  3. Gateway device
Gateway device
151 Posts 19 Posters 155.0k Views 21 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @Anticimex
    It doesn't cost anything to add footprints for extra pullup resistors, or decoupling caps. (Other than some time placing them). So I am throwing it in wherever I can..
    I have sticked with 0603 components btw. So it should be easier to hand solder the first prototypes :)
    The board is still 5x5 cm, probably being 4 layer so I can get room for all the wiring.
    AnticimexA 1 Reply Last reply
    • tbowmoT tbowmo
      @Anticimex
      AnticimexA
      AnticimexA
      Anticimex
      @tbowmo
      Ah, did not see a no-mount indicator for it so I assumed it would be mounted by default. I agree on keeping all options open if space allows for it.
      Yes, you probably have to go 4-layer on that. I had some trouble fitting the routs on my sensorboard in that space. And it has less components.
      • tbowmoT
        tbowmoT
        tbowmo
        @Anticimex
        Havent set any components as NM yet ;) just throwing components iñ at the moment
        • RJ_MakeR
          RJ_MakeR
          RJ_Make
          I'm sure I missed it but..... as it stands this can be used as a serial gateway correct?
          RJ_Make
          • tbowmoT tbowmo
            @Salmoides
            I don't own a 3d printer either. it's a secondary thing for me (I'm not that much into mechanical design, I let others do that part :))
            @Anticimex
            It should be able to have both radios connected, yes.. But what about available codespace? (Ok, we've got 4 times as much space as in the 328p).
            The 1284p exist in DIP style, http://dk.mouser.com/ProductDetail/Atmel/ATMEGA1284P-PU/?qs=K8BHR703ZXgaD0L1rKdwiQ%3D%3D Can't be any more breadboard friendly than that :)
            The wifi option is actually @hek's idea. And if we are going to make a pcb, it wouldn't hurt to make it possible, if someone wants to use it.
            I had briefly looked at PoE, but got scared away by the specifications for it :) Think that it's around 48V, and using special magnetics (if you are going to be standards compliant). So need a good switchmode stepdown converter from 48V to 5V. But as it's still on the conceptual state in my head, we might be able to find something that makes it "easy to implement".
            Of course size is not that big an issue here.. But 5x5 is standard for small batch pcb's from many of the cheap china board houses. that's why I would aim at that size.
            Prototyping area could be an option. Also was thinking about throwing in a sensors or two. Again, it's a concept that has to evolve a bit.. Getting inputs and let it sink in, in order to make an awesome board :)
            P
            P
            phil pritchard
            @tbowmo
            re: PoE supply
            http://www.freetronics.com.au/products/power-over-ethernet-regulator-8023af#.VWCsPLmqqko
            is cheap and easy you may be able to piggy back it on the board.
            hope it helps
            phil
            • tbowmoT
              tbowmoT
              tbowmo
              #66
              @ServiceXp
              It could be used as serial gateway, there's a ftdi chip onboard. But also place for Ethernet and WiFi connections, together with both nrf24 module and a rfm69 module.
              Made to be as versatile as possible.
              @phil-pritchard
              Ethernet is an add-on module, so a bit hard to implement Poe circuitry on this board. If we could find w5100 module with Poe, it might work.
              • tbowmoT
                tbowmoT
                tbowmo
                Btw. Would it be an idea to include a sensor onboard? (Si7021)
                • AnticimexA
                  AnticimexA
                  Anticimex
                  I see no reason not to (depending on available space) add footprints for various "standard" sensors in addition to a IO header on the board. I have no idea on what impact it has on the sw to have a gateway report sensor values to "itself" but I see no reason for why that could not be supported (if it isn't already).
                  End of double-negations ;)
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @Anticimex
                    What do you define as "standard" sensors?
                    • tbowmoT tbowmo
                      @Anticimex
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @tbowmo
                      Perhaps an unfortunate label. I guess standard footprints would be a better word. I mean footprints for the most commonly used sensor cases. TO-92, DFN and etc. connected such as the typical sensors (1-wire temps and Si7021 like) will "fit".
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        #71
                        @Anticimex
                        Problem is that each sensor has its own pinout, so you can't make generic footprints.
                        There already is a GPIO header, with 8 pins (4 analog and 4 digital) plus power. So people can make their own daughterboards with sensors. Might convert 2 of them to i2c bus with pull up, and then have si7021 onboard.
                        • pliniosenioreP
                          pliniosenioreP
                          plinioseniore
                          Have you considered Grove plugs for sensors? This can give flexibility and a large enough number of sensors at a reasonable price.
                          Souliss, Arduino and Android based SmartHome and IoT
                          http://www.souliss.net
                          @soulissteam
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @plinioseniore
                            Problem is space on the pcb :) as I see it Grove connectors are big and bulky. I have placed a couple of pinheaders (one 8 pin, and one 12 pins) for external devices right now..
                            • AnticimexA
                              AnticimexA
                              Anticimex
                              I think a header for daughterboards will go far in terms of flexibility.
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                updated the first post in the thread, with links to github project, and pdf of schematics (on github). So it will always point at the latest available one, so I don't have to remember that there is a forum thread to keep updated :)
                                • AnticimexA
                                  AnticimexA
                                  Anticimex
                                  Nice nice. I am very interested in this as I have more or less decided to swap to RF69 from RF24. Both for range and because I like the concept of having the radio handle the encryption on my signed packets (yep, I am paranoid as hell). Unfortunately, it means my current gateway has to go but I have made a "sensor evaluation board" (got the PCBs, still waiting for components). Once I get the components and can verify all the features I put on it I will publish it in this forum for those interested. It will still rely on Arduino modules and such so it is not the hard-core approach like the Sensebender Micro though.
                                  • tbowmoT tbowmo
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @tbowmo
                                    I believe you previously had the interrupt for RF69 connected. But it does not seem to be anymore. Any particular reason for skipping that?
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @Anticimex
                                      I'm still rearranging things in the schematics, in order to get the best board layout :).
                                      Could we go with one combined irq for both radio modules? (rfm69/Nrf24)?
                                      / Thomas
                                      • AnticimexA
                                        AnticimexA
                                        Anticimex
                                        I see no reason why that would not work. I sure hope so as I did that on my board :)
                                        Both radios will never be connected (or at least in use) simultaneously so it should be ok.
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @Anticimex
                                          could be someone got brainfreeze and decided to go with both radios at once in one setup.. On the other hand, we're not using IRQ for the nrf24 at the moment..
