  3. Domoticz
  4. Domoticz wont toggle light switch via ethernet gateway?
7 Posts 3 Posters 4.4k Views 1 Watching
  • K
    K
    kunall
    For my light switch i'm using the example relay actuator sketch. When I try to turn on/off light from Domoticz UI via ethernet gateway it wont work. However, it does update state On/Off light if I toggle the physical push button on the relay.
    On the contrary, everything works fine on Serial gateway. I just tried it and it worked.
    Any solution please? I really want to use ethernet gateway!
    Thanks!
    • S
      Striffster
      I have the same issue, if I use Myscontroller it works using the ethernet gateway but not when using Domoticz.
      • K
        K
        kunall
        wrote on last edited by kunall
        @Striffster Before this, I was running OpenHab via MQTT gateway. It works flawless. :)
        I wanted to give Domoticz a try but the ethernet gateway wont work.
        • F
          F
          floris
          My ethernetgateway didn't work also. my usb gateway does work. GizMoGuz has replied couple of weeks ago at the domoticz forum about the ethernetgateway with some modifications. Maybe they will work. (did't try it because i'm happy with my usbgateway) wondering if it is working.
          Floris
          • S
            Striffster
            @floris Do you have any link, I have searched the Domoticz forum without success.
            • F
              F
              floris
              http://www.domoticz.com/forum/viewtopic.php?f=42&t=5784
              Look for gizmoguz 6april, 11:54. :)
              • S
                Striffster
                @floris Ok thanks, I've seen that post but that was not a solution to the oneway communication.
