  3. works fine with 1.4.1 but not with 2.3.2
8 Posts 3 Posters 824 Views 3 Watching
  • B
    B
    Bmlsx
    hi all,
    long time no see :)
    have a strange issue that prbly is already answered somewhere but cannot find it
    i have a very simple setup with only an arduino Pro mini and an NRF24 (the famous 1242AF) that works fine with mysensors 1.4.1 but with the latest version does not (!RF24:INIT:SANCHK FAIL) with the below debug output
    any ideas ?
    many thanx in advance
    ////////////// 1.4.1
    sensor started, id 33
    send: 33-33-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
    send: 33-33-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
    send: 33-33-0-0 s=255,c=3,t=11,pt=0,l=18,st=ok:Temperature Sensor
    send: 33-33-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
    NumSensors:
    send: 33-33-0-0 s=0,c=0,t=6,pt=0,l=5,st=ok:1.4.1
    send: 33-33-0-0 s=0,c=1,t=0,pt=7,l=5,st=ok:23.9
    ////////////////////////////2.3.2
    16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=8,REL=255,VER=2.3.2
    28 TSM:INIT
    30 TSF:WUR:MS=0
    32 RF24:INIT:PIN,CE=9,CS=10
    36 RF24:SBY
    36 RF24:WBR:REG=0,VAL=14
    45 RF24:WBR:REG=3,VAL=3
    47 RF24:WBR:REG=4,VAL=95
    49 RF24:WBR:REG=5,VAL=76
    53 RF24:WBR:REG=6,VAL=33
    55 RF24:WBR:REG=29,VAL=4
    57 RF24:RBR:REG=29,VAL=0
    61 RF24:WBR:REG=16,VAL=115
    63 RF24:WBR:REG=29,VAL=4
    65 RF24:RBR:REG=6,VAL=0
    69 !RF24:INIT:SANCHK FAIL
    71 !TSM:INIT:TSP FAIL
    73 TSM:FAIL:CNT=1
    75 TSM:FAIL:DIS
    77 TSF:TDI:TSL
    77 RF24:SLP
    79 RF24:WBR:REG=0,VAL=12
    • B Bmlsx
      hi all,
      long time no see :)
      any ideas ?
      NumSensors:
      28 TSM:INIT
      30 TSF:WUR:MS=0
      36 RF24:SBY
      73 TSM:FAIL:CNT=1
      75 TSM:FAIL:DIS
      77 TSF:TDI:TSL
      77 RF24:SLP
      @Bmlsx could you post the entire sketches (for both 1.4.1 and 2.3.2)?
      • B
        B
        Bmlsx
        hi,
        I use the examples
        from 1.4.1 the humidity sensor and from 2.3.2 the mock sensor
        A 1 Reply Last reply
        • B Bmlsx
          hi,
          I use the examples
          A
          A
          Avamander
          @Bmlsx You're better off taking 2.x.x humidity sensors example. Alternatively, you should check if all the configuration options you're currently using are valid and used.
          • B
            B
            Bmlsx
            hi again
            had some progress
            i found one sensebender micro board i had from the early days
            and with the factory installed scketch I connected the NRF and it was working !!!
            when i deployed an example from 2.3.2 again the same error
            it must be something that changed over the years and now it is not compatible with my old RF24 HW
            • B Bmlsx
              hi again
              had some progress
              A
              A
              Avamander
              @Bmlsx Check the configuration defines and/or just post the sketch.
              • B
                B
                Bmlsx
                problem solved by throwing away 5 yo+ NRF24 and buying new ones
                why 1.4.1 was working with those old NRFs remains a mystery
                • B Bmlsx
                  @Bmlsx mystery indeed. Thanks for reporting back.
