  3. Multisensor PIR problem [solved]
53 Posts 7 Posters 27.1k Views 3 Watching
  • N Offline
    N Offline
    n3ro
    wrote on last edited by n3ro
    Hey Folks,
    i have some problems with my battery powered arduino mini.
    When i use my sketch, the PIR doesn't signal present right. Only sometime i get a signal.
    https://github.com/n3roGit/MySensors_n3ro/tree/master/MotionSensor_DHT_light_battery_mod
    But when i use this (simple) sketch with only PIR it works like charm.
    https://github.com/n3roGit/Arduino-home-automation/tree/master/2.4Ghz (MySensors)/Arduino/PirSleepBattery
    Any ideas whats wrong?
    Regards,
    n3ro
    pimatic + MySensors + Homeduino + z-way
    • A Offline
      A Offline
      andriej
      " delay(dht.getMinimumSamplingPeriod());" is the problem - it delays whole sketch every run of loop()
      N 1 Reply Last reply
      • N Offline
        N Offline
        n3ro
        PERFECT!!!!!!!!!!! It works now :):):)
        Big THX!
        • A andriej
          N Offline
          N Offline
          n3ro
          @andriej hey,
          the PIR works perfect now, but the DHT didnt update... Only the first startup of the arduino works:
          ---------- Battery: 100
          ---------- PIR: 1
          send: 10-10-0-0 s=1,c=1,t=16,pt=0,l=1,st=ok:1
          send: 10-10-0-0 s=3,c=1,t=0,pt=7,l=5,st=ok:20.5
          ---------- Temp: 20.50
          send: 10-10-0-0 s=2,c=1,t=1,pt=7,l=5,st=ok:34.6
          ---------- Humidity: 34.60
          send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:87
          ---------- Light: 87
          ---------- PIR: 0
          send: 10-10-0-0 s=1,c=1,t=16,pt=0,l=1,st=ok:0
          ---------- PIR: 1
          send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:84
          ---------- Light: 84
          ---------- PIR: 0
          send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:88
          ---------- Light: 88
          ---------- PIR: 1
          send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:83
          ---------- Light: 83
          ---------- PIR: 0
          ---------- PIR: 1
          S 1 Reply Last reply
          • N n3ro
            @andriej hey,
            ---------- PIR: 1
            ---------- PIR: 0
            ---------- PIR: 1
            ---------- PIR: 0
            ---------- PIR: 1
            ---------- PIR: 0
            ---------- PIR: 1
            Sparkman
            @n3ro the DHT needs a delay between polling. You are likely polling it too fast now. Rather than remove the delay command, you need to use a different method to not poll the DHT too frequently. The millis command is one option: http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
            Cheers
            Al
            • N Offline
              N Offline
              n3ro
              ufff. to build a multisensor sketch is really hard :-/
              thx for your info!
              • N Offline
                N Offline
                n3ro
                can somebody help me with my sketch? i dont understand millis :-/
                • N n3ro
                  Sparkman
                  wrote on last edited by Sparkman
                  @n3ro Hard to help you with your sketch since you don't have it posted ;-)
                  • N Offline
                    N Offline
                    n3ro
                    • T Offline
                      T Offline
                      torfinn
                      Hi ! I had the same problem. Seems like gw.sleep(some_number_of_mills); lets you loose the init of the dht. Just put dht.begin(); in your loop before you read the value and it should work.
                      example.
                      void loop ()
                      dht.begin();
                      float temperature = dht.readTemperature();
                      • T torfinn
                        example.
                        void loop ()
                        dht.begin();
                        N Offline
                        N Offline
                        n3ro
                        @torfinn said:
                        dht.begin();
                        Hey torfinn,
                        i get this error when compiling:
                        MotionSensor_DHT_light_battery_mod.ino: In function 'void loop()':
                        MotionSensor_DHT_light_battery_mod.ino:109:7: error: 'class DHT' has no member named 'begin'
                        Fehler beim Kompilieren.
                        • N Offline
                          N Offline
                          n3ro
                          I have a idea,
                          is it possible to build a second loop like this?
                          But now i have one problem... the loop2 never run...
                          #include <readVcc.h>
                          #include <DHT.h>
                          #include <Scheduler.h>
                          #define NODE_ID 11                       // ID of node
                          unsigned long SLEEP_TIME = 600000;        // Sleep time between reports (in milliseconds)
                          #define CHILD_ID_PIR 1                   // Id of the sensor PIR
                          #define CHILD_ID_HUM 2                   // Id of the sensor HUM
                          #define CHILD_ID_TEMP 3                  // Id of the sensor TEMP
                          #define CHILD_ID_LIGHT 4                 // Id of the sensor LIGHT
                          #define PIR_SENSOR_DIGITAL 3           // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                          #define INTERRUPT PIR_SENSOR_DIGITAL-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
                          #define HUMIDITY_SENSOR_DIGITAL_PIN 2
                          #define LIGHT_SENSOR_ANALOG_PIN 0
                          // Initialize Variables
                          MyMessage msgPir(CHILD_ID_PIR, V_TRIPPED);
                          MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
                          DHT dht;
                          float lastTemp;
                          float lastHum;
                          boolean metric = true;
                          int oldBatteryPcnt;
                          int lastLightLevel;
                          unsigned long time;
                          int MIN_V = 2700; // empty voltage (0%)
                          int MAX_V = 3200; // full voltage (100%)
                            gw.begin(NULL, NODE_ID, false);
                            //PIR
                            gw.sendSketchInfo("Motion Sensor", "1.0");
                            pinMode(PIR_SENSOR_DIGITAL, INPUT);      // sets the motion sensor digital pin as input
                            digitalWrite(PIR_SENSOR_DIGITAL, HIGH);
                            gw.present(CHILD_ID_PIR, S_MOTION);
                            //DHT
                            gw.sendSketchInfo("Humidity", "1.0");
                            //LIGHT
                            gw.sendSketchInfo("Light Sensor", "1.0");
                            gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
                            Scheduler.startLoop(loop2);
                            // Read digital motion value
                            boolean tripped = digitalRead(PIR_SENSOR_DIGITAL) == HIGH;
                            Serial.print("---------- PIR: ");
                            Serial.println(tripped);
                            gw.send(msgPir.set(tripped ? "1" : "0")); // Send tripped value to gw
                            gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
                          void loop2()
                            //DHT
                            //dht.begin();
                            //delay(1000);
                            //millis(dht.getMinimumSamplingPeriod());
                            //Serial.print(dht.getMinimumSamplingPeriod());
                            if (isnan(temperature)) {
                              lastTemp = temperature;
                              if (!metric) {
                              Serial.print("---------- Temp: ");
                              Serial.println(temperature);
                            if (isnan(humidity)) {
                              lastHum = humidity;
                              Serial.print("---------- Humidity: ");
                              Serial.println(humidity);
                            // Light
                            int lightLevel = (1023 - analogRead(LIGHT_SENSOR_ANALOG_PIN)) / 10.23;
                            //Serial.println(lightLevel);
                              gw.send(msgLight.set(lightLevel));
                              lastLightLevel = lightLevel;
                              Serial.print("---------- Light: ");
                            // Measure battery
                            float batteryV = readVcc();
                            int batteryPcnt = (((batteryV - MIN_V) / (MAX_V - MIN_V)) * 100 );
                            if (batteryPcnt > 100) {
                              batteryPcnt = 100;
                            if (batteryPcnt != oldBatteryPcnt) {
                              gw.sendBatteryLevel(batteryPcnt); // Send battery percentage
                              oldBatteryPcnt = batteryPcnt;
                            Serial.print("---------- Battery: ");
                            Serial.println(batteryPcnt);
                            gw.sleep(SLEEP_TIME);
                          i have downloaded THIS
                          But i get this error when compiling:
                          In file included from MotionSensor_DHT_light_battery_mod.ino:6:0:
                          Arduino\libraries\Scheduler/Scheduler.h:33:22: fatal error: WProgram.h: No such file or directory
                          #include <WProgram.h>
                          • R Offline
                            R Offline
                            rvendrame
                            @n3ro , you can have only one loop().
                            You need to merge the two logics into into a single loop. You might also want to remove the second sleep, otherwise PIR will not trigger there.
                            ESP8266 GW + mySensors 2.3.2
                            Alexa / Google Home
                            • R rvendrame
                              N Offline
                              N Offline
                              n3ro
                              @rvendrame do you have an idea how to do it?
                              • R Offline
                                R Offline
                                rvendrame
                                Maybe you can start by to removing these 3 lines:
                                void loop2()
                                ... and move the 1st sleep to the end of loop (where the 2nd sleep is):
                                .... and remove the 2nd sleep:
                                Alexa / Google Home
                                • R rvendrame
                                  void loop2()
                                  N Offline
                                  N Offline
                                  n3ro
                                  @rvendrame
                                  if i use this:
                                  #include <DHT.h>
                                  #define NODE_ID 10                       // ID of node
                                  DHT dht;
                                  float lastTemp;
                                  float lastHum;
                                  int oldBatteryPcnt;
                                  int lastLightLevel;
                                    //PIR
                                    //DHT
                                    //LIGHT
                                    // Measure battery
                                      batteryPcnt = 100;
                                    //DHT
                                    //delay(dht.getMinimumSamplingPeriod());
                                      if (!metric) {
                                      lastHum = humidity;
                                    // Light
                                  the pir works fine. but the dht doesn't work.
                                  when delay(dht.getMinimumSamplingPeriod()); is used the dht works and the pir fails.
                                  • R Offline
                                    R Offline
                                    rvendrame
                                    It makes sense ;-) Try this:
                                    create (outside the loop) a variable to count the time:
                                    long mytime = 0;
                                    .. and replace the delay by :
                                     if ( milis() > mytime )  {
                                       <  Put the dht stuff here >
                                      mytime = millis() + dht.getMinimumSamplingPeriod() ;
                                    Alexa / Google Home
                                    • R rvendrame
                                      long mytime = 0;
                                      N Offline
                                      N Offline
                                      n3ro
                                      @rvendrame
                                      hmm :)
                                      if is use this:
                                      #include <DHT.h>
                                      unsigned long SLEEP_TIME = 10000;        // Sleep time between reports (in milliseconds)
                                      DHT dht;
                                      float lastTemp;
                                      float lastHum;
                                      int oldBatteryPcnt;
                                      int lastLightLevel;
                                      long mytime = 0;
                                        //PIR
                                        //DHT
                                        //LIGHT
                                        if ( millis() > mytime )  {
                                          //DHT
                                            if (!metric) {
                                            lastHum = humidity;
                                          // Light
                                          // Measure battery
                                            batteryPcnt = 100;
                                          mytime = millis() + dht.getMinimumSamplingPeriod();
                                           Serial.println(mytime);
                                      i get this output:
                                      ---------- PIR: 0
                                      send: 10-10-0-0 s=1,c=1,t=16,pt=0,l=1,st=fail:0
                                      6608
                                      ---------- PIR: 0
                                      6608
                                      ---------- PIR: 0
                                      6608
                                      ---------- PIR: 0
                                      6608
                                      ---------- PIR: 0
                                      send: 10-10-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
                                      send: 10-10-0-0 s=2,c=1,t=1,pt=7,l=5,st=fail:41.7
                                      ---------- Humidity: 41.70
                                      send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=fail:38
                                      ---------- Light: 38
                                      11148
                                      ---------- PIR: 0
                                      11148
                                      ---------- PIR: 0
                                      11148
                                      ---------- PIR: 0
                                      11148
                                      ---------- PIR: 0
                                      11148
                                      ---------- PIR: 0
                                      15441
                                      ---------- PIR: 0
                                      15441
                                      ---------- PIR: 0
                                      15441
                                      ---------- PIR: 0
                                      15441
                                      ---------- PIR: 1
                                      the pir sends 0 and didnt sleep right :(
                                      • R Offline
                                        R Offline
                                        rvendrame
                                        What is this number? Did you print the milis()?
                                        6608 <<<<<<
                                        Alexa / Google Home
                                        • R rvendrame
                                          6608 <<<<<<
                                          N Offline
                                          N Offline
                                          n3ro
                                          yes :)
