  3. Camera as a sensor
Camera as a sensor
42 Posts 5 Posters 26.1k Views 1 Watching
  • M Mickey
    http://www.aliexpress.com/item/LYNEW-Portable-Mini-Wireless-wifi-Router-3G-4G-Hotspot-Wifi-Hotspot-support-3G-USB-modems/32257312139.html
    Today there are openwrt enable modules on aliexpress that start from below 8$ that can be attached to mjpg usb camera and can take pictures and streams with less than 10$ price tag.
    Moshe LivneM
    Moshe LivneM
    Moshe Livne
    @Mickey this device is a gsm hotspot generator. it connects to a USB GSM dongle and allows you to connect to it either wired or wirelessly. I have never seen devices like the ones you mention. they could be a good solution
    axillentA 1 Reply Last reply
    • Moshe LivneM Moshe Livne
      axillentA
      axillentA
      axillent
      wrote on last edited by axillent
      #22
      do not stick to it's original application
      the idea is that open-wrt can run on this small things. Open-wrt is a linux type system, you can program it very similar to RPI
      it is very cool if any camera working example exists for open-wrt
      sense and drive
        I have one (soon two) RPi with camera modules that take pictures and store / send to Pushbullet when a certain MySensors PIR is triggered. Has worked pretty well for the past year. and a Pi + Camera is still reasonably cheap plus it's a "real" computer so it can do anything with the camera and images. And the Pi camera is still pretty good, unless you happen to get a real bad clone from Ebay or something. Hardly worth it. I don't know how good these cameras in the store are, but I doubt they come anywhere near the simplicity and guaranteed quality of the Pi camera module.
        If you like, you can also use the "motion" package on the Pi, but that will be a real hassle with false triggers and all. The cheap PIR motion sensors have worked surprisingly well. It's more a question of positioning them right so you don't have problems with sunlight, fireworks, curious magpies etc.
        I have my RPi inside camera housings I got from AliExpress. There are a couple there that are pretty good. I think finding a bracket can be more of a challenge. I have J-brackets that fit under the eaves.
        I have the raspimjpeg script running on the Pi btw. You could just use raspistill I suppose but it's nice to be able to manually view the camera feed from the browser and have remote control at your fingertips. Hell, you could even get one of those motorized RPi things that are able to turn the camera.
        I have a sort of Power Over Ethernet going for my cameras btw.
        axillentA
        axillentA
        axillent
        @bjornhallberg very nice setup! my congratulations!
        for DIY you did it pretty well
        but cost vise I do not see how this can be more efficient comparing to foscam
        sense and drive
        • axillentA axillent
          Moshe LivneM
          Moshe LivneM
          Moshe Livne
          @axillent Oh, still not used to thinking this way. This is beyond the (very limited) limits of my knowledge.... can be great.... total setup fee of ~15$
            Mickey
            I have an example of this just with tl-wr703n but the one I posted from aliexpress is just the same:
            openwrt webcam
            • M Mickey
              openwrt webcam
              Moshe LivneM
              Moshe LivneM
              Moshe Livne
              @Mickey very good and detailed article. I have several of the GSM modems (that I now understand are not GSM modems at all) somewhere so i'll see if they can be flashed with openwrt. should be fuuuunnnn.
                Mickey
                wrote on last edited by Mickey
                #27
                Notice that the one I posted from aliexpress have its own procedure to flash openwrt on. Be careful not to brick your module...
                  bjornhallbergB
                  bjornhallbergB
                  bjornhallberg
                  @axillent
                  @Moshe-Livne
                  Yeah, it is perhaps not the most economical solution. Probably closer to $100 per unit. Foscams have probably become better and cheaper since last I looked. Personally I'd rather have more control over my setup. Like how the housing is ventilated. Plus all the fun of building and figuring things out. Of course I don't get night vision, but I figured it is better to trigger a relay to turn on some floodlights or whatnot that will give intruders some warning. No use being sneaky about it.
                  But yes, it would be really interesting if someone could come up with a really cheap battery powered solution.
                    @axillent
                    @Moshe-Livne
                    Mickey
                    @bjornhallberg said:
                    @axillent
                    @Moshe-Livne
                    openwrt as battery powered solution wont last much but they can be attach to cheap 5v solar pannel by day and run on lipo by night so no need for external power source. also
                    Its possible to install Motion on thoes modules and have state of the art motion sensors.
                    • M Mickey
                      @axillent
                      @Moshe-Livne
                      Moshe LivneM
                      Moshe LivneM
                      Moshe Livne
                      @Mickey how quickly do they boot up? might boot it when pir is triggered.
                        Mickey
                        I thought about it but openwrt is a full linux and it takes 15-20 seconds to boot up so it will be half a minute delay between trigger and response
                        • bjornhallbergB
                          bjornhallbergB
                          bjornhallberg
                          Speaking of battery powered cameras, there already are commercial products such as Arlo and Homeboy:
                          http://www.cnet.com/products/netgear-arlo-smart-home-security-kit/
                          http://www.cnet.com/products/homeboy/
                          Not cheap enough, and battery times will surely vary depending on use, but they are a nice proof of concept.
                          • M Mickey
                            Moshe LivneM
                            Moshe LivneM
                            Moshe Livne
                            @Mickey they are so small!!!!
                              Mickey
                              what is so small?
                              • Moshe LivneM
                                Moshe LivneM
                                Moshe Livne
                                the tiny 3g routers from aliexpress. just got one. do you happen to have the openwrt firmware pre-compiled?
                                  Mickey
                                  which one exactly did you buy?
                                  • M Mickey
                                    Moshe LivneM
                                    Moshe LivneM
                                    Moshe Livne
                                    @Mickey http://www.aliexpress.com/item/LYNEW-Portable-Mini-Wireless-wifi-Router-3G-4G-Hotspot-Wifi-Hotspot-support-3G-USB-modems/32257312139.html
                                      Mickey
                                      start from here:
                                      http://wiki.openwrt.org/toh/unbranded/a5-v11
                                      • Moshe LivneM
                                        Moshe LivneM
                                        Moshe Livne
                                        Been there.... just wasn't keen on compiling it. Oh well.
                                          Mickey
                                          This post is deleted!
