  3. Which device I have to use to connect with accelerometer before connecting to my pc?
5 Posts 4 Posters 1.5k Views 4 Watching
  • Yada KijsathanY
    Yada KijsathanY
    Yada Kijsathan
    Hello everyone,
    I am quite new using accelerometer. I would like to get the signal from industrial MEMS accelerometer (1-axis) and do the signal analysis in my pc.
    I know only that I can connect ADXL345 accelerometer to arduino board, then connect to pc. However, for industrial accelerometer is quite different.
    I am not sure which device I have to interface with accelerometer before connecting to my pc.
    I would be appreciate if someone can help me out.
    Thank you!
    P 2 Replies Last reply
    • Yada KijsathanY Yada Kijsathan
      Hello everyone,
      Thank you!
      P
      P
      pbw
      @Yada-Kijsathan .Hello this forum is pretty lazy.
      You must connect the Arduino to the accelerometer board. If you are working with the Arduino IDE, you must load the current library for the accelerometer board. There you will also find out the connection between the Arduino and the accelerometer board. The programmed Arduino then outputs the values ​​on the serial interface, that the computer can read.
        Hello everyone,
        Thank you!
        P
        P
        pbw
        @Yada-Kijsathan said in [Which device I have to use to connect with accelerometer before connecting to my pc?](
        ein bild währe hilfreich.Wenn der ADXL345 auf einem breakboard ist .,wie auf dem Bild!!
        a picture would be helpful. If the ADXL345 is on a breakboard, like the picture!!
        Winkelgeber .png finden Sie den Anschluss in der bibliotek für die arduino_IDE für ADXL345.find the connector in the bibliotek for the arduino_IDE for ADXL345.
        https://github.com/Seeed-Studio/Accelerometer_ADXL345
        • G
          G
          gulshan212
          Hello this is Gulshan Negi
          Well, to connect with an accelerometer, you typically need a device that can communicate with the sensor and send its data to your PC. The specific device you need to use will depend on the type of accelerometer you have and its communication protocol.
          • ZenBlizzardZ
            ZenBlizzardZ
            ZenBlizzard
            When connecting an accelerometer to your PC, consider its communication protocol (I2C or SPI) and the appropriate interface device, like a microcontroller (e.g., Arduino). You may also need additional hardware for voltage adjustment or signal conditioning, depending on the sensor’s specifications.
