  3. gw.sendVariable - library question
4 Posts 3 Posters 553 Views 3 Watching
  • pw44P
    pw44P
    pw44
    getting an example, gw.sendVariable was not recognized and i could not find it.
    Any hint?
    • boumB
      boumB
      boum
      You should post the code you're trying to compile. But it looks like it is using an older version of MySensors. The object model with Sensor gw is deprecated now.
      To send values to the gateway, you should use MyMessage messageName(CHILD_ID, V_type_of_message);
      pw44P 1 Reply Last reply
      • boumB boum
        pw44P
        pw44P
        pw44
        @boum thx, man. i was in doubt, so you confirmed that it's deprecated.
        i was following the code:
          // Read digital motion value
          boolean motion = digitalRead( DIGITAL_INPUT_SENSOR ) == LOW;
          // Send debug output to serial monitor
          mprintln(PSTR("Motion sensor %s"), motion ? "ON" : "OFF" );
          if (lastMotion != motion) {
            lastMotion = motion;
            // Send motion value to sensor
            gw.send( msg.set( motion ? "1" : "0" ) );
            if (motion) {
              gw.sleep( SLEEP_TIME );
          gw.sleep( INTERRUPT, CHANGE, SLEEP_TIME );
        to use the motion sensor without interrupt (pin 2 or 3).
          A guide for converting sketches using MySensors 1.5 to MySensors 2 is available at https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
