  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 622.2k Views 35 Watching
    @gbfromhb
    D3 is available on the side-pins. D2 is routed to the radio but can be used with some hacking.
    M Offline
    M Offline
    mbj
    @hek said:
    @gbfromhb
    I need 2 interrupts and would prefer using the external interrupts even though it might work with pin change interrupts. When looking through the forum I saw this answer from @hek but have not found any further reference to how this should be done in order not to disturb any radio functions. Anyone knows?
    • T Offline
      T Offline
      tbowmo
      I don't know if the radio actually drives the interrupt "output" pin on it's pinheader as default, or if you have to set it up when initializing the radio (@hek might have some input on this part :))
      If it drives the interrupt pin by default, then you need to either cut a trace on the sensebender, or cut / remove the pin in the pinheader on the radio module.
      • hekH Offline
        hekH Offline
        I think it does actually.
        M 1 Reply Last reply
          M Offline
          M Offline
          mbj
          @hek Is it needed for the radio to work or can I just cut it (seems odd to attach the radio to D2 if it is not really needed for anything).
          • hekH Offline
            hekH Offline
            No, it isn't currently used by the MySensors library. It could be used to wake up the board when detecting radio transmissions...
            But keeping MCU sleeping and the radio listening still uses up batteries far too quickly so I guess it's still not an option.
              M Offline
              M Offline
              mbj
              @hek @tbowmo Thanks! Cut the radio IRQ pin and soldered a connection to D2. Tested to attach both interrupts and it works using a modified SenseBenderMicro sketch. "The Thing" will when ready be placed in my mailbox (which has mail-in and mail-out doors) and as a bonus report the outside temp, humidity and battery status. Does not solve any of this worlds biggest problems but it is fun :-)
              • P Offline
                P Offline
                petoulachi
                one simple quick question, does this board can be used to create door sensors ? I do not need the temp/hum sensors, but I'm interested with the small footprint and the battery optimized board to make smallest door sensors (and some buttons).
                regards,
                • T Offline
                  T Offline
                  tbowmo
                  @petoulachi
                  Yes, it could be made into a door / window sensor.. (I'm planning on doing that myself).
                  However, you need to build your own, if you don't want the temperature/humidity sensor on it.
                  • P Offline
                    P Offline
                    petoulachi
                    @tbowmo
                    Well can't I use this board without using the temp/hum sensor ?
                    This board is quite small and allows to stack the radio module with minimum place. Also it works at 1Mhz, I guess it's a bit better than an Arduino Pro @ 3.3V ?
                    • T Offline
                      T Offline
                      tbowmo
                      Yes, you can use it without using the temp/hum sensor....
                      I just assumed, that as you wouldn't make use of it, you would like to have it removed from the board as well..
                      • P Offline
                        P Offline
                        petoulachi
                        Well I do, but I think that using a Arduino Pro 3.3V will be less effecient, but maybe I'm wrong ?
                        I'm currently using temp/hum/motion sensors with Arduino Pro 5V, but they are not battery powered. Now I need to make very small sensor with battery, and I thought that maybe this sensebender board is my solution ?
                        A 1 Reply Last reply
                        • P petoulachi
                          A Offline
                          A Offline
                          Anticimex
                          @petoulachi to make the pro mini as efficient as the SenseBender, you need to cut some traces on the board. There are forum topics for battery optimizing a pro mini. The SenseBender has these optimizations built in.
                          • P Offline
                            P Offline
                            petoulachi
                            That's why I think i'm going to go with this senseboard.
                            But I want to be sure that some connectors (D3 ?) support interrupts ? The goal is to have the sensor always in sleep mode, and wake up on interrupts only.
                            Regards,
                            • P petoulachi
                              Regards,
                              M Offline
                              M Offline
                              mbj
                              @petoulachi D3 can be used for interrupt, just tested it and it works.
                              • N Offline
                                N Offline
                                nikos1671
                                I vote for one cheap Sensebender version without the temp/hum sensor on it. It will be the perfect door/window sensor.
                                • T Offline
                                  T Offline
                                  tbowmo
                                  @nikos1671
                                  It has been up before, but back then it was decided that we don't save that much (2-3 $ or something like that). It might also be lower production quantities, which also keeps the price up..
                                  • T tbowmo
                                    @nikos1671
                                    M Offline
                                    M Offline
                                    mvader
                                    @tbowmo just curious do you guys know how many of these you've sold?
                                    I've bought about 15+ :)
                                    • hekH Offline
                                      hekH Offline
                                      @mvader
                                      Then you've bought almost 2% of them :)
                                      We're deeply grateful for yours and others support of the MySensors project.
                                      • P Offline
                                        P Offline
                                        petoulachi
                                        Ordered 6 board too ! I'm glad to support MySensors project !
                                        • T Offline
                                          T Offline
                                          timropp
                                          I've got 3 coming, can't wait to figure out what I'm going to use them for :)
                                          VeraEdge UI7 with Mysensors ethernet gateway
