  3. Watermeter pulse sensor, mistake in the provided ino file ?
7 Posts 5 Posters 3.9k Views 1 Watching
  • D
    D
    doblanch
    Hello Team,
    I'm using the water pulse meter ino file with jeedom.
    I made some change like this :
    gw.present(CHILD_ID_FLOW, S_WATER);
    gw.present(CHILD_ID_VOL, S_WATER);
    gw.present(CHILD_ID_PCMSG, S_WATER);
    gw.request(CHILD_ID_PCMSG, V_VAR1);
    Compare to the orignal one :
    gw.present(CHILD_ID, S_WATER);
    gw.request(CHILD_ID, V_VAR1);
    I f i don't do this, there is only one child presented to the gateway, and all 3 counters are sent in the same variable. The results on jeedom is only one value is recognized, and when it receives 3 values for the same thing, the variable in jeedom takes 3 different values alternatively... by the way, the gw request VAR1 doesn't work as it's taking the wrong variable...
    From now, it works with these changes, but does I miss something ?
    The right result is presented in the image below. As you can see we need 3 different variables in jeedom.
    Make sense ?
    • A
      A
      andriej
      Interesting catch!
      I'd like to know if these values are reported to domoticz properly - too!
      • D
        D
        doblanch
        wrote on last edited by doblanch
        @andriej These value are reported into the same Variable... so the GW receive 3 different values sequentially...I guess that behavior should be the same on domoticz.
        • L
          L
          lunarok
          Better to give a link to the sketch and copy the original part of code :
          https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/WaterMeterPulseSensor/WaterMeterPulseSensor.ino
          And yes there is only one sensor presentated to the gateway :
          // Register this device as Waterflow sensor
          But there is 3 differents messages created on the same sensor. So there is on this node a waterflower sensor, but also a volume sensor and a counter sensor.
          Why just one sensor ?
          @GizMoCuz I see you have done the latest changes on this sketch and part of it was the declaration of 3 differents messages types with only 1 sensor. Is this volontary ?
          D 1 Reply Last reply
          • L lunarok
            D
            D
            doblanch
            @lunarok said:
            CHILD_ID
            By the way, if I write this "gw.present(CHILD_ID, S_WATER);" , it means that it's only one sensor, and is not able to store 3 differents values.
            Look the screenshot. If I don't declare 3 sensors image, I will have only sensor number 5 for example :-( Hence only flow is reported... in this case, 0 (as there is no flow rate).
            When node register to gateway, it present itself with one sensor and only one value....
            Or maybe it's a jeedom issue, and jeedom is not able to understand 1 sensors, carrying 3 different values...
            • T
              tranbert
              Could you share your ino file ? Sounds interesting for jeedom users :-)
              • MarcoM
                MarcoM
                Marco
                Hello, can you put the entire file .ino modified , I have the same problem as you.
                Thank you
