  3. Compilation error nrf52_dk plateformio
5 Posts 3 Posters 750 Views 3 Watching
  • Ikes 72000I
    Ikes 72000I
    Ikes 72000
    I'm new to mysensors and trying to test some nrf52832 cards.
    Currently I am able to communicate and load a basic program into the nrf52 card via a BMP.
    Basic code:
    #include <Arduino.h>
      // put your setup code here, to run once:
      // put your main code here, to run repeatedly:
    Log:
    Processing nrf52_dk (platform: nordicnrf52; board: nrf52_dk; framework: arduino)
    Verbose mode can be enabled via `-v, --verbose` option
    CONFIGURATION: https://docs.platformio.org/page/boards/nordicnrf52/nrf52_dk.html
    PLATFORM: Nordic nRF52 4.4.0 > Nordic nRF52-DK
    HARDWARE: NRF52832 64MHz, 64KB RAM, 512KB Flash
    DEBUG: Current (jlink) On-board (cmsis-dap, jlink) External (blackmagic, stlink)
    PACKAGES:
     - framework-arduinonordicnrf5 1.600.190830 (6.0)
     - tool-bossac-nordicnrf52 1.10866.191129 (1.8.66)
     - tool-jlink 1.65200.0 (6.52.0)
     - tool-openocd 2.1000.190707 (10.0)
     - tool-sreccat 1.164.0 (1.64)
     - toolchain-gccarmnoneeabi 1.70201.0 (7.2.1)
    LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf
    LDF Modes: Finder ~ chain, Compatibility ~ soft
    LibraryManager: Installing id=548
    Using cache: C:\Users\Ikes\.platformio\.cache\08\6b3d0755f5ced94725e5025051350d08
    MySensors @ 2.3.2 has been successfully installed!
    Found 37 compatible libraries
    Scanning dependencies...
    No dependencies
    Building in release mode
    Checking size .pio\build\nrf52_dk\firmware.elf
    Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
    RAM:   [          ]   0.2% (used 140 bytes from 65536 bytes)
    Flash: [          ]   0.4% (used 2256 bytes from 524288 bytes)
    Configuring upload protocol...
    AVAILABLE: blackmagic, cmsis-dap, jlink, mbed, nrfjprog, stlink
    CURRENT: upload_protocol = blackmagic
    Looking for BlackMagic port...
    Auto-detected: COM6
    Uploading .pio\build\nrf52_dk\firmware.hex
    Target voltage: 3.02V
    Available Targets:
    No. Att Driver
     1      Nordic nRF52 M3/M4
     2      Nordic nRF52 Access Port
    0x000006ee in main ()
    Loading section .text, size 0x85c lma 0x0
    Loading section .ARM.exidx, size 0x8 lma 0x85c
    Loading section .data, size 0x6c lma 0x864
    Start address 0x4b8, load size 2256
    Transfer rate: 31 KB/sec, 451 bytes/write.
    Section .text, range 0x0 -- 0x85c: matched.
    Section .ARM.exidx, range 0x85c -- 0x864: matched.
    Section .data, range 0x864 -- 0x8d0: matched.
    Kill the program being debugged? (y or n) [answered Y; input not from terminal]
    ========================================================================================== [SUCCESS] Took 4.02 seconds ==========================================================================================
    When I try to download a sample sketch (pulse counter, mysensors library sample), I get compilation errors.
    Log:
    Compiling .pio\build\nrf52_dk\lib45d\Time_ID44\DateStrings.cpp.o
    In file included from src\main.cpp:2:0:
    .pio\libdeps\nrf52_dk\MySensors/MySensors.h:426:2: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    In file included from C:\users\ikes\.platformio\packages\framework-arduinonordicnrf5\cores\nRF5/Arduino.h:17:0,
                     from C:\users\ikes\.platformio\lib\Time_ID44\DateStrings.cpp:12:
    C:\users\ikes\.platformio\lib\Time_ID44\DateStrings.cpp: In function 'char* monthStr(uint8_t)':
    C:\users\ikes\.platformio\packages\framework-arduinonordicnrf5\cores\nRF5/avr/pgmspace.h:105:49: error: 'const void*' is not a pointer-to-object type
     #define pgm_read_ptr(addr) (*(const void *)(addr))
    C:\users\ikes\.platformio\packages\framework-arduinonordicnrf5\cores\nRF5/avr/pgmspace.h:63:45: note: in definition of macro 'strcpy_P'
     #define strcpy_P(dest, src) strcpy((dest), (src))
    C:\users\ikes\.platformio\lib\Time_ID44\DateStrings.cpp:72:29: note: in expansion of macro 'pgm_read_ptr'
         strcpy_P(buffer, (PGM_P)pgm_read_ptr(&(monthNames_P[month])));
    C:\users\ikes\.platformio\lib\Time_ID44\DateStrings.cpp: In function 'char* dayStr(uint8_t)':
    C:\users\ikes\.platformio\lib\Time_ID44\DateStrings.cpp:86:28: note: in expansion of macro 'pgm_read_ptr'
        strcpy_P(buffer, (PGM_P)pgm_read_ptr(&(dayNames_P[day])));
    *** [.pio\build\nrf52_dk\lib45d\Time_ID44\DateStrings.cpp.o] Error 1
    *** [.pio\build\nrf52_dk\src\main.cpp.o] Error 1
    Where can the problem come from?
    Thanks.
    Ikes
    • Ikes 72000I Ikes 72000
      Basic code:
      Log:
      PACKAGES:
      No dependencies
      Auto-detected: COM6
      Available Targets:
      No. Att Driver
      Log:
      Thanks.
      Ikes
      Welcome to the forum @Ikes-72000
      This message means that the sketch is configured as a node (not a gateway), but no transport is selected. Without a transport, a MySensors node can't do much.
      If you just want to try the most basic nrf5, add
      #define MY_GATEWAY_SERIAL
      to the sketch, before including MySensors.h.
      • Ikes 72000I
        Ikes 72000I
        Ikes 72000
        I just tried this code and compilation fail.
        Log:
        PACKAGES:
        Dependency Graph
        |-- <MySensors> 2.3.2
        |   |-- <Time> 1.6
        |   |-- <SPI> 1.0
        |   |-- <Wire> 1.0
        Compiling .pio\build\nrf52_dk\src\main.cpp.o
        Compiling .pio\build\nrf52_dk\FrameworkArduino\Stream.cpp.o
        Compiling .pio\build\nrf52_dk\FrameworkArduino\Uart.cpp.o
        In file included from .pio\libdeps\nrf52_dk\MySensors/MySensors.h:74:0,
                         from src\main.cpp:7:
        .pio\libdeps\nrf52_dk\MySensors/hal/architecture/NRF5/MyHwNRF5.cpp: In function 'uint16_t hwCPUVoltage()':
        .pio\libdeps\nrf52_dk\MySensors/hal/architecture/NRF5/MyHwNRF5.cpp:506:16: warning: 'sample' is used uninitialized in this function [-Wuninitialized]
          return (sample*3600)/255;
        =========================================================================================== [FAILED] Took 5.57 seconds ===========================================================================================
        BearWithBeardB 1 Reply Last reply
          Log:
          PACKAGES:
          Dependency Graph
          |   |-- <Time> 1.6
          |   |-- <SPI> 1.0
          |   |-- <Wire> 1.0
          BearWithBeardB
          BearWithBeardB
          BearWithBeard
          @Ikes-72000 said in Compilation error nrf52_dk plateformio:
          Dependency Graph
          | |-- <Time> 1.6
          | |-- <SPI> 1.0
          | |-- <Wire> 1.0
          Why does it list this Time library as a dependency? This shouldn't be here. Did you, at some point, include it in lib_deps? Because your current issue seems to be related to this lib, not MySensors. Without it, it should compile just fine.
          PACKAGES:
          Found 6 compatible libraries
          Dependency Graph
          |   |-- <Wire> 1.0
          |   |-- <SPI> 1.0
          RAM:   [          ]   2.1% (used 1352 bytes from 65536 bytes)
          Flash: [          ]   3.8% (used 19784 bytes from 524288 bytes)
          ============================== [SUCCESS] Took 1.51 seconds ==============================
          Try pio lib uninstall Time or remove it manually from the libdeps folder and rebuild the sketch.
          Ikes 72000I 1 Reply Last reply
          • BearWithBeardB BearWithBeard
            Dependency Graph
            | |-- <Time> 1.6
            | |-- <SPI> 1.0
            | |-- <Wire> 1.0
            PACKAGES:
            Dependency Graph
            |   |-- <Wire> 1.0
            |   |-- <SPI> 1.0
            Ikes 72000I
            Ikes 72000I
            Ikes 72000
            @BearWithBeard, compilation works fine after remove time lib. Thanks.
            Now I can play with mysensors. :smiley:
