  3. Ethernet Gateway - W5100 - stops responding to sensor and server
6 Posts 3 Posters 734 Views 3 Watching
  • pw44P
    pw44P
    pw44
    Hi All,
    after building the gateway with the w5100 shield + Uno R3 + NRF24L01, it starts, i can telnet to it, it responds.
    Power supply is a 9V 1A feeding the Uno
    After a while, it becomes unresponsive, telnet does not work, but it responds to pings.
    Also extended with the leds for error, tx and rx, but these does not work.
    Any hint what can be happening?
    Thx in advance.
    • N
      N
      NeoX
      I have exactly same issue as you.
      https://forum.mysensors.org/topic/11242/arduino-mega-w5500-bme280-connection-refused-all-the-time/2
      However, i haven't found a solution :( I think this is a bug in mysensors.
      What i suggest - use MQTT as a workaround
      • B
        B
        bomber
        I had similar issue. I found that problem was W5100. It just turned to brick when it runs long time as server. And I have seen that many times.
        Upload basic ethernet sketch and check that Ethernet module is still working. I found that mine was not working at all.
        My workaround was to use W5300 what is much better. Runs colder and is able to share bus.
        • B
          B
          bomber
          Sorry, the correct new Ethernet module type is W5500.
          N 1 Reply Last reply
          • B bomber
            N
            N
            NeoX
            @bomber said in Ethernet Gateway - W5100 - stops responding to sensor and server:
            I use W5500, no difference. But mine is not bricked, resetting arduino+w5500 helps and again i can connect to it...For a one time...
            pw44P 1 Reply Last reply
            • N NeoX
              pw44P
              pw44P
              pw44
              @NeoX i gave up the w5100 gateway (uno r3 + w5100 shiled + NRF24L01+PA-LNA).
              the gateway with NRF24L01+ and Wemos D1 mini is working flawlessly the last two days - so, it will be the way to go.
