  3. Gateway device
Gateway device
151 Posts 19 Posters 152.9k Views 21 Watching
  • scalzS
    scalzS
    @tbowmo: oh, i have the 48p variant. so I will try to use it in another project in the future. and will order other sample.
    sensebender micro2 atsam, wow, crazy thing! could be fun to see this :smile:
    • tbowmoT tbowmo
      Just learned a lesson the hard way, the last couple of days.. Discovered that I hadn't read the datasheet for the atsamd21 good enough, so I had connected all the PINS for the SPI / UARTs completely wrong. Which means 10-12 connections that was wrong (the board uses 3 SPI ports and 2 UARTs, one SPI doubles as UART, depending on the network interface connected)
      So new boards are in the pipeline from dirtypcbs.com
      This is btw improved on a couple of other points, compared to the previous board. Biggest is, that it now has 4 x 3mm mounting holes, (happy now @ServiceXp ? :)). It also got a couple of extra solder jumpers on the backside, that could be used for software configurations, or test points.
      RJ_MakeR
      RJ_MakeR
      RJ_Make
      @tbowmo Now that's what I'm talking about.. Those holes look so sexy.... wait, that doesn't sound right.... :bowtie:
      RJ_Make
      • tbowmoT tbowmo
        @scalz
        atsamd21 comes in 3 variants, with 32, 48 og 64 pins (If I remember right). I'm using the 64 pin variant
        If things go well with this one, then I might make a sensebender micro 2, with an 32 pin atsamd20 (almost the same as d21, but without USB host/slave capabilities)
        RJ_MakeR
        RJ_MakeR
        RJ_Make
        @tbowmo How is the testing going?
        RJ_Make
        • tbowmoT
          tbowmoT
          tbowmo
          @ServiceXp
          I just received the PCBs for the second prototype spin yesterday, the first spin had too many errors in the routing around SPI / UARTS so I decided to ditch it, and do a second spin. Dirtypcbs got some hickups processing my gerbers but finaly made the boards.
          I hope that I can get around to assemble one this weekend, but I can't promise anything, as I have been loaded more than 150% with work (both from my employer, and from the wife).
          RJ_MakeR 1 Reply Last reply
          • tbowmoT tbowmo
            @ServiceXp
            RJ_MakeR
            RJ_MakeR
            RJ_Make
            @tbowmo Sounds Good, Thanks for the update.
            RJ_Make
            • tbowmoT
              tbowmoT
              tbowmo
              #126
              Images of the latest pcb's (Before SMD assembly)
              Unfortunately I "injured" my back today (aah, maybe not injured, but feels like it :() so I'm on strong medics to keep the pain away. That means that didn't get around to do the SMD assembly today as I planned, as I can't sit at the desk for a longer time.. hope that it gets better during the weekend.
              • tbowmoT tbowmo
                RJ_MakeR
                RJ_MakeR
                RJ_Make
                @tbowmo Oh now that is sexy.. From someone with back problems, you take it easy for the next 3 days Sir!! :point_left:
                RJ_Make
                • tbowmoT
                  tbowmoT
                  tbowmo
                  Aahh.. I'm back in the man-cave. Been too long since I had a chance to power up the soldering irons..
                  Anyways, I've mounted the first of the second prototype spin, so next up is getting firmware written, and tested..
                  • scalzS
                    scalzS
                    @tbowmo: it looks very nice. I like the way you place components. I think I need to look more at your design and learn :wink:
                    With a firmware, it looks promising :smiley:
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @scalz
                      Thanks :) I hope that I at least can get some LED's flashing tonight :). And then perhaps the bootloader programmed.
                      / Thomas
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        And we have lights..
                        https://www.youtube.com/watch?v=SHNmJMJg2b8
                        • scalzS
                          scalzS
                          yeah :smile:
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            A small update before I hit the bed tonight..
                            I've got radio up and running on the SAMD, and got the first message from one of my sensebender micros through to my pc.
                            It's still in debug mode, using a serial port on the samd as output (And my logic analyzer to decode the serial stream). So no ethernet / wifi or the like up yet.
                            The next step will be to have it use USB instead of the serial port..
                            • AnticimexA
                              AnticimexA
                              Anticimex
                              :+1: good work!
                              • sundberg84S
                                Great! I will buy one of these as soon as this is working as you want :)
                                • alexsh1A
                                  alexsh1A
                                  alexsh1
                                  Wow - excellent! I'd buy one
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    a new small update..
                                    Got it working as a serial GW.. Receiving the first messages from one of my sensebenders..
                                    Also got the ethernet going, this is not integrated with the mysensors parts though, as I have to refactor nrf / ethernet libraries a bit, in order to support multiple (HW) SPI interfaces..
                                    TD22057T 1 Reply Last reply
                                    • tbowmoT tbowmo
                                      TD22057T
                                      TD22057T
                                      TD22057
                                      Sounds great. I'm definitely interested in using this as a gateway as well. Any chance you're going to add SPI transaction support to those libraries (more info in my post here)? I know there are RFM library versions that have that as well (see here).
                                      tbowmoT 1 Reply Last reply
                                      • TD22057T TD22057
                                        tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @TD22057
                                        Here is more hw spi ports available on this beauty. So radio and ethernet is separated on their own spi bus. There is a 3rd spi bus available on the MYSX connector, that is at free disposal to the end user.
                                        • TD22057T
                                          TD22057T
                                          TD22057
                                          Nice - I forgot that you upgraded and weren't using a 328 processor.
