  3. Building an Ethernet Gateway on an Arduino Mega
31 Posts 16 Posters 33.3k Views 10 Watching
  • bruno araripeB bruno araripe
    hy guys,
    i have a mega bord, and wiznet ethernet shield, and i want to use this whith ethernet getway. i try many configs, but nothing work. please help me.
    B
    B
    brakc
    @bruno-araripe said:
    hy guys,
    Hy,
    I have a same project and same problem.
    please :sweat:
    • O
      O
      otto001
      Did someone get the GW with mega and W5100 working????
      • A
        A
        afick
        Any update ?
        • TD22057T
          TD22057T
          TD22057
          Did you try resetting the board after power on? I guess there are some boards that have issues and need a reset after power on before anything works. See the links in this post: http://forum.mysensors.org/topic/1021/security-introducing-signing-support-to-mysensors/157. The links in that post have a relatively easy fix to implement if it turns out that is the problem.
          • sj44kS
            sj44kS
            sj44k
            Nope but winter season is starting again so I have some spare time not being "outside" so I will be starting this project back up
            • barduinoB barduino
              I have a similar issue with Adafruit CC3000 shield and a Mega.
              After much fidling around I finally got it to work.
              The Adafruit shiled is the same size of an Uno but when connected to a Mega it doesn't get the SCK, MOSI and MISO from the 13,11,12 pins, it gets them from the central connector ICSP as showed on the picture on this thread.
              So first step was to connect the wireless module to the ICSP.
              The second issue is the CSN and CE pins, these can't be connected to 10 and 9 since they are used by the shield. I've used 35 and 34.
              Adjust your code like this:
              #define INCLUSION_MODE_TIME 1 // Number of minutes inclusion mode is enabled
              #define INCLUSION_MODE_PIN 32 // Digital pin used for inclusion mode button
              #define CE_PIN 35
              #define CS_PIN 34
              MyGateway gw(CE_PIN, CS_PIN, INCLUSION_MODE_TIME, INCLUSION_MODE_PIN, 6, 5, 4);
              Even with this, some times I still get a check wires message, others just a bunch of errors about the version.
              This erratic behaviour led me to think about noise on the wireless receiver, so in goes a 10uF.
              Its stable now.
              On a side note I also changed the CE and CS pin assignments on the sensors...
              #define DIGITAL_INPUT_SENSOR 4 // The digital input you attached your motion sensor. (Only 2 and 3 generates interrupt!)
              #define CHILD_ID 1 // Id of the sensor child
              #define CE_PIN 9
              #define CS_PIN 53
              MySensor gw(CE_PIN,CS_PIN);
              // Initialize motion message
              Cheers
              F
              F
              flopp
              #define CE_PIN 35
              #define CS_PIN 34
              Its stable now.
              #define CE_PIN 9
              #define CS_PIN 53
              Cheers
              Hi, can you please share your Gateway code. I also having problem with a CC3000 and Arduino Mega. UNO was too small :)
              barduinoB 1 Reply Last reply
              • F flopp
                #define CE_PIN 35
                #define CS_PIN 34
                Its stable now.
                #define CE_PIN 9
                #define CS_PIN 53
                Cheers
                barduinoB
                barduinoB
                barduino
                I'm sorry @flopp
                It did not work on the end, my shield just stopped working even with an example sketch, so I never completed the project.
                What flavor of CC3000 do you have, the shield with the SD card or the small board with just the wifi module?
                Cheers
                F 1 Reply Last reply
                  I'm sorry @flopp
                  Cheers
                  F
                  F
                  flopp
                  wrote on last edited by flopp
                  #28
                  @barduino
                  EDIT: NOT SD-card
                  • S
                    spugna85
                    wrote on last edited by spugna85
                    #29
                    Here the solution to run Arduino Mega and the shield W5100.
                    Into the file MyConfig.h, after the line:
                    #include <stdint.h>:
                    you must add the following lines:
                    #if ARDUINO < 100
                    	#include <WProgram.h>
                    #else
                           #include <Arduino.h>
                    Then replace the lines:
                    const uint8_t SOFT_SPI_MISO_PIN = 16;
                    const uint8_t SOFT_SPI_MOSI_PIN = 15;
                    const uint8_t SOFT_SPI_SCK_PIN = 14;
                    with these:
                    const uint8_t SOFT_SPI_MISO_PIN = A2;
                    const uint8_t SOFT_SPI_MOSI_PIN = A1;
                    const uint8_t SOFT_SPI_SCK_PIN = A0;
                    Finally enable define SOFTSPI removing the comment (//)
                    Compile and load the software and you're done! :grin:
                    A 1 Reply Last reply
                    • B
                      B
                      bozo
                      hello
                      i've got the ethernet gateway on the mega that work but after a power loose, the ping of the gateway is ok but no more return on the serial monitor even after reset
                      i'm using a external power for the mega and same result with usb power.
                      • S spugna85
                        #if ARDUINO < 100
                        #else
                        with these:
                        A
                        A
                        anibaldiniz
                        @spugna85
                        Hello, I'm putting the code as you indicated, and connecting the nRF24L01 pins:
                        6 CSN
                        5 CE
                        Pin 50, 51, 52
                        and message: 0;0;3;0;9;radio init fail
                        I link capacitor in power, I have done everything. And now????
                        :anguished:
