  3. Combine sensors in same node
4 Posts 2 Posters 3.5k Views 1 Watching
  • ferpandoF
    ferpandoF
    ferpando
    I know I can connect several sensors of the same type to the same node, but is it possible to connect let's say a light sensor with a temperature one.
    Thanks in advance
    hekH 1 Reply Last reply
    • ferpandoF ferpando
      Thanks in advance
      @ferpando
      Yes, you can use different types of sensors connected to the same Arduino.
      • ferpandoF
        ferpandoF
        ferpando
        Ok, thank you.
        But as far as code goes, do I just merge the codes from the examples?
          Yes, but you need to reconfigure io-pins correctly. Join the discussion here:
          http://forum.mysensors.org/topic/115/implementing-multiple-sensors#780
