  3. AM312 with no delay
AM312 with no delay
5 Posts 3 Posters 946 Views 3 Watching
  • H Offline
    H Offline
    halipte
    Hi! I bought five AM312 PIR-sensors but just realized that there is a delay from motion until action. Is there a similar PIR (same specification and size) but with no delay?
    I would like to trigger the output as fast as possible when motion is detected.
    Best regards
    Halipte
    skywatchS V 2 Replies Last reply
    • H halipte
      Best regards
      Halipte
      skywatchS Offline
      skywatchS Offline
      skywatch
      @halipte The microwave 'radar' modules seem to trigger pretty fast - With PIR it depends a lot on ambient temperature of the area the pir is 'looking' at and the temperature of the moving object.
      • H halipte
        Best regards
        Halipte
        V Offline
        V Offline
        virtualmkr
        @halipte
        Hi, have you tried these ones? HC-SR501 PIR
        For me they work faster than the AS312.
        For the AS312 I use this one:
        Wemos PIR shield
        H 1 Reply Last reply
        • V virtualmkr
          @halipte
          Wemos PIR shield
          H Offline
          H Offline
          halipte
          @virtualmkr Hi, thanks! I haven´t tried that one. How much faster (approx) are they? If possible I would like to trigger the output immediately there is movement.
          Regarding the Wemos PIR shield, how do you mean you use it? Together with the AM312?
          Best regards
          Halipte
          V 1 Reply Last reply
          • H halipte
            Best regards
            Halipte
            V Offline
            V Offline
            virtualmkr
            @halipte Yes, you are right. The AM312 is different from the AS312 which I use.
            see: AM312 Datasheet and AS312 Datasheet
            But both are looking similar. No additional parts are required. For the HC-SR501 PIR there are a lot of additional parts on the module PCB. So at the end I prefer the AS312 to keep my PIR sensor device small and simple.
