  3. Ethernet Gateway Using PCBWAY board Fifisoft57
gatewaypcb mysensors gateway ethernet
5 Posts 2 Posters 1.0k Views 2 Watching
  • N
    N
    Newzwaver
    Hi Everyone,
    I am trying to add a gateway to anther project and this time I am using the W5100 mini and the PCBWAY board designed by FIFIsoft57 (hopefully you see this). The code for the gateway I beleive had to be changed. PLease see my modes below any guidance would be greatly appreciated. This is the PCB MySensors Gateway Ethernet 3.0.
     * Version 1.0 - Henrik Ekblad
     * Contribution by a-lurker and Anticimex
     * Contribution by Tomas Hozza <thozza@gmail.com>
     * LED purposes:
     * - To use the feature, uncomment MY_DEFAULT_xxx_LED_PIN in the sketch below
     * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
     * - ERR (red) - fast blink on error during transmission error or receive crc error
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_W5100
    #define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #define MY_SOFT_SPI_SCK_PIN A0 // CHanged from D14
    #define MY_SOFT_SPI_MISO_PIN A2 // CHanged from D16
    #define MY_SOFT_SPI_MOSI_PIN A1 // Changed from D15
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
    #define MY_IP_ADDRESS 192,168,2,203
    #define MY_PORT 5003
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
    //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
    // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
    #define MY_MAC_ADDRESS 0xDD, 0xDD, 0xBE, 0xEF, 0xFE, 0xED
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #define MY_DEFAULT_ERR_LED_PIN 8  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  7  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    and this is what message I receive.
    0 MCO:BGN:INIT GW,CP=RNNGA---,FQ=16,REL=255,VER=2.3.2
    4 TSM:INIT
    5 TSF:WUR:MS=0
    11 !TSM:INIT:TSP FAIL
    13 TSM:FAIL:CNT=1
    15 TSM:FAIL:DIS
    16 TSF:TDI:TSL
    4 TSM:INIT
    5 TSF:WUR:MS=0
    13 TSM:FAIL:CNT=1
    15 TSM:FAIL:DIS
    16 TSF:TDI:TSL
    10019 TSM:FAIL:RE-INIT
    10021 TSM:INIT
    10028 !TSM:INIT:TSP FAIL
    10030 TSM:FAIL:CNT=2
    10032 TSM:FAIL:DIS
    10034 TSF:TDI:TSL
    YveauxY 1 Reply Last reply
    • N Newzwaver
      Hi Everyone,
       * LED purposes:
      #define MY_SOFTSPI
      4 TSM:INIT
      5 TSF:WUR:MS=0
      13 TSM:FAIL:CNT=1
      15 TSM:FAIL:DIS
      16 TSF:TDI:TSL
      4 TSM:INIT
      5 TSF:WUR:MS=0
      13 TSM:FAIL:CNT=1
      15 TSM:FAIL:DIS
      16 TSF:TDI:TSL
      10021 TSM:INIT
      10032 TSM:FAIL:DIS
      10034 TSF:TDI:TSL
      YveauxY
      YveauxY
      @Newzwaver said in Ethernet Gateway Using PCBWAY board Fifisoft57:
      !TSM:INIT:TSP FAIL
      This indicates there's a communication issue with the radio module. Start your debugging there.
      N 2 Replies Last reply
      • YveauxY Yveaux
        !TSM:INIT:TSP FAIL
        N
        N
        Newzwaver
        @Yveaux thanks
        • N
          N
          Newzwaver
          HI All.
          Still having problems and this is my first purchase from PCBway not sure if the code need to be changed for this board but I am using PCB MySensors Gateway Ethernet 3.0 developed by fifisoft57. The radios work on other projects and it is almost like the pins are not correct I traced them and they appear right but......... Has anyone used this board if so did you have any issues? I would say it is my solder job but I did 3 boards one should work.
          ANy help would be great.
          • YveauxY Yveaux
            !TSM:INIT:TSP FAIL
            N
            N
            Newzwaver
            wrote on last edited by Newzwaver
            @Yveaux
            Should have dove deeper when you fist said radio, looks like everything was taken care off except the radio power. Jumped a wire over there and bang worked.
            Thanks again for the help.
