  3. Trouble combining sketches for temp and motion control
24 Posts 6 Posters 10.7k Views 2 Watching
  • S Offline
    #21
    Its a problem with the DHT, the setup between Arduino and DHT sensor i think...
    -Tried another DHT-Sensor or bare DHT code?
    -Tried another inputpin on the arduino (i got this message when i didnt solder the pin properly)
    -Check/change wiring.
    Also try the delay(dht.getMinimumSamplingPeriod()); before the motion sensor code and see if this changes anything.
    D 1 Reply Last reply
    • S sundberg84
      davvvvvo
      @sundberg84 I have two DHT22 sensors which I have tried both. They both work when I run the humidity sketch on its own but not when I try this sketch. Having never written code before this "delay(dht.getMinimumSamplingPeriod());" I have no clue what this is. Also if I used pin 5 for example how would I go changing the code to represent this. Cheers everyone so far for your help fault finding what's wrong with my set up. I don't usually give up but this simple one is testing my patients to the point I might just run a temp sensor on its own.
      S 1 Reply Last reply
      • D davvvvvo
        Sparkman
        @davvvvvo
        "delay(dht.getMinimumSamplingPeriod());" is used to not retrieve info from the DHT22 too often. The sensors don't respond if polled too frequently and this is a function in the DHT library. To change the sketch to use pin 5, change this line:
        #define HUMIDITY_SENSOR_DIGITAL_PIN 6
        to
        #define HUMIDITY_SENSOR_DIGITAL_PIN 5
        Is the sketch you are using identical to the one @hek posted? How are you powering your board?
        Cheers
        Al
        • S Sparkman
          @davvvvvo
          to
          Cheers
          Al
          davvvvvo
          @Sparkman yes it's the same sketch hek uploaded word for word. Powering using a phone charger 5v 1amp. Im putting it down to I might have a faulty pin 6 or the sketch doesn't play well with Vera and the plugin. Does anyone have another sketch?
