  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 657.0k Views 35 Watching
  • J jovo
    @mvader Hi,
    I guess you are not for 8 months on v2?
    I had a long time on the previous version as well.
    Haven't done the measurements, but I noticed my batteries were depleted quickly since v2 was on.
    I am more concerned about the fact that the force transmission doesn't seem to be working.
    alexsh1A
    alexsh1A
    alexsh1
    @jovo how exactly do you define "quicker" please? I do not think anyone had enough time to test it. My batteries dropped 0.2V for 2 months (reporting temp/humidity/pressure every minute) but that does not mean anything at all. I would need to run it for another 6 months at least to say what I think.
    • Mitja BlazinsekM
      Mitja BlazinsekM
      Mitja Blazinsek
      i have some problems with sensbender micro it all work fine it shows temp and hum in mycontroller bu then i try to program the board to test my FTDI programmer, for test i was try to upload default sketch but since then it showing me only node in mycontroller without any sensors :(
      this is my log from debug:
      0 MCO:BGN:INIT NODE,CP=RNONA--,VER=2.1.1
      4 TSM:INIT
      4 TSF:WUR:MS=0
      12 TSM:INIT:TSP OK
      14 TSF:SID:OK,ID=5
      16 TSM:FPAR
      53 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      2062 !TSM:FPAR:NO REPLY
      2064 TSM:FPAR
      2101 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      4110 !TSM:FPAR:NO REPLY
      4112 TSM:FPAR
      4149 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      6158 !TSM:FPAR:NO REPLY
      6160 TSM:FPAR
      6197 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      8206 !TSM:FPAR:FAIL
      8208 TSM:FAIL:CNT=1
      8210 TSM:FAIL:PDT
      18214 TSM:FAIL:RE-INIT
      18216 TSM:INIT
      18225 TSM:INIT:TSP OK
      18227 TSF:SID:OK,ID=5
      18229 TSM:FPAR
        That looks like there is no communication with gateway. Did you check gw log? You could also update mysensors to latest 2.2
        • Mitja BlazinsekM
          Mitja BlazinsekM
          Mitja Blazinsek
          but before it was working im using sensebender gateway and i see node in controler, i update my sensors and still nothing
          • Mitja BlazinsekM
            Mitja BlazinsekM
            Mitja Blazinsek
            OK i found the problem i just needed to clear the eeprom and it works i remembered that i had this problem before with binary switch sample
            • Mitja BlazinsekM
              Mitja BlazinsekM
              Mitja Blazinsek
              sory still not workinkg i was thinking that i solve the problem but i didn't now i was try to connect other sensebender micro and it's working with no problem and i noticed that the red led flash on micro when i connect power i dont se that led on previous not working micro is it possible that i burn micro when programming, bu ti upload program with no problems i also had 3,3V jumper on the programer :(
                You could try with a basic blink sketch and see if you can blink an led
                • Mitja BlazinsekM
                  Mitja BlazinsekM
                  Mitja Blazinsek
                  nothing happened just upload blink code but no blinking :(
                  // the setup function runs once when you press reset or power the board
                    // initialize digital pin LED_BUILTIN as an output.
                    pinMode(LED_BUILTIN, OUTPUT);
                  // the loop function runs over and over again forever
                    digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
                    delay(1000);                       // wait for a second
                    digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
                    have you tried another led?
                    • Mitja BlazinsekM
                      Mitja BlazinsekM
                      Mitja Blazinsek
                      it work when i try button example, had no diode at the hand
                      tbowmoT 1 Reply Last reply
                        maybe the led on the sensebender is broken... at least you figured it still works
                        • Mitja BlazinsekM Mitja Blazinsek
                          tbowmoT
                          tbowmoT
                          tbowmo
                          @mitja-blazinsek
                          Try toggling A2 instead og BUILTIN_LED. Or try the default Sensebender Micro sketch, found here.
                          With the default sketch loaded, you could try holding A0 low, while applying power to the Sensebender Micro, this will start a selftest routine, blinking the LED at the end.
                          • Mitja BlazinsekM
                            Mitja BlazinsekM
                            Mitja Blazinsek
                            can anyone help me every sensor it work fine first time in mycontroler but but when i reprogram it with same code it doesn't register anymore in my controller like i remember i have this same problem about year ago with binary switch bu i can't remember what was solution for problem that why sensebender micro doesn't work i just try hum. sensor with nano working fine after reprogram with same code my controller doesn't recognize anymore :( do i have clear anything in my controller i already try to delete node and sensor but no affect
                              Do you see correct communication on node and gw logs?
                              • Mitja BlazinsekM
                                Mitja BlazinsekM
                                Mitja Blazinsek
                                25 TSM:INIT
                                26 TSF:WUR:MS=0
                                33 TSM:INIT:TSP OK
                                35 TSM:INIT:STATID=15
                                37 TSF:SID:OK,ID=15
                                39 TSM:FPAR
                                75 TSF:MSG:SEND,15-15-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                2082 !TSM:FPAR:NO REPLY
                                2084 TSM:FPAR
                                gohanG 1 Reply Last reply
                                  25 TSM:INIT
                                  26 TSF:WUR:MS=0
                                  33 TSM:INIT:TSP OK
                                  37 TSF:SID:OK,ID=15
                                  39 TSM:FPAR
                                  2084 TSM:FPAR
                                  @mitja-blazinsek said in Sensebender Micro:
                                  That's clearly a communication problem, look at the gateway what do you see
                                  • Mitja BlazinsekM
                                    Mitja BlazinsekM
                                    Mitja Blazinsek
                                    Jan 30, 2018 04:46:45 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:GWL OK
                                    Jan 30, 2018 04:46:45 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:CKU:OK,FCTRL
                                    Jan 30, 2018 04:46:45 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:FPAR REQ,ID=15
                                    Jan 30, 2018 04:46:45 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:BC
                                    Jan 30, 2018 04:46:45 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:READ,15-15-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                    • Mitja BlazinsekM
                                      Mitja BlazinsekM
                                      Mitja Blazinsek
                                      why mycontroller don't register node and sensor if he receive message
                                        @mitja-blazinsek I think there must be something else in the gateway log, please add more entries
                                        • Mitja BlazinsekM
                                          Mitja BlazinsekM
                                          Mitja Blazinsek
                                          Jan 30, 2018 05:00:30 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] !TSF:MSG:SEND,0-0-15-15,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                          	Jan 30, 2018 05:00:29 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:GWL OK
                                          	Jan 30, 2018 05:00:29 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:CKU:OK,FCTRL
                                          	Jan 30, 2018 05:00:29 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:FPAR REQ,ID=15
                                          	Jan 30, 2018 05:00:29 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:BC
                                          	Jan 30, 2018 05:00:29 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:READ,15-15-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                          	Jan 30, 2018 05:00:28 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] !TSF:MSG:SEND,0-0-15-15,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                          	Jan 30, 2018 05:00:27 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:GWL OK
                                          	Jan 30, 2018 05:00:27 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:CKU:OK,FCTRL
                                          	Jan 30, 2018 05:00:27 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:FPAR REQ,ID=15
                                          	Jan 30, 2018 05:00:27 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:BC
                                          	Jan 30, 2018 05:00:27 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:READ,15-15-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                          	Jan 30, 2018 05:00:26 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] !TSF:MSG:SEND,0-0-15-15,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                          	Jan 30, 2018 05:00:25 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:GWL OK
                                          	Jan 30, 2018 05:00:25 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:CKU:OK,FCTRL
                                          	Jan 30, 2018 05:00:25 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:FPAR REQ,ID=15
                                          	Jan 30, 2018 05:00:25 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:BC
                                          	Jan 30, 2018 05:00:25 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:READ,15-15-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                          	Jan 30, 2018 05:00:24 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] !TSF:MSG:SEND,0-0-15-15,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                          	Jan 30, 2018 05:00:23 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:GWL OK
                                          	Jan 30, 2018 05:00:23 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:CKU:OK
                                          	Jan 30, 2018 05:00:23 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:PNG:SEND,TO=0
                                          	Jan 30, 2018 05:00:23 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:FPAR REQ,ID=15
                                          	Jan 30, 2018 05:00:23 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:BC
                                          	Jan 30, 2018 05:00:23 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:READ,15-15-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                          	Jan 30, 2018 05:00:14 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                                          	Jan 30, 2018 05:00:14 PM	Notice	Gateway	 mysensors	Sent	Internal	[Discover]
                                          	Jan 30, 2018 05:00:12 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] !TSF:MSG:SEND,0-0-15-15,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                          	Jan 30, 2018 05:00:11 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:GWL OK
                                          	Jan 30, 2018 05:00:11 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:CKU:OK,FCTRL
                                          	Jan 30, 2018 05:00:11 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:FPAR REQ,ID=15
                                          	Jan 30, 2018 05:00:11 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:BC
                                          	Jan 30, 2018 05:00:11 PM	Notice	Node	 mysensors   0	Received	Internal	[Log message] TSF:MSG:READ,15-15-255,s=255,c=3,t=7,pt=0,l=0,sg=0:```
                                          gohanG Mitja BlazinsekM 2 Replies Last reply
