:TSP FAIL
                                      12 TSM:FAIL:CNT=1
                                      14 TSM:FAIL:PDT
                                        parachutesj
                                        almost forgot:
                                        to just eliminate the issues with ID, missing controller etc. You could test the radios with a simple NRF24 test script, just google "NRF24 test code" and you will find a bunch to test if the communication works between nodes and radios are ok.
                                        • skywatchS Offline
                                          skywatchS Offline
                                          skywatch
                                          Photos of your hardware would be good as 'nano clone' and 'nrf24' come in lots of types and qualities...
