  2. Feature Requests
  3. Keepalive
Keepalive
6 Posts 4 Posters 3.3k Views 1 Watching
  • C Offline
    C Offline
    clippermiami
    I was experimenting with a Temp/Hum sensor this weekend and I noticed that the environment in which the sensor "lives" doesn't change much at all. The code onl;ine skips the send if the last value is the same as the current value. In this case as a result there was no update to the Vera gateway for over 14 hours, to the point where I assumed something might be wrong. So I manually reset the sensor to forcean update.
    How about a "Keepalive" function in the Library that can be included in he sketch to update the Gateway every "N" minutes whether there is a value change or not. One could declare the keepalive period in the sketch, say 1 hour, so that the sensor would send an update to the Gateway even if there was no change.
    • A Offline
      A Offline
      andriej
      And what's the problem with making a loop in code and forcing node to send values?
      • hekH Offline
        hekH Offline
        yes, by default we try to minimize message sending in the examples. But like Andrej says you could just allow it to send one message each X sleep cycle.
        C 1 Reply Last reply
          C Offline
          C Offline
          clippermiami
          @hek Which is what I ended up doing in the code I modified for the triple sensor device. I was merely suggesting that it might be nice to have a standardized keepalive routine in the library, call it and it takes care of it for you.
          • greglG Offline
            greglG Offline
            gregl
            Hi guys ...
            i agree sending the values periodically helps if the radio transmission is not ack'ed. I was testing yesterday a sketch and looks like i have another dodgy radio module. probably 80% packets were successful, but other 20% resulted in Vera not being told the door was open or closed...
            So i added this "hack" which whilst it works could be better coded im sure!!
            if (counter < 1000000){
            counter++ ;
            // Serial.println(counter);
            } else {
            Serial.println("sending status");
            gw.sendVariable(CHILD_ID_DOORA, V_LOCK_STATUS, trippedA?DOOR_CLOSED:DOOR_OPEN); // Send value change to gw
            counter = 0;
            I was thinking... since debug message prints "Ack: received OK" - what if the library repeated the transmission when the ACK was not received.. Hek i do recall a short discussion on this...not sure if its to be in 1.4 or what...
            Cheers,
            • hekH Offline
              hekH Offline
              Next version will use the burst mode which result in much better success rate for packages. I hope you won't need to resent same data.
