  3. Building an Ethernet Gateway on an Arduino Mega
31 Posts 16 Posters 33.3k Views 10 Watching
  • sj44kS sj44k
    I am trying to utilize all of my available Arduinos as best as I can, and having all sketches being developed on this site for the UNO my Arduino Mega seems to fit best in it's role as an Ethernet Gateway.
    By this I am able to use my available UNO to do some more testing and playing around with the MySensor sketches without the need to modify my sketches like I did to do in the past
    BUT, having that said this also exactly gives away my challenge :
    Getting the Ethernet Gateway Sketch working on my Arduino Mega with a W5100 Ethernet Shield.
    Issue is the pinout of a Mega's SPI interface is different than the UNO.
    So the sketch is working easily on my UNO, but changing the shield and uploading the same sketch to my MEGA results in a non working Ethernet Gateway (debug modes states : check wires)
    (I did uncomment the #define SOFTSPI line in the RF24_Config.h by the way)
    Does anyone know which file / library I need to edit to change these pins ? I am using the W5100 shield not the module so I would prefer the shield installed as a is, and not use any jumper cables.
    E
    E
    ewgor
    wrote on last edited by ewgor
    @sj44k hi, may i ask if you need a NRF24L01 radio module in order to make this Ethernet Gateway work? I'm asking because i understood that for a Serial Gateway you need this module, other way you cannot test it!
    My second question is if you made it i mean if you can read some sensors using the Ethernet W5100 and the Openhab server?
    Forget the 1st question, i got it...
    Could you please tell me if you made it with Arduino Mega and the Ethernet shield? which are the right pins that needs to be modified in the RF24_Config.h ?
    • E
      E
      ewgor
      everybody in holiday here? nodoby answered on the serial gateway so im asking again here about the ethernet gateway if somebody can tell me/us which are the right pins that needs to be modified to start the ethernet gataway and to test it with openhab?
        @ewgor said:
        NRF24L01
        The NRF or HopeRF RF69 module i central in the MySensors infrastructure as it is centralised around wireless sensors/actuators. Experimental code exist (https://github.com/mysensors/Arduino/tree/gateway-refactoring) which lets you attach sensors to the gateway (serial or ethernet) directly. But this is not documented on the main site yet so you should be comfortable to read up code yourself.
        How to connect ethernet module (and modify configuration) is described on the main site. I haven't personally used a Mega as gateway myself. But I successfully used it as a sensor for the Touch Scene Controller.
        • bruno araripeB
          bruno araripeB
          bruno araripe
          hy guys,
          i have a mega bord, and wiznet ethernet shield, and i want to use this whith ethernet getway. i try many configs, but nothing work. please help me.
          B 1 Reply Last reply
          • bruno araripeB bruno araripe
            hy guys,
            B
            B
            brakc
            @bruno-araripe said:
            hy guys,
            Hy,
            I have a same project and same problem.
            please :sweat:
            • O
              O
              otto001
              Did someone get the GW with mega and W5100 working????
              • A
                afick
                Any update ?
                • TD22057T
                  TD22057T
                  TD22057
                  Did you try resetting the board after power on? I guess there are some boards that have issues and need a reset after power on before anything works. See the links in this post: http://forum.mysensors.org/topic/1021/security-introducing-signing-support-to-mysensors/157. The links in that post have a relatively easy fix to implement if it turns out that is the problem.
                  • sj44kS
                    sj44kS
                    sj44k
                    Nope but winter season is starting again so I have some spare time not being "outside" so I will be starting this project back up
                    • barduinoB barduino
                      I have a similar issue with Adafruit CC3000 shield and a Mega.
                      After much fidling around I finally got it to work.
                      The Adafruit shiled is the same size of an Uno but when connected to a Mega it doesn't get the SCK, MOSI and MISO from the 13,11,12 pins, it gets them from the central connector ICSP as showed on the picture on this thread.
                      So first step was to connect the wireless module to the ICSP.
                      The second issue is the CSN and CE pins, these can't be connected to 10 and 9 since they are used by the shield. I've used 35 and 34.
                      Adjust your code like this:
                      #define INCLUSION_MODE_PIN 32 // Digital pin used for inclusion mode button
                      #define CE_PIN 35
                      #define CS_PIN 34
                      MyGateway gw(CE_PIN, CS_PIN, INCLUSION_MODE_TIME, INCLUSION_MODE_PIN, 6, 5, 4);
                      Even with this, some times I still get a check wires message, others just a bunch of errors about the version.
                      This erratic behaviour led me to think about noise on the wireless receiver, so in goes a 10uF.
                      Its stable now.
                      On a side note I also changed the CE and CS pin assignments on the sensors...
                      #define DIGITAL_INPUT_SENSOR 4 // The digital input you attached your motion sensor. (Only 2 and 3 generates interrupt!)
                      #define CHILD_ID 1 // Id of the sensor child
                      #define CE_PIN 9
                      #define CS_PIN 53
                      MySensor gw(CE_PIN,CS_PIN);
                      // Initialize motion message
                      F
                      F
                      flopp
                      #define CE_PIN 35
                      #define CS_PIN 34
                      Its stable now.
                      #define CE_PIN 9
                      #define CS_PIN 53
                      Hi, can you please share your Gateway code. I also having problem with a CC3000 and Arduino Mega. UNO was too small :)
                      barduinoB 1 Reply Last reply
                      • F flopp
                        #define CE_PIN 35
                        #define CS_PIN 34
                        Its stable now.
                        #define CE_PIN 9
                        #define CS_PIN 53
                        barduinoB
                        barduinoB
                        barduino
                        I'm sorry @flopp
                        It did not work on the end, my shield just stopped working even with an example sketch, so I never completed the project.
                        What flavor of CC3000 do you have, the shield with the SD card or the small board with just the wifi module?
                        F 1 Reply Last reply
                          I'm sorry @flopp
                          F
                          F
                          flopp
                          wrote on last edited by flopp
                          #28
                          @barduino
                          EDIT: NOT SD-card
                            spugna85
                            wrote on last edited by spugna85
                            #29
                            Here the solution to run Arduino Mega and the shield W5100.
                            Into the file MyConfig.h, after the line:
                            #include <stdint.h>:
                            you must add the following lines:
                            #if ARDUINO < 100
                            	#include <WProgram.h>
                                   #include <Arduino.h>
                            Then replace the lines:
                            with these:
                            const uint8_t SOFT_SPI_MISO_PIN = A2;
                            const uint8_t SOFT_SPI_MOSI_PIN = A1;
                            const uint8_t SOFT_SPI_SCK_PIN = A0;
                            Finally enable define SOFTSPI removing the comment (//)
                            Compile and load the software and you're done! :grin:
                            A 1 Reply Last reply
                            • B
                              B
                              bozo
                              hello
                              i've got the ethernet gateway on the mega that work but after a power loose, the ping of the gateway is ok but no more return on the serial monitor even after reset
                              i'm using a external power for the mega and same result with usb power.
                              • S spugna85
                                #if ARDUINO < 100
                                with these:
                                anibaldiniz
                                @spugna85
                                Hello, I'm putting the code as you indicated, and connecting the nRF24L01 pins:
                                6 CSN
                                5 CE
                                Pin 50, 51, 52
                                and message: 0;0;3;0;9;radio init fail
                                I link capacitor in power, I have done everything. And now????
                                :anguished:
