  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 658.9k Views 35 Watching
  • Mitja BlazinsekM
    Mitja BlazinsekM
    Mitja Blazinsek
    OK i found the problem i just needed to clear the eeprom and it works i remembered that i had this problem before with binary switch sample
    • Mitja BlazinsekM
      Mitja BlazinsekM
      Mitja Blazinsek
      sory still not workinkg i was thinking that i solve the problem but i didn't now i was try to connect other sensebender micro and it's working with no problem and i noticed that the red led flash on micro when i connect power i dont se that led on previous not working micro is it possible that i burn micro when programming, bu ti upload program with no problems i also had 3,3V jumper on the programer :(
        You could try with a basic blink sketch and see if you can blink an led
        • Mitja BlazinsekM
          Mitja BlazinsekM
          Mitja Blazinsek
          nothing happened just upload blink code but no blinking :(
          // the setup function runs once when you press reset or power the board
            // initialize digital pin LED_BUILTIN as an output.
            pinMode(LED_BUILTIN, OUTPUT);
          // the loop function runs over and over again forever
            digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
            delay(1000);                       // wait for a second
            digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
            have you tried another led?
            • Mitja BlazinsekM
              Mitja BlazinsekM
              Mitja Blazinsek
              it work when i try button example, had no diode at the hand
              tbowmoT 1 Reply Last reply
                maybe the led on the sensebender is broken... at least you figured it still works
                • Mitja BlazinsekM Mitja Blazinsek
                  tbowmoT
                  tbowmoT
                  tbowmo
                  @mitja-blazinsek
                  Try toggling A2 instead og BUILTIN_LED. Or try the default Sensebender Micro sketch, found here.
                  With the default sketch loaded, you could try holding A0 low, while applying power to the Sensebender Micro, this will start a selftest routine, blinking the LED at the end.
                  • Mitja BlazinsekM
                    Mitja BlazinsekM
                    Mitja Blazinsek
                    can anyone help me every sensor it work fine first time in mycontroler but but when i reprogram it with same code it doesn't register anymore in my controller like i remember i have this same problem about year ago with binary switch bu i can't remember what was solution for problem that why sensebender micro doesn't work i just try hum. sensor with nano working fine after reprogram with same code my controller doesn't recognize anymore :( do i have clear anything in my controller i already try to delete node and sensor but no affect
                      Do you see correct communication on node and gw logs?
                      • Mitja BlazinsekM
                        Mitja BlazinsekM
                        Mitja Blazinsek
                        16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.2.0
                        25 TSM:INIT
                        26 TSF:WUR:MS=0
                        33 TSM:INIT:TSP OK
                        35 TSM:INIT:STATID=15
                        37 TSF:SID:OK,ID=15
                        39 TSM:FPAR
                        75 TSF:MSG:SEND,15-15-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        2082 !TSM:FPAR:NO REPLY
                        2084 TSM:FPAR
                        gohanG 1 Reply Last reply
                          25 TSM:INIT
                          26 TSF:WUR:MS=0
                          33 TSM:INIT:TSP OK
                          37 TSF:SID:OK,ID=15
                          39 TSM:FPAR
                          2084 TSM:FPAR
                          @mitja-blazinsek said in Sensebender Micro:
                          That's clearly a communication problem, look at the gateway what do you see
                          • Mitja BlazinsekM
                            Mitja BlazinsekM
                            Mitja Blazinsek
                            Jan 30, 2018 04:46:45 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:GWL OK
                            Jan 30, 2018 04:46:45 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:CKU:OK,FCTRL
                            Jan 30, 2018 04:46:45 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:FPAR REQ,ID=15
                            Jan 30, 2018 04:46:45 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:BC
                            Jan 30, 2018 04:46:45 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:READ,15-15-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                            • Mitja BlazinsekM
                              Mitja BlazinsekM
                              Mitja Blazinsek
                              why mycontroller don't register node and sensor if he receive message
                                @mitja-blazinsek I think there must be something else in the gateway log, please add more entries
                                • Mitja BlazinsekM
                                  Mitja BlazinsekM
                                  Mitja Blazinsek
                                  Jan 30, 2018 05:00:30 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] !TSF:MSG:SEND,0-0-15-15,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                  	Jan 30, 2018 05:00:29 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:GWL OK
                                  	Jan 30, 2018 05:00:29 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:CKU:OK,FCTRL
                                  	Jan 30, 2018 05:00:29 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:FPAR REQ,ID=15
                                  	Jan 30, 2018 05:00:29 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:BC
                                  	Jan 30, 2018 05:00:29 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:READ,15-15-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                  	Jan 30, 2018 05:00:28 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] !TSF:MSG:SEND,0-0-15-15,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                  	Jan 30, 2018 05:00:27 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:GWL OK
                                  	Jan 30, 2018 05:00:27 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:CKU:OK,FCTRL
                                  	Jan 30, 2018 05:00:27 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:FPAR REQ,ID=15
                                  	Jan 30, 2018 05:00:27 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:BC
                                  	Jan 30, 2018 05:00:27 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:READ,15-15-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                  	Jan 30, 2018 05:00:26 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] !TSF:MSG:SEND,0-0-15-15,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                  	Jan 30, 2018 05:00:25 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:GWL OK
                                  	Jan 30, 2018 05:00:25 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:CKU:OK,FCTRL
                                  	Jan 30, 2018 05:00:25 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:FPAR REQ,ID=15
                                  	Jan 30, 2018 05:00:25 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:BC
                                  	Jan 30, 2018 05:00:25 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:READ,15-15-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                  	Jan 30, 2018 05:00:24 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] !TSF:MSG:SEND,0-0-15-15,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                  	Jan 30, 2018 05:00:23 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:GWL OK
                                  	Jan 30, 2018 05:00:23 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:CKU:OK
                                  	Jan 30, 2018 05:00:23 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:PNG:SEND,TO=0
                                  	Jan 30, 2018 05:00:23 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:FPAR REQ,ID=15
                                  	Jan 30, 2018 05:00:23 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:BC
                                  	Jan 30, 2018 05:00:23 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:READ,15-15-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                  	Jan 30, 2018 05:00:14 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                                  	Jan 30, 2018 05:00:14 PM	Notice	Gateway	 mysensors	Sent	Internal	[Discover]
                                  	Jan 30, 2018 05:00:12 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] !TSF:MSG:SEND,0-0-15-15,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                  	Jan 30, 2018 05:00:11 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:GWL OK
                                  	Jan 30, 2018 05:00:11 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:CKU:OK,FCTRL
                                  	Jan 30, 2018 05:00:11 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:FPAR REQ,ID=15
                                  	Jan 30, 2018 05:00:11 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:BC
                                  	Jan 30, 2018 05:00:11 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:READ,15-15-255,s=255,c=3,t=7,pt=0,l=0,sg=0:```
                                  gohanG Mitja BlazinsekM 2 Replies Last reply
                                    That is a transmission error, so either the node is not receiving well or the gateway doesn't have a good power source for radio
                                    • Mitja BlazinsekM
                                      Mitja BlazinsekM
                                      Mitja Blazinsek
                                      couldn't be radio second sensebender micro working fin bu that micro is out of the box didn't touch em fist one that i was programming with officially code don't work anymore also nano that i programm default Door/Window/Button and relay sketch on it bouth doesent work since i was start programing i realy dont know anymore try ewerything but mycontroler dont show nothing anymore no senors no nodes except original sensebender micro
                                        If you get NACK in the debug it means it failed the communication, so of course it will not show any data on controller.
                                        • Mitja BlazinsekM
                                          Mitja BlazinsekM
                                          Mitja Blazinsek
                                          but why fail i upload officially sketches from my sensors also try same radio from sensebender that works also try blink test on sensebender and it works so what else could be i have everything latest version my controler mysensor libary...
