  3. Cannot compile sketch with STM32F1 BluePill board
5 Posts 3 Posters 1.5k Views 3 Watching
  • T
    tnick
    I am trying to compile a sketch with mysensors library for a generic STM32F1 BluePill C8 board.
    Arduino IDE throughs me following error: "\Arduino\Sketches\libraries\MySensors/MySensors.h:84:2: error: #error Hardware abstraction not defined (unsupported platform)"
    I have installed the STM32 board definitions from ST.
    Defined board: "Generic STM32F1 series" in the Arduino IDE.
    To my knowledge should the mysensors library work with STM32F1 boards.
    Any idea where the problem could be?
    • T tnick
      @tnick which version of MySensors are you using?
      Are you using the correct board definitions? STM32F1 2019.12.8 (stm32duino)
      • T
        tnick
        I am using the lastest version of the board definition "Arduino Core for STM32 2.10.1". Do I have to use the older 2019.12.8 definitions ?
        • T tnick
          @tnick STM32F1 2019.12.8 (stm32duino) is the version that was active when the latest MySensors release was made. Later versions may or may not work; nobody would know until they tried.
          • dirkjuD
            dirkjuD
            dirkju
            @tnick I know this is an old post, but if it helps you - I've created support for STM32 based on latest STM32duino here. It's currently made to be backward compatible for the existing STM32F1 support, which is what you are struggling. But with a small change you can use the new STM32 HAL support. Let me know if you are interested to give it a try.
            The longer term plan is to remove the existing (old) STM32F1 support in favor of the new and more general STM32 support. (If @mfalkvidd agrees ;-))
