  3. RFM69 sub band/channel?
3 Posts 2 Posters 500 Views 2 Watching
  • P
    P
    p359
    Hi. I've found some old parts in a clear out, labelled 915Mhz RFM69. Before using them, I see online a mixture of info for Australia. This one is from Things Network which I'd hope is accurate:
    "For AU915, we use Frequency Sub Band 2, also known as channels 8-15, or 916.8MHz through to 918.2MHz."
    Anyway to achieve this in mysensors or might be over thinking this? Have read the api docs best I can and nothing jumps out, only network ID. Just to check. Cheers!
    • P p359
      @p359 The Things Network use LoRa radios. RFM69 is not a LoRa radio so the information from TTN is not relevant.
      • P
        P
        p359
        Ah crikey, you're right there. Thanks @mfalkvidd, time to dust off the soldering iron.
        Cheers
