  3. Gateway device
Gateway device
151 Posts 19 Posters 152.9k Views 21 Watching
  • scalzS
    scalzS
    very interesting! I didn't know neutrino, pretty nice board. Seems there will be some work on software part but it is doable like you said. And you will have more power, which is nice for the GW I think, and I like when chip is usb compatible (like pic18f4550 ...). Maybe one day, it will become HID, lol!
    • tbowmoT
      tbowmoT
      tbowmo
      #102
      @scalz
      I didn't know of the neutrino (or arduino zero) before @blacey mentioned it to me, and he finally got me convinced that I should swap the atmega1284. (I know that @axillent tried to convince me to use another chip, than the atmega, before.. But when you find this, and it can reduce board complexity..)
      • scalzS
        scalzS
        @tbowmo: it is likely same things for me. lots of 8/16bits chip collection (microchip). but never moved to 32bit even if i have a 32bit usb bit wacker (not time to test it). I was thinking that you can do lot of things with 8bit chips. So yesterday, I have read a little the datasheet atsamd21. Wow, 1077 pages! But there is lots lots of features! I think I will try to order one sample for my collection! Plus, these chips seems to be not expensive but there is some learning curve on it. I think Microchip have missed a big move with arduino platform!
        • tbowmoT
          tbowmoT
          tbowmo
          A couple of late night shots, of the progress..
          Getting ready for the first prototype spin of the board
          • RJ_MakeR
            RJ_MakeR
            RJ_Make
            That right there is a work of art!
            RJ_Make
            • NeverDieN
              NeverDieN
              You may be interested in this Arduino shield:
              http://www.ebay.com/itm/WireLess-Gate-Shield-DIY-Maker-Seeed-BOOOLE-/171713943896?hash=item27faf2d958
              It has both NRF24L01+ and RFM69HW radios.
              • 5546dug5
                5546dug5
                5546dug
                @tbowmo this gw is looking good, hope the prototypes get to you soon!
                • tbowmoT
                  tbowmoT
                  tbowmo
                  #108
                  The first pcb's have arrived today.
                  They came a bit faster from dirtypcbs.com, than I had expected. So haven't even sourced the components yet.
                  So need to look into that the next couple of days.
                  with W5100 / NRF module "mounted" :
                  RJ_MakeR 1 Reply Last reply
                  • tbowmoT tbowmo
                    RJ_MakeR
                    RJ_MakeR
                    RJ_Make
                    @tbowmo No mounting holes?
                    RJ_Make
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @ServiceXp
                      As we need to bring things to life on a new MCU core (Cortex M0), I decided to just make a "simple" dev board, without holes. They will probably be added on the next iteration of the board. (Besides that, 3 of the corners are a bit crammed with components, so no place for the holes anyway.)
                      • scalzS
                        scalzS
                        @tbowmo: very beautiful board. I can't wait to see how it will work. And your feedback about dirtypcb. I often use seeed for their price. But dirty seems good too regarding their shipping rates. I like osh sometimes for their beautiful boards.
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @scalz
                          Haven't tried any of the other "cheap" board houses. But I'm glad for the quality that dirtypcbs are delivering, and the price can't be argued about..
                          • scalzS
                            scalzS
                            thx good to know.
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              things are beginning to take form..
                              First arduino sketch are running on the GW
                              Proof is here :)
                              • scalzS
                                scalzS
                                great :clap:
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  Just learned a lesson the hard way, the last couple of days.. Discovered that I hadn't read the datasheet for the atsamd21 good enough, so I had connected all the PINS for the SPI / UARTs completely wrong. Which means 10-12 connections that was wrong (the board uses 3 SPI ports and 2 UARTs, one SPI doubles as UART, depending on the network interface connected)
                                  So new boards are in the pipeline from dirtypcbs.com
                                  This is btw improved on a couple of other points, compared to the previous board. Biggest is, that it now has 4 x 3mm mounting holes, (happy now @ServiceXp ? :)). It also got a couple of extra solder jumpers on the backside, that could be used for software configurations, or test points.
                                  • scalzS
                                    scalzS
                                    @tbowmo: what a bad luck! but it is so easy to miss something when you look at the datasheet size :wink:
                                    I hope you will get it working like you want, I am sure :smiley:
                                    I like your enlarged pads for 0402. Is it easier to solder like this? Do you handsolder it? Do you think using 0603/0805 with no enlarged pads would take same place???I am asking this for my future designs, in case. But 0402 is so small...
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @scalz
                                      I'm using 0603 components this time, as I'm not under that big a space constraint, as on the sensebender micro.
                                      The biggest issue is the finepitched SAMD21, have to be extra careful not to make solder bridges between the pins..
                                      • scalzS
                                        scalzS
                                        @tbowmo: 0603, cool. I have some samd21 sample but have not tried to solder them. it looks tiny but I think I will be able but not without some :cold_sweat:
                                        thank you for your precision :smile:
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @scalz
                                          atsamd21 comes in 3 variants, with 32, 48 og 64 pins (If I remember right). I'm using the 64 pin variant
                                          If things go well with this one, then I might make a sensebender micro 2, with an 32 pin atsamd20 (almost the same as d21, but without USB host/slave capabilities)
