  3. Camera as a sensor
Camera as a sensor
42 Posts 5 Posters 26.1k Views 1 Watching
  • Moshe LivneM Moshe Livne
    @axillent no, no.... as I said, i want to use it as cheap entrance device. PIR is good enough to trigger the response
    axillentA
    axillentA
    axillent
    can you explain exactly what do you want?
    PIR is triggering event and someone is taking picture at this moment?
    sense and drive
    • axillentA axillent
      Moshe LivneM
      Moshe LivneM
      Moshe Livne
      @axillent yes. just a door or hall sensor that will be triggered by the PIR, take a snapshot (or maybe several in 10 sec increment) and send them to the home automation system.
      axillentA 1 Reply Last reply
        axillentA
        axillentA
        axillent
        OK, I see. Do you want both PIR and camera module been connected to the same device? If yes this could have not much todo with mysensors. It can be regular arduino or rpi sketch sending pictures by FTP or email.
        If you want to have PIR on other device you can use mysensor to sens PIR and trigger other device to take pictures using mysensors radio
        sense and drive
        • bjornhallbergB
          bjornhallbergB
          bjornhallberg
          I have one (soon two) RPi with camera modules that take pictures and store / send to Pushbullet when a certain MySensors PIR is triggered. Has worked pretty well for the past year. and a Pi + Camera is still reasonably cheap plus it's a "real" computer so it can do anything with the camera and images. And the Pi camera is still pretty good, unless you happen to get a real bad clone from Ebay or something. Hardly worth it. I don't know how good these cameras in the store are, but I doubt they come anywhere near the simplicity and guaranteed quality of the Pi camera module.
          If you like, you can also use the "motion" package on the Pi, but that will be a real hassle with false triggers and all. The cheap PIR motion sensors have worked surprisingly well. It's more a question of positioning them right so you don't have problems with sunlight, fireworks, curious magpies etc.
          I have my RPi inside camera housings I got from AliExpress. There are a couple there that are pretty good. I think finding a bracket can be more of a challenge. I have J-brackets that fit under the eaves.
          I have the raspimjpeg script running on the Pi btw. You could just use raspistill I suppose but it's nice to be able to manually view the camera feed from the browser and have remote control at your fingertips. Hell, you could even get one of those motorized RPi things that are able to turn the camera.
          I have a sort of Power Over Ethernet going for my cameras btw.
          Moshe LivneM axillentA 2 Replies Last reply
            Moshe LivneM
            Moshe LivneM
            Moshe Livne
            @bjornhallberg That is a very cool setup although i suspect its not very economical. the pi+camera would cost ~80$ i think. plus casing and bracket would get you very close to foscam if not higher. I was aiming at cheapest possible solution. maybe even one that can run on battery.
              Mickey
              wrote on last edited by Mickey
              http://www.aliexpress.com/item/LYNEW-Portable-Mini-Wireless-wifi-Router-3G-4G-Hotspot-Wifi-Hotspot-support-3G-USB-modems/32257312139.html
              Today there are openwrt enable modules on aliexpress that start from below 8$ that can be attached to mjpg usb camera and can take pictures and streams with less than 10$ price tag.
              • M Mickey
                Moshe LivneM
                Moshe LivneM
                Moshe Livne
                @Mickey this device is a gsm hotspot generator. it connects to a USB GSM dongle and allows you to connect to it either wired or wirelessly. I have never seen devices like the ones you mention. they could be a good solution
                  axillentA
                  axillentA
                  axillent
                  #22
                  do not stick to it's original application
                  the idea is that open-wrt can run on this small things. Open-wrt is a linux type system, you can program it very similar to RPI
                  it is very cool if any camera working example exists for open-wrt
                  sense and drive
                    axillentA
                    axillentA
                    axillent
                    @bjornhallberg very nice setup! my congratulations!
                    for DIY you did it pretty well
                    but cost vise I do not see how this can be more efficient comparing to foscam
                    sense and drive
                      Moshe LivneM
                      Moshe LivneM
                      Moshe Livne
                      @axillent Oh, still not used to thinking this way. This is beyond the (very limited) limits of my knowledge.... can be great.... total setup fee of ~15$
                        Mickey
                        I have an example of this just with tl-wr703n but the one I posted from aliexpress is just the same:
                        openwrt webcam
                        • M Mickey
                          openwrt webcam
                          Moshe LivneM
                          Moshe LivneM
                          Moshe Livne
                          @Mickey very good and detailed article. I have several of the GSM modems (that I now understand are not GSM modems at all) somewhere so i'll see if they can be flashed with openwrt. should be fuuuunnnn.
                            Mickey
                            #27
                            Notice that the one I posted from aliexpress have its own procedure to flash openwrt on. Be careful not to brick your module...
                              bjornhallbergB
                              bjornhallbergB
                              bjornhallberg
                              @axillent
                              @Moshe-Livne
                              Yeah, it is perhaps not the most economical solution. Probably closer to $100 per unit. Foscams have probably become better and cheaper since last I looked. Personally I'd rather have more control over my setup. Like how the housing is ventilated. Plus all the fun of building and figuring things out. Of course I don't get night vision, but I figured it is better to trigger a relay to turn on some floodlights or whatnot that will give intruders some warning. No use being sneaky about it.
                              But yes, it would be really interesting if someone could come up with a really cheap battery powered solution.
                                @axillent
                                @Moshe-Livne
                                Mickey
                                @bjornhallberg said:
                                @axillent
                                @Moshe-Livne
                                openwrt as battery powered solution wont last much but they can be attach to cheap 5v solar pannel by day and run on lipo by night so no need for external power source. also
                                Its possible to install Motion on thoes modules and have state of the art motion sensors.
                                • M Mickey
                                  @axillent
                                  @Moshe-Livne
                                  Moshe LivneM
                                  Moshe LivneM
                                  Moshe Livne
                                  @Mickey how quickly do they boot up? might boot it when pir is triggered.
                                    Mickey
                                    I thought about it but openwrt is a full linux and it takes 15-20 seconds to boot up so it will be half a minute delay between trigger and response
                                    • bjornhallbergB
                                      bjornhallbergB
                                      bjornhallberg
                                      Speaking of battery powered cameras, there already are commercial products such as Arlo and Homeboy:
                                      http://www.cnet.com/products/netgear-arlo-smart-home-security-kit/
                                      http://www.cnet.com/products/homeboy/
                                      Not cheap enough, and battery times will surely vary depending on use, but they are a nice proof of concept.
                                      • M Mickey
                                        Moshe LivneM
                                        Moshe LivneM
                                        Moshe Livne
                                        @Mickey they are so small!!!!
                                          Mickey
                                          what is so small?
