  3. Battery PIR power consumption
9 Posts 5 Posters 8.1k Views 2 Watching
  • SweebeeS Offline
    SweebeeS Offline
    Sweebee
    wrote on last edited by Sweebee
    I have a HC-SR501 with an arduino pro mini 3.3v. I want to run it on batteries as long as possible. In sleep the setup draws around 280 uA. Thats quite a lot?
    I already removed the power led on the arduino and i use the PIR 3.3v Hack.
    The datasheet of the pirs tells me that it uses around 50 uA (@ 5v). When I only measure the pir it uses around 200 uA. The arduino with NRF around 70 uA without the PIR.
    Is there a way to reduce it? With this setup and 2 AA batteries it won't last a year.
    • J Offline
      J Offline
      Jan Gatzke
      Did you desolder the voltage regulator from the PIR? It can draw some current even when it is not used.
      • SweebeeS Offline
        SweebeeS Offline
        Sweebee
        No, I havent. lets try...
        Edit: I removed the HT7133. The power consumption is not jumping a lot anymore. Sometimes it went from 250 - 320. but now its more stable around 260 uA (with arduino and NRF).
        • A Offline
          A Offline
          Andreas Maurer
          But this is not a big step in the desired direction?!
          • SweebeeS Offline
            SweebeeS Offline
            Sweebee
            @Andreas-Maurer no, not really. Around 160 uA should be fine? Don't know if there is some1 else with a pir sensor on batteries? maybe he can share his experience.
            • hekH Offline
              hekH Offline
              What are you using to measure the consumption? uCurrent?
              • SweebeeS Offline
                SweebeeS Offline
                Sweebee
                I'm using a UNI-T UT136B. Should be quite accurate according EEV.
                • Y Offline
                  Y Offline
                  Please read http://forum.mysensors.org/topic/250/how-do-i-use-the-interrupt/14
                  I measured sleeping current of HC-SR501 (2xAA at 2.86V) at 60uA, using uCurrent.
                  • SweebeeS Offline
                    SweebeeS Offline
                    Sweebee
                    So it should be okay? Even when my meter shows around 180-200 uA with pir only?
