  3. Domoticz
  4. Doubled devices
Doubled devices
2 Posts 2 Posters 1.2k Views 2 Watching
  • xliborX
    xliborX
    xlibor
    wrote on last edited by xlibor
    Hi, i have problem with my domoticz and mysensors temp and humidity sensors, sometimes is recognized as one device with temp and humidity, sometimes as temp only and humidity only device with different ID, can anyone help me?
    I use RPi 3B with domoticz and local network gateway with SPI NRF24L01+
    • F
      F
      Flyer
      I have a similar issue with domoticz and ethernet gateway wired with W5100 ethernet shield.
      On the ehternet gateway only one temperature sensor is attached (DS18B20).
      I have checked that also nodes list is strange:
      Any suggestion?
      I will try by changing the protocol to MQTT but you look to have same problem (you have radio) and so the way to connect the gateway doesn't look to have influence.
