  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 659.9k Views 35 Watching
  • ximinezX ximinez
    @Anticimex Ah, yes. sed /your/@tbowmo's/g. I blame lack of caffeine.
    AnticimexA
    AnticimexA
    Anticimex
    @ximinez makes sense. I'm sure you can cut down on power consumption by cutting power to those peripherals. I do not know how signing would be affected by this though, as I have not tested it with switching the atsha on and off between calls. I would like to hear from you on that topic if you choose to try it though :)
    ximinezX 1 Reply Last reply
    • AnticimexA Anticimex
      ximinezX
      ximinezX
      ximinez
      Ok, I've been looking at the image and my spare sensor. It looks like:
      Power to the NRF can be cut between C3 and VCC pin.
      ATSHA204a power can be cut on the trace that goes from the atsha and beneath the flash.
      Si7021 power can be cut at the trace that goes from C4.
      I just might have to dig out my scalpel and iron for this. If the components magically work without any extra initialization on powerup, modifying the code looks easy.
      I'll report back with my findings
      • tbowmoT
        tbowmoT
        tbowmo
        @ximinez
        For my battery reporting, I have set 1.9V as 0%, 3.3V is 100%..
        While you're at it, also power down the external flash, as it might also contribute a bit..
        • ximinezX
          ximinezX
          ximinez
          Well that went south pretty fast. Was wondering why my sensebender was acting up. Took a while to see that I had plugged in an ESP8266 module instead of one of my NRF24 modules. Those modules look far too much alike :rage:
          Serial output now looks like this: "Sånsebåndåò Micro FW 1.3" with random characters corrupted. I think I've killed it ;)
          I can still flash firmware to it via serial, so it's not completely dead.
          I can however confirm that both the SHA204A and SI7021 self-tests OK being powered on in-sketch:
          (Flash seems to randomly fail or test OK, not sure why yet)
          þSånseâånder Micòo F× 1.3 - TesôÍoäe
          Tåstiîg påòipheraló!
          -> ÓÉ7021 : ok!
          -> Æìasè : æailed!
          -> SÈA204 : Ïk (seòéal : 01234ÂBAÅ259E8AÄÅE)
          Tåót fiîésheä
          ----> Óelftest æaiìåä!
          AnticimexA 1 Reply Last reply
          • ximinezX ximinez
            -> ÓÉ7021 : ok!
            -> Æìasè : æailed!
            Tåót fiîésheä
            AnticimexA
            AnticimexA
            Anticimex
            @ximinez If possible, try to check if signing and verification of signatures work as well. I have tried to implement the use of the ATSHA to be atomic in nature, but it could be that some state is retained which is cleared on power down which might break the calculations.
            • ximinezX
              ximinezX
              ximinez
              What is the easiest and fastest way to sign and verify? I don't have a gateway set up quite yet.
              (And, is any part of setting this up dependent on serial integrity? If so I might have to adjust baud quite a bit)
              • ximinezX ximinez
                AnticimexA
                AnticimexA
                Anticimex
                @ximinez Well, without a gw the only option is to use node peer to peer transmissons to test signing. How to do it is described in the signing documentation, assuming you use development branch, you can see here. For master, look here.
                • ximinezX
                  ximinezX
                  ximinez
                  I have an Uno with an ethernet shield and nrf24 hooked up, so I will have to get around to write a sketch for that purpose.
                  But to get signing to work, I'll have to personalize the atsha? That sketch doesn't compile for me.
                  • AnticimexA
                    AnticimexA
                    Anticimex
                    Yes, you have to personalize it. What is failing? I don't have an Uno myself, but according to Jenkins the personalizer compiles ok for Uno on both master and development. You don't have any local changes?
                    • ximinezX
                      ximinezX
                      ximinez
                      The personalization fails to compile for my sensebender micro. There's a few undeclared:
                      Personalizer:225: error: 'EEPROM_SIGNING_SOFT_HMAC_KEY_ADDRESS' was not declared in this scope
                      Personalizer:225: error: 'hwReadConfigBlock' was not declared in this scope
                      Personalizer:236: error: 'EEPROM_SIGNING_SOFT_SERIAL_ADDRESS' was not declared in this scope
                      Personalizer:247: error: 'EEPROM_RF_ENCRYPTION_AES_KEY_ADDRESS' was not declared in this scope
                      Personalizer:697: error: 'hwMillis' was not declared in this scope
                      I'm trying to compile this against master however. Do I have to have dev branch to compile that sketch?
                      • ximinezX
                        ximinezX
                        ximinez
                        Fails with the same errors on Uno for me.
                        • AnticimexA
                          AnticimexA
                          Anticimex
                          @ximinez and you are certain you have no local changes to the code? Jenkins builds both master and development branches every night for both the SenseBender and the uno and it builds all examples, including the personalizer without issues.
                          • ximinezX
                            ximinezX
                            ximinez
                            Pretty sure.
                            I'll wipe my library dir and redownload master.
                            • AnticimexA
                              AnticimexA
                              Anticimex
                              If memory serves me, some of the errors you get seem to originate from code on development branch. The eeprom addresses are to my knowledge not yet available on master.
                              • ximinezX
                                ximinezX
                                ximinez
                                Ok, moved from master to dev. Sketch compiled. Not quite the output I expected however.
                                EEPROM configuration:
                                SOFT_HMAC_KEY | FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                                SOFT_SERIAL | FFFFFFFFFFFFFFFFFF
                                AES_KEY | FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                                • ximinezX ximinez
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @ximinez it is the output I expected. You have gone for soft signing, and you see the reset values of the eeprom. You need to pick atsha settings. The link I gave you gives the exact settings to personalize both for software and atsha backends.
                                  • ximinezX
                                    ximinezX
                                    ximinez
                                    Got it now :)
                                    I had two different sketches and had edited the wrong one. Now I have actual values.
                                    Is there an example GW sketch that I can load quickly to my Uno/W5100 shield/NRF24?
                                    • AnticimexA
                                      AnticimexA
                                      Anticimex
                                      :thumbsup:
                                      I'm rusty on the gateways. But on development branch, configuring signing is easier than on master branch. My link gives the details on signing configuration for both nodes and gateways with examples.
                                      • ximinezX
                                        ximinezX
                                        ximinez
                                        wrote on last edited by ximinez
                                        #419
                                        Yeah, I'm struggling a bit with those instructions. I've set up my gateway with soft signing, and got sane values written to EEPROM.
                                        Now, do I need any of the three values to personalize the sensebender?
                                        SOFT_HMAC_KEY?
                                        • ximinezX ximinez
                                          SOFT_HMAC_KEY?
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @ximinez the SenseBender you have patched/cut needs atsha personalization, so no SOFT anything. But you need to have the same hmac key stored on the atsha on the SenseBender as you have picked as soft hmac key in eeprom of your gateway (the node you have personalized for soft signing).
