  3. Trouble combining sketches for temp and motion control
24 Posts 6 Posters 10.6k Views 2 Watching
  • 8 Offline
    8 Offline
    8200
    So I am new to building sensors.
    I have managed to build a ethernet gateway and have this connect to my Vera2.
    Furthermore I have succeeded in building temperature and motion sensors.
    So far so good.
    Now I want to combine the sensors in a new sensor - a 230V powered motion and temp sensor (based on a Nano-clone)
    I have search the forum to see if anyone else has made this kind of sensor (for me to copy the sketch) but with no luck.
    I have the tried to combine the temp sketch and the motion sketch from the build-page, into the below sketch but the sketch wont compile. I have no experience in this so my combination is mostly based on gut-feeling :)
    Is there any one who can have a look at the sketch and explain where I go wrong or even better - are there anyone with a similar sensor and working sketch that I can use?
    #include <OneWire.h>
    #define CHILD_ID_MOT 2 // Id of the sensor child
    #define ONE_WIRE_BUS 4 // Pin where dallase sensor is connected
    OneWire oneWire(ONE_WIRE_BUS);
    #define DIGITAL_INPUT_SENSOR 3 // The digital input you attached your motion sensor. (Only 2 and 3 generates interrupt!)
    int numSensors=0;
    boolean metric = true;
    MyMessage msg(0,V_TEMP);
    // Initialize motion message
    MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
    sensors.begin();
    gw.begin();
    gw.sendSketchInfo("Motion Sensor", "1.0");
    gw.present(i, S_TEMP);
    pinMode(DIGITAL_INPUT_SENSOR, INPUT); // sets the motion sensor digital pin as input
    gw.present(CHILD_ID_MOT, S_MOTION);
    gw.sendSketchInfo("Temperature Sensor", "1.0");
    // Read digital motion value
    Serial.println(tripped);
    gw.send(msg.set(tripped?"1":"0")); // Send tripped value to gw
    gw.process();
    if (lastTemperature[i] != temperature && temperature != -127.00) {
    gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    Thanks!
    • H Offline
      H Offline
      Here is a sketch I use myself. A combination of hum/temp (DHT) and motion.
      It reports motion status on motion or every 30 sec.
      #include <DHT.h>
      #define CHILD_ID_HUM 0
      #define CHILD_ID_TEMP 1
      #define CHILD_ID_MOTION 3
      #define HUMIDITY_SENSOR_DIGITAL_PIN 6
      #define MOTION_SENSOR_PIN 3
      #define INTERRUPT MOTION_SENSOR_PIN-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
      DHT dht;
      float lastTemp;
      float lastHum;
      MyMessage msgMotion(CHILD_ID_MOTION, V_TRIPPED);
        gw.begin();
        gw.sendSketchInfo("Multi Motion+Hum", "1.0");
        pinMode(MOTION_SENSOR_PIN, INPUT);      // sets the motion sensor digital pin as input
        gw.present(CHILD_ID_MOTION, S_MOTION);
        boolean tripped = digitalRead(MOTION_SENSOR_PIN) == HIGH;
        Serial.print("Tripped: ");
        gw.send(msgMotion.set(tripped?"1":"0"));  // Send tripped value to gw
        if (isnan(temperature)) {
          lastTemp = temperature;
          if (!metric) {
          Serial.print("T: ");
          Serial.println(temperature);
        if (isnan(humidity)) {
            lastHum = humidity;
            Serial.print("H: ");
            Serial.println(humidity);
      8 1 Reply Last reply
      • H hek
        #include <DHT.h>
        DHT dht;
        float lastTemp;
        float lastHum;
          gw.begin();
            if (!metric) {
              lastHum = humidity;
        8 Offline
        8 Offline
        8200
        @hek Wow - thanks for a fast reply
        I have used a some what similar sketch as a basis and I guess I go wrong when adapting the sketch to the Dallas sensor which I presume is needed?
        • H Offline
          H Offline
          The DHT11/22 sensor gives both temperature and humidity.
          • H hek
            8 Offline
            8 Offline
            8200
            @hek But I was hoping to use the DS18b20?
            • H Offline
              H Offline
              Yep, I know. This was just an example how I combined them to help you a bit while exploring the wonderful world of embedded programming ;)
              • 8 Offline
                8 Offline
                8200
                I am gratefull ;)
                I will try to compare the sketches.
                • D Offline
                  davvvvvo
                  Hek, tried your sketch. Motion works but not getting a temp reading on my Vera. Using the dht 22,sensor onto pin 6. Am I missing something? I'm using the same power that the motion uses on the nano.
                  • S Offline
                    Do you have a bare DHT that needs a resistor?
                    link text
                    What does the serial say?
                    • D Offline
                      davvvvvo
                      It doesnt give a reading for temperature or humidity. Sensor works. Yeah it's the solder free module dht 22 that has the three pronges
                      D 1 Reply Last reply
                      • D davvvvvo
                        Dwalt
                        @davvvvvo Did you re-include the node after changing the sketch? What controller are you using? Post your sketch using the </> tool.
                        • D Dwalt
                          davvvvvo
                          @Dwalt yes I removed the node off Vera U7 and re added it as instructions say. Using Nana serial controller. The motion sensor works perfectly. I'm using hek sketch, I just cut and paste the sketch into to program and compiled and uploaded. Do I need a resistor with the dht 22 temp sensor because I don't have one on it at the moment.
                          • D davvvvvo
                            Dwalt
                            @davvvvvo If you used Hek's sketch above and your DHT is connected to pin 6 and the PIR on pin 3, it should work. How are you powering the DHT and PIR? You should be using the nano's 5v. You do not need a separate resistor on the DHT module (3 pins), it has one onboard the module. Are you seeing the temp and hum child devices in Vera? If so, try powering the node off-on and reloading the Vera page.
                            • D Dwalt
                              davvvvvo
                              wrote on last edited by davvvvvo
                              @Dwalt I'm powering both sensors off the 5v pin on the board so they are sharing the power. Temp is on pin 6. All three nodes added to Vera. I can arm or bypass the motion and this works, the temp and humidity node are on Vera but not showing any numbers. Temp is at 0 degrees and humidity is at 0%. I tried cycling the nodes off and on a few times. With no results.
                              • D davvvvvo
                                Dwalt
                                @davvvvvo If you eliminate any wiring mistakes, I assume you must have a bad DHT sensor. You could try it without the PIR and load up the basic temp/hum sketch to see if it works or see if you can see anything through the serial log.
                                • D Dwalt
                                  davvvvvo
                                  @Dwalt Just used the DHT sensor on its own and loaded the humidity sketch and it works perfectly. did try and load the dallas temp sketch and that didnt work on its own. Question will i need to upload if there is one someting like a dallas.JSON or or another XML onto vera for hek's sketch to work possibly?
                                  • D davvvvvo
                                    Dwalt
                                    @davvvvvo The Dallas sensor is completely different from the DHT and does not factor into your setup. The DHT provides both temp and humidity. The Dallas temp sensor uses a separate library for pulling data from that particular sensor. Can you post your serial log from your sensor with both DHT and PIR connected using the sketch Hek provided above? That would tell us what is happening at the communication level between the sensor node and gateway.
                                    D 3 Replies Last reply
                                    • D Dwalt
                                      davvvvvo
                                      @Dwalt how do i go about gathering the serial log. Can i plug in the sensor and download the serial log with the arduino program
                                      • D Dwalt
                                        davvvvvo
                                        This post is deleted!
                                        • D Dwalt
                                          davvvvvo
                                          @Dwalt
                                          sensor started, id 2
                                          send: 2-2-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                                          send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                                          send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=16,st=ok:Multi Motion+Hum
                                          send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                                          send: 2-2-0-0 s=0,c=0,t=7,pt=0,l=0,st=ok:
                                          send: 2-2-0-0 s=1,c=0,t=6,pt=0,l=0,st=ok:
                                          send: 2-2-0-0 s=3,c=0,t=1,pt=0,l=0,st=ok:
                                          Tripped: 0
                                          send: 2-2-0-0 s=3,c=1,t=16,pt=0,l=1,st=ok:0
                                          Tripped: 0
                                          Tripped: 0
                                          12.1k
