  3. [Solved] Arduino Nanos don't work as nodes
37 Posts 6 Posters 3.2k Views 5 Watching
  • electrikE
    electrikE
    electrik
    I don't think this is a software issue. More likely your NRF24 is failing.
    A 1 Reply Last reply
    • electrikE electrik
      A
      A
      Avamander
      @electrik It's highly unlikely. I have more than one type of module and more than one module of each type, none of them work. I also swapped the modules between working GW and Mega node and it still works, I swap the module between working GW and the node, it doesn't work.
      • electrikE
        electrikE
        electrik
        Could you try version 2.2 of mysensors? I remember summer changes in 2.4 regarding nrf modules
          A
          A
          Avamander
          wrote on last edited by Avamander
          #24
          @electrik :
          I went to the oldest available version and it doesn't work.
          I don't really get it, if I swap the radios between the Mega node and the Nano node, it stops working, swapping CE/CSN also makes it stop working - any alterations make it fail loud and clear.
          It does initialize the radio and claim everything is okay. I can be quite certain it's not the radios, it's not the boards themselves, it's not the wiring.
          There's something very specific to the Nanos themselves that 2.x.x is unable to use the nRF24L01+.
          I will assemble an Arduino Uno board and see if the issue is specific to the AtMega328P.
          • A
            A
            Avamander
            #25
            I also ran the full "test" suite of RF24 and all examples work great, so I am very certain communication is likely to be very good.
            It's just that something makes MySensors not like it.
            • A
              A
              Avamander
              #26
              Just in case I also took clean RepeaterNode example and just defined the CE/CSN pins and channel, it's still unable to work.
              I also tried the same example without any repeater functionality enabled, it's still unable to register. It's basically a blank sketch.
              Changing Node ID didn't also work.
              • electrikE
                electrikE
                electrik
                In your first sketch the baud rate was 2mbps. How is your existing network configured?
                If you take an example sketch and an example gateway sketch, does it work then. So don't change channels and so on
                  A
                  A
                  Avamander
                  That's exactly the same across all my sketches.
                  Yeah, I did that and wrote about it above, took RepeaterNode and just defined CE/CSN on GW and the node.
                  • A
                    A
                    Avamander
                    #29
                    I've determined that it doesn't matter which:
                    • Radio
                    • Radio's power supply/source
                    • Nano
                    • Bootloader
                    • Arduino IDE (tried 1.8.2 and latest nightly)
                    • 2.x.x MySensors
                    • Example, or custom sketch
                    • Channel, data rate, power level or node ID
                    • Repeater or not
                    • WAIT_READY_MS or not
                    • Predefined master or not
                    • SPI bus speed, 0.5*default SPI speed didn't help
                    I just can't make a Nano act as a regular node.
                    Maybe a MySensors dev has an idea what I could try.
                    • A
                      A
                      Avamander
                      I'm going to finish my Arduino Uno node and if that too doesn't work getting MyController to work must take some goat sacrifice because I can't do it.
                      • A
                        A
                        Avamander
                        #31
                        I just discovered that on the Arduino Uno RF24_250KBPS works, but RF24_2MBPS doesn't. On the Nanos, neither work.
                        I used RF24 and tested the boards for a while, I've determined that 2MBPS on that specific channel works great, I've sent at least 100 000 packets and lost only two. Auto-ack and dynamic payloads also work.
                        I am 99.99% certain this is a bug in MySensors. @mfalkvidd maybe you have some ideas where to look next?
                        YveauxY 1 Reply Last reply
                        • A Avamander
                          YveauxY
                          YveauxY
                          @Avamander nano's are basically just regular atmega328 boards, running off 5v at 16MHz. The MySensors stack doesn't know if it is running on a nano, uno or pro mini, so why are you so certain this is a bug in the stack?
                          What I do know is that a lot of low quality nanos are available from Chinese sources, with bad ground planes or crappy power regulators.
                          What nano boards do you use? Could you try a different atmega328 based arduino?
                          • YveauxY Yveaux
                            A
                            A
                            Avamander
                            #33
                            @Yveaux said in Arduino Nanos don't work as nodes:
                            Because I'm really rather certain it isn't the hardware. You can read what I've replaced, swapped and tried. The radios have been decoupled, the power has been decoupled. The setup works in all possible ways when using RF24.
                            Yeah, I said I tried an Uno and it exhibited pretty much the same symptoms when acting as a regular node.
                            tekkaT 1 Reply Last reply
                            • A Avamander
                              tekkaT
                              tekkaT
                              tekka
                              wrote on last edited by tekka
                              #34
                              @Avamander Can you upload both, the GW and node sketches from the working pair nanoGW/megaNode? Also, it would be helpful to see the full GW log from the non-working combination (nanoNode/megaGW) with MY_DEBUG_VERBOSE_RF24 enabled. If time allows, I'd like to reproduce and test your setup.
                              • tekkaT tekka
                                A
                                A
                                Avamander
                                #35
                                @tekka
                                Just to be clear, the Arduino Mega node (megaNode) can talk to the Arduino Nano gateway (nanoGW), but no Arduino Nano node (nanoNode) can talk to the Arduino Nano gateway.
                                I'll post the sketches and logs.
                                • A
                                  A
                                  Avamander
                                  Ah, I think cussing is warranted here, I copied the radio configuration from my old sketch to the new ones, the node had:
                                  #define RF24_DATARATE RF24_2MBPS
                                  The GW has:
                                  #define MY_RF24_DATARATE RF24_2MBPS
                                  Lesson learned: Never copy configuration from an existing older sketch, you never know what has been deprecated without a warning. MY_RADIO_NRF24 threw a warning and I fixed that, had no idea about RF24_DATARATE and I didn't notice it. :sweat_smile:
                                  • alowhumA
                                    alowhumA
                                    alowhum
                                    This thread reads like an Agathie Christie novel. Well done on finding it!
