  3. LoRa Gpio serial gateway
3 Posts 2 Posters 582 Views 2 Watching
  • garfiusG
    garfiusG
    garfius
    wrote on last edited by garfius
    Hi!
    I am trying to set up a lora gateway, and i found a BIG inconvenience. Cannot be used via GPIO serial ports?!¿
    Hardware:
    -Raspberry pi 3b
    -Arduino pro mini 3.3v
    -Ra-01 (Ai-Thinker)
    Comment:
    LoRa node already tested.
    Gateway only works if i manually reset the arduino at the time Hass opens the serial port.
    IMPORTANT NOTE:
    This is normal beheaviour for arduinos with USB-Serial conversor included.
    I can try to copy the beheaviour using DTR pin on FT232, but simply don't knoww a way to copy the beheaviour using GPIO serial ports.
    Seems Hass waits for MySensors gateway boot message, but gateway is already up since time.
    But everithing works well i push reset button on message: "INFO (MainThread) [mysensors] Connected to Serial<..."
    So.
    Is there any way out?
    • pihomeP
      pihomeP
      pihome
      i havent tested lora on serial gateway but i had issues using 3.3v arduino, for me fix was 5v arduino with logic converter.
      PiHome - Smart Heating Control
      garfiusG 1 Reply Last reply
      • pihomeP pihome
        garfiusG
        garfiusG
        garfius
        @pihome Please read full coment before answering.
        I wrote: ...everithing works well i push reset button on...
