  3. temp sensor not reading at all
6 Posts 3 Posters 608 Views 3 Watching
  • markjgabbM
    markjgabbM
    markjgabb
    hey guys
    ive tried to modify two of the built in designs to make them work together, but i think ive stuffed up the dallas temprature probe
    the temprature is never updated or sent to the controller
    anyone able to advise what ive missed?
    i only have the one temprature sensor hooked up
    // Enable debug prints
    //#define MY_DEBUG
    #define MY_RADIO_RF24
    #include <OneWire.h>
    #define COMPARE_TEMP 1
    #define LIGHT_SENSOR_ANALOG_PIN 0
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    unsigned long SLEEP_TIME = 120000 ; // 120000 Sleep time between reports (in milliseconds)
    int lastLightLevel;
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_LIGHT 2
    //#define MY_REPEATER_FEATURE
    // Initialize motion message
    MyMessage temp(CHILD_ID_TEMP,V_TEMP);
    MyMessage light(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
    // BATTERY VOLTAGE DIVIDER SETUP
    #define VBAT_PER_BITS 0.003363075
    #define VMIN 1.9                                  //  Vmin (radio Min Volt)=1.9V (564v)
    #define VMAX 3.0                                  //  Vmax = (2xAA bat)=3.0V (892v)
    int batteryPcnt = 0;                              // Calc value for battery %
    int batLoop = 0;                                  // Loop to help calc average
    int batArray[3];                                  // Array to store value for average calc.
    int BATTERY_SENSE_PIN = A0;                       // select the input pin for the battery sense point
    void before()
      sensors.begin();
      sendSketchInfo("Lounge Node enviroment", "1.0");
    //light sensor
      int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
        Serial.print("Light Level:");
        Serial.println(lightLevel);
            send(light.set(lightLevel));
            lastLightLevel = lightLevel;
    //temprature
      sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        #else
          send(temp.setSensor(i).set(temperature,1));
      batM();
      sleep(SLEEP_TIME);
    void batM() //The battery calculations
       delay(500);
       // Battery monitoring reading
       delay(500);
       // Calculate the battery in %
       float Vbat  = sensorValue * VBAT_PER_BITS;
       int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
       Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
       // Add it to array so we get an average of 3 (3x20min)
       batArray[batLoop] = batteryPcnt;
       if (batLoop > 2) {
         batteryPcnt = (batArray[0] + batArray[1] + batArray[2] + batArray[3]);
         batteryPcnt = batteryPcnt / 3;
       if (batteryPcnt > 100) {
         batteryPcnt=100;
         Serial.print("Battery Average (Send): "); Serial.print(batteryPcnt); Serial.println(" %");
           batLoop = 0;
         else
         batLoop++;
    • markjgabbM markjgabb
      hey guys
      //#define MY_DEBUG
      int numSensors=0;
      bool metric = true;
      int lastLightLevel;
      void before()
        sensors.begin();
      //light sensor
      //temprature
          #else
        batM();
        sleep(SLEEP_TIME);
         delay(500);
         delay(500);
         if (batLoop > 2) {
           batteryPcnt=100;
             batLoop = 0;
           else
           batLoop++;
      @markjgabb the debug output of the node is likely the best first step for troubleshooting.
      • markjgabbM
        markjgabbM
        markjgabb
        yeah ive checked that
        this is the parsed log below
        it presents the temp sensor, but never sends the temp data
        https://www.mysensors.org/build/parser?log=2131 TSF%3AMSG%3ASEND%2C3-3-0-0%2Cs%3D255%2Cc%3D3%2Ct%3D11%2Cpt%3D0%2Cl%3D22%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3ALounge Node enviroment 2143 TSF%3AMSG%3ASEND%2C3-3-0-0%2Cs%3D255%2Cc%3D3%2Ct%3D12%2Cpt%3D0%2Cl%3D3%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A1.0 2151 TSF%3AMSG%3ASEND%2C3-3-0-0%2Cs%3D2%2Cc%3D0%2Ct%3D16%2Cpt%3D0%2Cl%3D0%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A 2157 TSF%3AMSG%3ASEND%2C3-3-0-0%2Cs%3D1%2Cc%3D0%2Ct%3D6%2Cpt%3D0%2Cl%3D0%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A 2163 MCO%3AREG%3AREQ 2167 TSF%3AMSG%3ASEND%2C3-3-0-0%2Cs%3D255%2Cc%3D3%2Ct%3D26%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A2 2173 TSF%3AMSG%3AREAD%2C0-0-3%2Cs%3D255%2Cc%3D3%2Ct%3D27%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 2179 MCO%3APIM%3ANODE REG%3D1 2181 MCO%3ABGN%3ASTP 2183 MCO%3ABGN%3AINIT OK%2CTSP%3D1 Light Level%3A4 2188 TSF%3AMSG%3ASEND%2C3-3-0-0%2Cs%3D2%2Cc%3D1%2Ct%3D23%2Cpt%3D2%2Cl%3D2%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A4 Battery percent%3A 125 %25 3696 MCO%3ASLP%3AMS%3D120000%2CSMS%3D0%2CI1%3D255%2CM1%3D255%2CI2%3D255%2CM2%3D255 3702 TSF%3ATDI%3ATSL 3704 MCO%3ASLP%3AWUP%3D-1 3706 TSF%3ATRI%3ATSB Light Level%3A3 3714 TSF%3AMSG%3ASEND%2C3-3-0-0%2Cs%3D2%2Cc%3D1%2Ct%3D23%2Cpt%3D2%2Cl%3D2%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A3 Battery percent%3A 127 %25 5223 MCO%3ASLP%3AMS%3D120000%2CSMS%3D0%2CI1%3D255%2CM1%3D255%2CI2%3D255%2CM2%3D255 5229 TSF%3ATDI%3ATSL
        • markjgabbM
          markjgabbM
          markjgabb
          ok think i have partially found the issue, when i re did it for a simpler setup, it seems that im measureing temprature of -127 im not even sure what the means, i assume its an error but not sure what its telling me
          • markjgabbM
            markjgabbM
            markjgabb
            God I'm an idiot. Must of picked up the wrong resistor.
            10k resistor won't help me much
            • X
              X
              xreichardx
              If your Dallas DS18B20 was purchased on ebay or amazon or elsewhere other than DigiKey, Mouser, etc, it is likely counterfeit and will not work in parasitic power mode and will give a -127.
              Here's a sketch to help determine of the Ds18B20 is genuine and rule-out shoddy counterfeits:
              https://github.com/cpetrich/counterfeit_DS18B20
              I wasted countless days and days with remote sensors only to find they were counterfeit.
