  3. Signing and mysterious !MCO:PRO:RC=1
recursive callsigningmcoprorc1
2 Posts 2 Posters 333 Views 2 Watching
  • G
    G
    Geelbuik
    Dear forum,
    Your help is very much appreciated. When I turn on signing my gateway shows !MCO:PRO:RC=1.
    I have several relay nodes with ATSHA204A and RFM69 HW all prepared with the security personalizer, running mysensors 2.3.2 (not using the new driver) and #define MY_SIGNING_ATSHA204 / #define MY_SIGNING_REQUEST_SIGNATURES in the sketch.
    The gateway is a sensebender also prepared with security personalizer, etc. I have put an ifndef around <drivers/ATSHA204/ATSHA204.cpp>. The gateway is a serial and runs mysensors 2.3.2.
    I do not use a send within receive. Neither in the nodes nor in the gateway.
    The nodes and gateway communicate well when MY_SIGNING_REQUEST_SIGNATURES is disabled. When I turn MY_SIGNING_REQUEST_SIGNATURES on in the node the gateway starts having problems with !MCO:PRO:RC=1 in the log.
    I have tested my setup with two ESP8266 WIFI gateways and other RFM69 HW modules. With these alternatives I experience the same problem.
    When I plugin an old ESP8266 Wifi gateway with Mysensors 2.2.0. all is working perfect with signing requested enabled in the nodes.
    0;255;3;0;9;107234 TSF:MSG:READ,61-61-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;107235 TSF:MSG:BC
    0;255;3;0;9;107235 TSF:MSG:FPAR REQ,ID=61
    0;255;3;0;9;107235 TSF:PNG:SEND,TO=0
    0;255;3;0;9;107236 TSF:CKU:OK
    0;255;3;0;9;107236 TSF:MSG:GWL OK
    0;255;3;0;9;107976 SGN:SKP:MSG CMD=3,TYPE=8
    0;255;3;0;9;107984 TSF:MSG:SEND,0-0-61-61,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    0;255;3;0;9;109269 TSF:MSG:READ,61-61-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    0;255;3;0;9;109269 TSF:MSG:PINGED,ID=61,HP=1
    0;255;3;0;9;109275 SGN:SKP:MSG CMD=3,TYPE=25
    0;255;3;0;9;109486 TSF:MSG:SEND,0-0-61-61,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    0;255;3;0;9;109526 TSF:MSG:READ,61-61-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
    0;255;3;0;9;109526 SGN:PRE:SGN REQ,FROM=61
    0;255;3;0;9;109558 SGN:PRE:SGN NREQ,TO=61
    0;255;3;0;9;109558 SGN:PRE:WHI NREQ,TO=61
    0;255;3;0;9;109559 SGN:SKP:MSG CMD=3,TYPE=15
    0;255;3;0;9;109566 TSF:MSG:SEND,0-0-61-61,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    0;255;3;0;9;109567 SGN:PRE:XMT,TO=61
    0;255;3;0;9;109590 TSF:MSG:READ,61-61-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.2
    61;255;0;0;17;2.3.2
    0;255;3;0;9;109610 TSF:MSG:READ,61-61-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
    61;255;3;0;6;0
    0;255;3;0;9;111844 TSF:MSG:READ,61-61-0,s=255,c=3,t=11,pt=0,l=25,sg=0:RelayActuatorSignalReport
    61;255;3;0;11;RelayActuatorSignalReport
    0;255;3;0;9;111870 TSF:MSG:READ,61-61-0,s=255,c=3,t=12,pt=0,l=2,sg=0:V1
    61;255;3;0;12;V1
    0;255;3;0;9;112090 TSF:MSG:READ,61-61-0,s=1,c=0,t=3,pt=0,l=12,sg=0:Test relay 1
    61;1;0;0;3;Test relay 1
    0;255;3;0;9;112324 TSF:MSG:READ,61-61-0,s=2,c=0,t=3,pt=0,l=12,sg=0:Test relay 2
    61;2;0;0;3;Test relay 2
    0;255;3;0;9;112446 TSF:MSG:READ,61-61-0,s=10,c=0,t=23,pt=0,l=19,sg=0:UPLINK QUALITY RSSI
    61;10;0;0;23;UPLINK QUALITY RSSI
    0;255;3;0;9;112567 TSF:MSG:READ,61-61-0,s=11,c=0,t=23,pt=0,l=12,sg=0:TX LEVEL DBM
    61;11;0;0;23;TX LEVEL DBM
    0;255;3;0;9;112697 TSF:MSG:READ,61-61-0,s=12,c=0,t=23,pt=0,l=16,sg=0:TX LEVEL PERCENT
    61;12;0;0;23;TX LEVEL PERCENT
    0;255;3;0;9;112833 TSF:MSG:READ,61-61-0,s=13,c=0,t=23,pt=0,l=7,sg=0:TX RSSI
    61;13;0;0;23;TX RSSI
    0;255;3;0;9;112957 TSF:MSG:READ,61-61-0,s=14,c=0,t=23,pt=0,l=7,sg=0:RX RSSI
    61;14;0;0;23;RX RSSI
    0;255;3;0;9;113076 TSF:MSG:READ,61-61-0,s=15,c=0,t=23,pt=0,l=6,sg=0:TX SNR
    61;15;0;0;23;TX SNR
    0;255;3;0;9;113195 TSF:MSG:READ,61-61-0,s=16,c=0,t=23,pt=0,l=6,sg=0:RX SNR
    61;16;0;0;23;RX SNR
    0;255;3;0;9;113219 TSF:MSG:READ,61-61-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
    0;255;3;0;9;113224 SGN:SKP:MSG CMD=3,TYPE=16
    0;255;3;0;9;113434 TSF:MSG:SEND,0-0-61-61,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
    0;255;3;0;9;113435 SGN:SGN:NCE REQ,TO=61
    0;255;3;0;9;113435 !MCO:PRO:RC=1
    0;255;3;0;9;113436 !MCO:PRO:RC=1
    0;255;3;0;9;113437 !MCO:PRO:RC=1
    0;255;3;0;9;113438 !MCO:PRO:RC=1
    0;255;3;0;9;113439 !MCO:PRO:RC=1
    0;255;3;0;9;113440 !MCO:PRO:RC=1
    0;255;3;0;9;113441 !MCO:PRO:RC=1
    0;255;3;0;9;113442 !MCO:PRO:RC=1
    0;255;3;0;9;113443 !MCO:PRO:RC=1
    0;255;3;0;9;113444 !MCO:PRO:RC=1
    0;255;3;0;9;113445 !MCO:PRO:RC=1
    0;255;3;0;9;113446 !MCO:PRO:RC=1
    0;255;3;0;9;113447 !MCO:PRO:RC=1
    0;255;3;0;9;113448 !MCO:PRO:RC=1
    0;255;3;0;9;113449 !MCO:PRO:RC=1
    0;255;3;0;9;113450 !MCO:PRO:RC=1
    0;255;3;0;9;113451 !MCO:PRO:RC=1
    0;255;3;0;9;113452 !MCO:PRO:RC=1
    0;255;3;0;9;113453 !MCO:PRO:RC=1
    0;255;3;0;9;113454 !MCO:PRO:RC=1
    0;255;3;0;9;113455 !MCO:PRO:RC=1
    0;255;3;0;9;113456 !MCO:PRO:RC=1
    0;255;3;0;9;113457 !MCO:PRO:RC=1
    0;255;3;0;9;113458 !MCO:PRO:RC=1
    0;255;3;0;9;113459 !MCO:PRO:RC=1
    0;255;3;0;9;113460 !MCO:PRO:RC=1
    0;255;3;0;9;113461 !MCO:PRO:RC=1
    0;255;3;0;9;113462 !MCO:PRO:RC=1
    0;255;3;0;9;113463 !MCO:PRO:RC=1
    0;255;3;0;9;113464 !MCO:PRO:RC=1
    0;255;3;0;9;113465 !MCO:PRO:RC=1
    0;255;3;0;9;113470 TSF:MSG:READ,61-61-0,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
    0;255;3;0;9;113470 SGN:NCE:FROM=61
    0;255;3;0;9;113470 SGN:BND:NONCE=5FC416FDCE1A4FFE9828828D5A212C90A5A287C19B97E6C295AAAAAAAAAAAAAA
    0;255;3;0;9;113568 SGN:BND:HMAC=43C69D121F2941470A498195982E0EE32D88016257F4D011447DD0643672CCF3
    0;255;3;0;9;113569 SGN:SGN:SGN
    0;255;3;0;9;113580 TSF:MSG:SEND,0-0-61-61,s=255,c=3,t=27,pt=1,l=1,sg=1,ft=0,st=OK:1
    0;255;3;0;9;113756 TSF:MSG:READ,61-61-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;113757 TSF:MSG:BC
    0;255;3;0;9;113757 TSF:MSG:FPAR REQ,ID=61
    0;255;3;0;9;113757 TSF:CKU:OK,FCTRL
    0;255;3;0;9;113758 TSF:MSG:GWL OK
    0;255;3;0;9;113852 SGN:SKP:MSG CMD=3,TYPE=8
    0;255;3;0;9;113864 TSF:MSG:SEND,0-0-61-61,s=255,c=3,t=8,pt=1,l=1,sg=1,ft=0,st=OK:0
    0;255;3;0;9;115785 TSF:MSG:READ,61-61-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    0;255;3;0;9;115785 TSF:MSG:PINGED,ID=61,HP=1
    0;255;3;0;9;115791 SGN:SKP:MSG CMD=3,TYPE=25
    0;255;3;0;9;116008 TSF:MSG:SEND,0-0-61-61,s=255,c=3,t=25,pt=1,l=1,sg=1,ft=0,st=OK:1
    0;255;3;0;9;116041 TSF:MSG:READ,61-61-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
    0;255;3;0;9;116042 SGN:PRE:SGN REQ,FROM=61
    0;255;3;0;9;116074 SGN:PRE:SGN NREQ,TO=61
    0;255;3;0;9;116074 SGN:PRE:WHI NREQ,TO=61
    0;255;3;0;9;116074 SGN:SKP:MSG CMD=3,TYPE=15
    0;255;3;0;9;116082 TSF:MSG:SEND,0-0-61-61,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    0;255;3;0;9;116083 SGN:PRE:XMT,TO=61
    0;255;3;0;9;116104 TSF:MSG:READ,61-61-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.2
    61;255;0;0;17;2.3.2
    0;255;3;0;9;116125 TSF:MSG:READ,61-61-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
    61;255;3;0;6;0
    0;255;3;0;9;118363 TSF:MSG:READ,61-61-0,s=255,c=3,t=11,pt=0,l=25,sg=0:RelayActuatorSignalReport
    0;255;3;0;9;118390 TSF:MSG:READ,61-61-0,s=255,c=3,t=12,pt=0,l=2,sg=0:V1
    61;255;3;0;12;V1
    0;255;3;0;9;118623 TSF:MSG:READ,61-61-0,s=1,c=0,t=3,pt=0,l=12,sg=0:Test relay 1
    0;255;3;0;9;118846 TSF:MSG:READ,61-61-0,s=2,c=0,t=3,pt=0,l=12,sg=0:Test relay 2
    0;255;3;0;9;118967 TSF:MSG:READ,61-61-0,s=10,c=0,t=23,pt=0,l=19,sg=0:UPLINK QUALITY RSSI
    0;255;3;0;9;119092 TSF:MSG:READ,61-61-0,s=11,c=0,t=23,pt=0,l=12,sg=0:TX LEVEL DBM
    0;255;3;0;9;119215 TSF:MSG:READ,61-61-0,s=12,c=0,t=23,pt=0,l=16,sg=0:TX LEVEL PERCENT
    0;255;3;0;9;119340 TSF:MSG:READ,61-61-0,s=13,c=0,t=23,pt=0,l=7,sg=0:TX RSSI
    0;255;3;0;9;119458 TSF:MSG:READ,61-61-0,s=14,c=0,t=23,pt=0,l=7,sg=0:RX RSSI
    0;255;3;0;9;119581 TSF:MSG:READ,61-61-0,s=15,c=0,t=23,pt=0,l=6,sg=0:TX SNR
    61;15;0;0;23;TX SNR
    0;255;3;0;9;119701 TSF:MSG:READ,61-61-0,s=16,c=0,t=23,pt=0,l=6,sg=0:RX SNR
    61;16;0;0;23;RX SNR
    0;255;3;0;9;119721 TSF:MSG:READ,61-61-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
    0;255;3;0;9;119726 SGN:SKP:MSG CMD=3,TYPE=16
    0;255;3;0;9;119944 TSF:MSG:SEND,0-0-61-61,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
    0;255;3;0;9;119945 SGN:SGN:NCE REQ,TO=61
    0;255;3;0;9;119945 !MCO:PRO:RC=1
    0;255;3;0;9;119946 !MCO:PRO:RC=1
    0;255;3;0;9;119947 !MCO:PRO:RC=1
    0;255;3;0;9;119948 !MCO:PRO:RC=1
    0;255;3;0;9;119949 !MCO:PRO:RC=1
    0;255;3;0;9;119950 !MCO:PRO:RC=1
    0;255;3;0;9;119951 !MCO:PRO:RC=1
    0;255;3;0;9;119952 !MCO:PRO:RC=1
    0;255;3;0;9;119953 !MCO:PRO:RC=1
    0;255;3;0;9;119954 !MCO:PRO:RC=1
    0;255;3;0;9;119955 !MCO:PRO:RC=1
    0;255;3;0;9;119956 !MCO:PRO:RC=1
    0;255;3;0;9;119957 !MCO:PRO:RC=1
    0;255;3;0;9;119958 !MCO:PRO:RC=1
    0;255;3;0;9;119959 !MCO:PRO:RC=1
    0;255;3;0;9;119960 !MCO:PRO:RC=1
    0;255;3;0;9;119961 !MCO:PRO:RC=1
    0;255;3;0;9;119962 !MCO:PRO:RC=1
    0;255;3;0;9;119963 !MCO:PRO:RC=1
    0;255;3;0;9;119964 !MCO:PRO:RC=1
    0;255;3;0;9;119965 !MCO:PRO:RC=1
    0;255;3;0;9;119966 !MCO:PRO:RC=1
    0;255;3;0;9;119967 !MCO:PRO:RC=1
    0;255;3;0;9;119968 !MCO:PRO:RC=1
    0;255;3;0;9;119969 !MCO:PRO:RC=1
    0;255;3;0;9;119970 !MCO:PRO:RC=1
    0;255;3;0;9;119971 !MCO:PRO:RC=1
    0;255;3;0;9;119972 !MCO:PRO:RC=1
    0;255;3;0;9;119973 !MCO:PRO:RC=1
    0;255;3;0;9;119974 !MCO:PRO:RC=1
    0;255;3;0;9;119975 !MCO:PRO:RC=1
    0;255;3;0;9;119979 TSF:MSG:READ,61-61-0,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
    0;255;3;0;9;119980 SGN:NCE:FROM=61
    0;255;3;0;9;119980 SGN:BND:NONCE=07DF546949253DA0F51A921B7F8200DD36482663FBC8D8CE60AAAAAAAAAAAAAA
    0;255;3;0;9;120079 SGN:BND:HMAC=F506482D17A7F0E4DE768EBACC1E4128777D9BEF6C2C1C77CA8644B06F7DA207
    0;255;3;0;9;120079 SGN:SGN:SGN
    0;255;3;0;9;120091 TSF:MSG:SEND,0-0-61-61,s=255,c=3,t=27,pt=1,l=1,sg=1,ft=0,st=OK:1
    Who can help troubshooting this issue?
    YveauxY 1 Reply Last reply
    • G Geelbuik
      Dear forum,
      61;255;0;0;17;2.3.2
      61;255;3;0;6;0
      61;255;3;0;12;V1
      61;15;0;0;23;TX SNR
      61;16;0;0;23;RX SNR
      61;255;0;0;17;2.3.2
      61;255;3;0;6;0
      61;255;3;0;12;V1
      61;15;0;0;23;TX SNR
      61;16;0;0;23;RX SNR
      YveauxY
      YveauxY
      @Geelbuik it is a known issue, see https://github.com/mysensors/MySensors/issues/1458
