  3. Understanding Message code
6 Posts 3 Posters 4.1k Views 1 Watching
  • J
    J
    jmmorgan
    I need to understand message coding better. The overview is fine, but I was hoping for a link that would explain it more (i.e. what it message_s? etc).
    John
      message_s contains the actual message that is transferred over the air. It contains of a header and a payload.
      The payload is the actual message you want to transfer from sensor. Like 23.7 degres.
      The header contains meta information like destination, which sensor is reporting etc. The header is needed for routing the message to its destination and for interpreting the message on the other end.
      • J
        J
        jmmorgan
        So were to you find the syntax to parse the header such as message.header.??? And what is "atoi (message.data)". I hate to keep asking questions, if there is some place I could read up on it.
        BulldogLowellB hekH 2 Replies Last reply
        • J jmmorgan
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @jmmorgan said:
          message.data is the return of gw.getMessage and atoi() is an (arduino) C function to convert a string to an integer, so:
          atoi (message.data) returns the message.data as an integer
          Use that if you are moving integers from server side.
          if you are moving Strings:
          messageString = String(message.data)
          • J jmmorgan
            @jmmorgan
            Why would you like to parse the header? And by what?
            You probably need to pick up some of the c++ basics first. There free online :book: and we linked a couple of physical ones on the API page.
              @jmmorgan
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              I would also recommend Beginning C in Arduino, which is a great start. It has practical examples you can test with your Arduino. Downside is that it has a terrible index and is pricey. Borrow it, don't buy it! ;)
