  3. Trouble combining sketches for temp and motion control
24 Posts 6 Posters 10.9k Views 2 Watching
  • D davvvvvo
    @Dwalt I'm powering both sensors off the 5v pin on the board so they are sharing the power. Temp is on pin 6. All three nodes added to Vera. I can arm or bypass the motion and this works, the temp and humidity node are on Vera but not showing any numbers. Temp is at 0 degrees and humidity is at 0%. I tried cycling the nodes off and on a few times. With no results.
    DwaltD
    DwaltD
    Dwalt
    @davvvvvo If you eliminate any wiring mistakes, I assume you must have a bad DHT sensor. You could try it without the PIR and load up the basic temp/hum sketch to see if it works or see if you can see anything through the serial log.
    D 1 Reply Last reply
    • DwaltD Dwalt
      davvvvvo
      @Dwalt Just used the DHT sensor on its own and loaded the humidity sketch and it works perfectly. did try and load the dallas temp sketch and that didnt work on its own. Question will i need to upload if there is one someting like a dallas.JSON or or another XML onto vera for hek's sketch to work possibly?
      DwaltD 1 Reply Last reply
      • D davvvvvo
        DwaltD
        DwaltD
        Dwalt
        @davvvvvo The Dallas sensor is completely different from the DHT and does not factor into your setup. The DHT provides both temp and humidity. The Dallas temp sensor uses a separate library for pulling data from that particular sensor. Can you post your serial log from your sensor with both DHT and PIR connected using the sketch Hek provided above? That would tell us what is happening at the communication level between the sensor node and gateway.
        D 3 Replies Last reply
        • DwaltD Dwalt
          davvvvvo
          @Dwalt how do i go about gathering the serial log. Can i plug in the sensor and download the serial log with the arduino program
          • DwaltD Dwalt
            davvvvvo
            • DwaltD Dwalt
              davvvvvo
              @Dwalt
              sensor started, id 2
              send: 2-2-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
              send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
              send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=16,st=ok:Multi Motion+Hum
              send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
              send: 2-2-0-0 s=0,c=0,t=7,pt=0,l=0,st=ok:
              send: 2-2-0-0 s=1,c=0,t=6,pt=0,l=0,st=ok:
              send: 2-2-0-0 s=3,c=0,t=1,pt=0,l=0,st=ok:
              Tripped: 0
              send: 2-2-0-0 s=3,c=1,t=16,pt=0,l=1,st=ok:0
              Failed reading temperature from DHT
              Failed reading humidity from DHT
              Tripped: 0
              Tripped: 0
              • sundberg84S
                sundberg84S
                #21
                Its a problem with the DHT, the setup between Arduino and DHT sensor i think...
                -Tried another DHT-Sensor or bare DHT code?
                -Tried another inputpin on the arduino (i got this message when i didnt solder the pin properly)
                -Check/change wiring.
                Also try the delay(dht.getMinimumSamplingPeriod()); before the motion sensor code and see if this changes anything.
                • sundberg84S sundberg84
                  davvvvvo
                  @sundberg84 I have two DHT22 sensors which I have tried both. They both work when I run the humidity sketch on its own but not when I try this sketch. Having never written code before this "delay(dht.getMinimumSamplingPeriod());" I have no clue what this is. Also if I used pin 5 for example how would I go changing the code to represent this. Cheers everyone so far for your help fault finding what's wrong with my set up. I don't usually give up but this simple one is testing my patients to the point I might just run a temp sensor on its own.
                  SparkmanS 1 Reply Last reply
                  • D davvvvvo
                    SparkmanS
                    SparkmanS
                    Sparkman
                    @davvvvvo
                    "delay(dht.getMinimumSamplingPeriod());" is used to not retrieve info from the DHT22 too often. The sensors don't respond if polled too frequently and this is a function in the DHT library. To change the sketch to use pin 5, change this line:
                    #define HUMIDITY_SENSOR_DIGITAL_PIN 6
                    to
                    #define HUMIDITY_SENSOR_DIGITAL_PIN 5
                    Is the sketch you are using identical to the one @hek posted? How are you powering your board?
                    Al
                    • SparkmanS Sparkman
                      @davvvvvo
                      to
                      Al
                      davvvvvo
                      @Sparkman yes it's the same sketch hek uploaded word for word. Powering using a phone charger 5v 1amp. Im putting it down to I might have a faulty pin 6 or the sketch doesn't play well with Vera and the plugin. Does anyone have another sketch?
