  3. First sensor having radio issues
5 Posts 3 Posters 2.5k Views 2 Watching
  • B
    B
    britcowboy
    Hi Folks,
    I've finally got my gateway up and running (MQTT Client Gateway with a Ethernet Shield on an Uno) - and today I tried adding a temp sensor.
    The temp sensor is reporting this:
    send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
    req node id
    send: 255-255-255-0 s=255,c=3,t=3,pt=0,l=0,st=fail:
    sensor started, id 255
    req node id
    req node id
    req node id
    and the Gateway is reporting this:
    0;0;3;0;9;read: 255-255-255 s=255,c=3,t=7,pt=0,l=0:
    0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,st=fail:0
    0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0:
    What does this imply? Is the radio on the gateway having issues with power (which i've read could happen?) - if so, I don't have any capacitors around at the moment (I'll order some if needbe) but for now, could I wire up a second spare uno to the gateway, wire the 3.3 V from that to the radio, join the grounds of the two unos, thereby essentially running the radio on it's own power supply - will this work for now? Would I need to do the same for the sensor potentially?
    Also what Capacitor value would you recommend?
      mainali
      I am also trying something similar and I get fail in the serial monitor for all the relays I have connected. But after that everything works fine.
      • B
        B
        britcowboy
        Sorry, what did you do for everything to work fine?
        • B
          B
          britcowboy
          wrote on last edited by britcowboy
          Right, I've fixed this, temporarily anyway.
          So I hooked up a spare uno and hooked it's 3v up to the gateway radio, making sure to link all the grounds up. Still not working. So I hooked up an uno to my nano sensors radio and then it all worked perfectly. Now obviously this isn't a permanent solution as I don't want to have to use two power sources for all my sensors, but I have capacitors on order so I'll try with them next week to see if that fixes the problem. But it's definitely a power problem...
          • sj44kS
            sj44kS
            sj44k
            This most probably will be solved with the capacitors installed, here you can find exactly how, I and most people use 4,7u F which is enough.
            http://www.mysensors.org/build/connect_radio
